j’ai installer linux ubuntu , et voici mon probleme quand je fait un apt-get
insserv: loop involving service hwclockfirst at depth 3
insserv: loop involving service hostname at depth 4
insserv: loop involving service kbd at depth 12
insserv: There is a loop between service rc.local and ifupdown if started
insserv: loop involving service ifupdown at depth 7
insserv: loop involving service ifupdown-clean at depth 6
insserv: There is a loop between service rc.local and mountoverflowtmp if started
insserv: loop involving service mountoverflowtmp at depth 9
insserv: loop involving service mountall-bootclean at depth 8
insserv: There is a loop between service FOGImageReplicator and checkfs if started
insserv: loop involving service checkfs at depth 6
insserv: loop involving service mountall at depth 8
insserv: loop involving service mtab at depth 6
insserv: There is a loop at service FOGImageReplicator if started
insserv: There is a loop between service FOGImageReplicator and ifupdown-clean if started
insserv: There is a loop between service FOGImageReplicator and udev if started
insserv: loop involving service udev at depth 2
insserv: loop involving service mountkernfs at depth 1
insserv: loop involving service networking at depth 12
insserv: There is a loop between service rc.local and mountall if started
insserv: loop involving service FOGImageReplicator at depth 1
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg : erreur de traitement de exim4-base (--configure) :
le sous-processus script post-installation installé a retourné une erreur de sortie d'état 1
dpkg : des problèmes de dépendances empêchent la configuration de exim4-daemon-light :
exim4-daemon-light dépend de exim4-base (>= 4.72) ; cependant :
Le paquet exim4-base n'est pas encore configuré.
dpkg : erreur de traitement de exim4-daemon-light (--configure) :
problèmes de dépendances - laissé non configuré
configured to not write apport reports
exim4-base
exim4-daemon-light
root@Web-Server:~#
Le paquet exim4-base n’est pas encore configuré.
dpkg : erreur de traitement de exim4-daemon-light (–configure) :
exim4-base
exim4-daemon-light
je ne comprend pas , pouvez vous m’aider SVP ?
