- jai voulu faire un upgrade de ecth à lenny ! et apres avoir fait :
apt-get -f install ou aptitude -f install ,j’ai la fenetre suivante:
apt-get -f install
Reading Package Lists… Done
Building Dependency Tree… Done
Correcting dependencies… Done
The following extra packages will be installed:
exim4-base exim4-daemon-light libc6 libdb4.6 libgcrypt11 libgnutls26
libgpg-error0 libpcre3 libtasn1-3 locales lsb-base
Suggested packages:
eximon4 exim4-doc-html exim4-doc-info gnutls-bin libmail-spf-query-perl
swaks glibc-doc libc6-i686 rng-tools
The following packages will be REMOVED:
kernel-image-2.6.8-2-686
The following NEW packages will be installed:
exim4-daemon-light libdb4.6 libgnutls26 libtasn1-3 lsb-base
The following packages will be upgraded:
exim4-base libc6 libgcrypt11 libgpg-error0 libpcre3 locales
6 upgraded, 5 newly installed, 1 to remove and 230 not upgraded.
Need to get 0B/12.0MB of archives.
After unpacking 44.7MB disk space will be freed.
Do you want to continue? [Y/n] Y
Preconfiguring packages …
(Reading database … 28187 files and directories currently installed.)
Removing kernel-image-2.6.8-2-686 …
You are running a kernel (version 2.6.8-2-686) and attempting to remove
the same version. This is a potentially disastrous action. Not only
will /boot/vmlinuz-2.6.8-2-686 be removed, making it impossible to boot
it, (you will have to take action to change your boot loader to boot
a new kernel), it will also remove all modules under the directory
/lib/modules/2.6.8-2-686. Just having a copy of the kernel image is not
enough, you will have to replace the modules too.
I repeat, this is very dangerous. If at all in doubt, answer
no. If you know exactly what you are doing, and are prepared to
hose your system, then answer Yes.
Remove the running kernel image (not recommended) [No]?
dpkg: error processing kernel-image-2.6.8-2-686 (–remove):
subprocess pre-removal script returned error exit status 1
Errors were encountered while processing:
- quand je fais : ls /boot ,j’ai ça:
System.map-2.6.8-2-686 grub lost+found
config-2.6.8-2-686 initrd.img-2.6.8-2-686 vmlinuz-2.6.8-2-686
quelqu’un peut 'il m’aider?
mail,web,et le monitoring ne fonctionnent plus!
