merci ^^
[quote]DELL    DV051   0x00000007 ASL  0x00000061) @ 0x000fcd91
ACPI: MCFG (v001 DELL    DV051   0x00000007 ASL  0x00000061) @ 0x000fcdb9
ACPI: HPET (v001 DELL    DV051   0x00000007 ASL  0x00000061) @ 0x000fcdf7
ACPI: DSDT (v001   DELL    dt_ex 0x00001000 MSFT 0x0100000d) @ 0x00000000
ACPI: PM-Timer IO Port: 0x808
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Processor #0 15:4 APIC version 20
ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
Processor #1 15:4 APIC version 20
WARNING: NR_CPUS limit of 1 reached.  Processor ignored.
ACPI: LAPIC (acpi_id[0x03] lapic_id[0x06] disabled)
ACPI: LAPIC (acpi_id[0x04] lapic_id[0x07] disabled)
ACPI: LAPIC (acpi_id[0x05] lapic_id[0x06] disabled)
ACPI: LAPIC (acpi_id[0x06] lapic_id[0x07] disabled)
ACPI: LAPIC (acpi_id[0x07] lapic_id[0x00] disabled)
ACPI: LAPIC (acpi_id[0x08] lapic_id[0x01] disabled)
ACPI: LAPIC_NMI (acpi_id[0xff] high level lint[0x1])
ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode:  Flat.  Using 1 I/O APICs
ACPI: HPET id: 0x8086a201 base: 0xfed00000
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 50000000 (gap: 40000000:a0000000)
Built 1 zonelists
Kernel command line: root=/dev/sda6 ro iommu=memaper=3
mapped APIC to ffffd000 (fee00000)
mapped IOAPIC to ffffc000 (fec00000)
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 65536 bytes)
Console: colour VGA+ 80x25
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 1021488k/1038880k available (1425k kernel code, 16596k reserved, 530k data, 144k init, 121376k highmem)
Checking if this processor honours the WP bit even in supervisor mode… Ok.
hpet0: at MMIO 0xfed00000 (virtual 0xf8800000), IRQs 2, 8, 0
hpet0: 3 64-bit timers, 14318180 Hz
Using HPET for base-timer
Using HPET for gettimeofday
Detected 3192.425 MHz processor.
Using hpet for high-res timesource
Calibrating delay using timer specific routine… 6388.07 BogoMIPS (lpj=3194035)
Security Framework v1.0.0 initialized
SELinux:  Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: bfebfbff 20100000 00000000 00000000 0000649d 00000000 00000000
CPU: After vendor identify, caps: bfebfbff 20100000 00000000 00000000 0000649d 00000000 00000000
monitor/mwait feature present.
using mwait in idle threads.
CPU: Trace cache: 12K uops, L1 D cache: 16K
CPU: L2 cache: 2048K
CPU: After all inits, caps: bfebfbff 20100000 00000000 00000080 0000649d 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU0: Intel P4/Xeon Extended MCE MSRs (24) available
CPU0: Thermal monitoring enabled
mtrr: v2.0 (20020519)
CPU: Intel® Pentium® 4 CPU 3.20GHz stepping 03
Enabling fast FPU save and restore… done.
Enabling unmasked SIMD FPU exception support… done.
Checking ‘hlt’ instruction… OK.
ENABLING IO-APIC IRQs
…TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
checking if image is initramfs… it is
Freeing initrd memory: 5247k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xfb326, last bus=3
PCI: Using MMCONFIG
ACPI: Subsystem revision 20050902
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
ACPI: Assume root bridge [_SB_.PCI0] bus is 0
Boot video device is 0000:00:02.0
PCI: Ignoring BAR0-3 of IDE controller 0000:00:1f.1
PCI: Transparent bridge - 0000:00:1e.0
ACPI: PCI Interrupt Routing Table [_SB_.PCI0.PRT]
ACPI: PCI Interrupt Routing Table [_SB.PCI0.PCI1.PRT]
ACPI: PCI Interrupt Routing Table [_SB.PCI0.PCI2.PRT]
ACPI: PCI Interrupt Routing Table [_SB.PCI0.PCI3._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 *10 11 12 15)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 *4 5 6 7 9 10 11 12 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 *10 11 12 15)
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 *9 10 11 12 15)
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 9 10 11 12 15)
ACPI: PCI Interrupt Link [LNKH] (IRQs *3 4 5 6 7 9 10 11 12 15)
Linux Plug and Play Support v0.97 © Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 7 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn’t work, try “pci=routeirq”.  If it helps, post a report
pnp: 00:00: ioport range 0x800-0x85f could not be reserved
pnp: 00:00: ioport range 0xc00-0xc7f has been reserved
pnp: 00:00: ioport range 0x860-0x8ff has been reserved
pnp: 00:06: ioport range 0x100-0x1fe has been reserved
pnp: 00:06: ioport range 0x200-0x277 has been reserved
pnp: 00:06: ioport range 0x280-0x2e7 has been reserved
pnp: 00:06: ioport range 0x2e8-0x2ef has been reserved
pnp: 00:06: ioport range 0x2f0-0x2f7 has been reserved
pnp: 00:06: ioport range 0x2f8-0x2ff has been reserved
pnp: 00:06: ioport range 0x300-0x377 has been reserved
pnp: 00:06: ioport range 0x380-0x3bb has been reserved
PCI: Ignore bogus resource 6 [0:0] of 0000:00:02.0
PCI: Bridge: 0000:00:1c.0
IO window: disabled.
MEM window: dfe00000-dfefffff
PREFETCH window: disabled.
PCI: Bridge: 0000:00:1c.1
MEM window: dfd00000-dfdfffff
PCI: Bridge: 0000:00:1e.0
IO window: d000-dfff
MEM window: dfc00000-dfcfffff
ACPI: PCI Interrupt 0000:00:1c.0[A] -> GSI 16 (level, low) -> IRQ 169
PCI: Setting latency timer of device 0000:00:1c.0 to 64
ACPI: PCI Interrupt 0000:00:1c.1[B] -> GSI 17 (level, low) -> IRQ 177
PCI: Setting latency timer of device 0000:00:1c.1 to 64
PCI: Setting latency timer of device 0000:00:1e.0 to 64
Simple Boot Flag at 0x7a set to 0x1
audit: initializing netlink socket (disabled)
audit(1145974696.624:1): initialized
highmem bounce pool size: 64 pages
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
assign_interrupt_mode Found MSI capability
Allocate Port Service[pcie00]
Allocate Port Service[pcie02]
Allocate Port Service[pcie03]
isapnp: Scanning for PnP cards…
isapnp: No Plug & Play device found
PNP: No PS/2 controller found. Probing ports directly.
i8042.c: Can’t read CTR while initializing i8042.
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
ACPI: PCI Interrupt 0000:03:02.0[A] -> GSI 18 (level, low) -> IRQ 209
0000:03:02.0: ttyS0 at I/O 0xdc08 (irq = 209) is a 16450
0000:03:02.0: ttyS1 at I/O 0xdc10 (irq = 209) is a 8250
0000:03:02.0: ttyS2 at I/O 0xdc18 (irq = 209) is a 16450
0000:03:02.0: ttyS3 at I/O 0xdc20 (irq = 209) is a 8250
Couldn’t register serial port 0000:03:02.0: -28
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 7, 524288 bytes)
TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Using IPI Shortcut mode
ACPI wakeup devices:
VBTN PCI0 PCI1 PCI2 PCI3 PCI4 USB0 USB1 USB2 USB3
ACPI: (supports S0 S1 S3 S4 S5)
Freeing unused kernel memory: 144k freed
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v2.3
ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 21 (level, low) -> IRQ 217
PCI: Setting latency timer of device 0000:00:1d.0 to 64
uhci_hcd 0000:00:1d.0: UHCI Host Controller
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:1d.0: irq 217, io base 0x0000ff80
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1d.1[B] -> GSI 22 (level, low) -> IRQ 225
PCI: Setting latency timer of device 0000:00:1d.1 to 64
uhci_hcd 0000:00:1d.1: UHCI Host Controller
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:1d.1: irq 225, io base 0x0000ff60
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
e100: Intel® PRO/100 Network Driver, 3.4.14-k4-NAPI
e100: Copyright© 1999-2005 Intel Corporation
ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 209
PCI: Setting latency timer of device 0000:00:1d.2 to 64
uhci_hcd 0000:00:1d.2: UHCI Host Controller
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:1d.2: irq 209, io base 0x0000ff40
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1d.3[D] -> GSI 23 (level, low) -> IRQ 233
PCI: Setting latency timer of device 0000:00:1d.3 to 64
uhci_hcd 0000:00:1d.3: UHCI Host Controller
uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 4
uhci_hcd 0000:00:1d.3: irq 233, io base 0x0000ff20
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
SCSI subsystem initialized
libata version 1.20 loaded.
ahci 0000:00:1f.2: version 1.2
ACPI: PCI Interrupt 0000:00:1f.2[C] -> GSI 20 (level, low) -> IRQ 50
usb 2-1: new low speed USB device using uhci_hcd and address 2
ICH6: IDE controller at PCI slot 0000:00:1f.1
ACPI: PCI Interrupt 0000:00:1f.1[A] -> GSI 16 (level, low) -> IRQ 169
ICH6: chipset revision 4
ICH6: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0xffa0-0xffa7, BIOS settings: hda:DMA, hdb:pio
Probing IDE interface ide0…
ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 21 (level, low) -> IRQ 217
PCI: Setting latency timer of device 0000:00:1d.7 to 64
ehci_hcd 0000:00:1d.7: EHCI Host Controller
ehci_hcd 0000:00:1d.7: debug port 1
PCI: cache line size of 128 is not supported by device 0000:00:1d.7
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 5
ehci_hcd 0000:00:1d.7: irq 217, io mem 0xffa80800
ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 8 ports detected
usb 2-1: USB disconnect, address 2
hda: _NEC DVD+/-RW ND-3530A, ATAPI CD/DVD-ROM drive
usbcore: registered new driver hiddev
usb 2-1: new low speed USB device using uhci_hcd and address 4
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
usb 2-2: new low speed USB device using uhci_hcd and address 5
input: Logitech Optical USB Mouse as /class/input/input0
input: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-0000:00:1d.1-1
input: Dell Dell USB Keyboard as /class/input/input1
input: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-0000:00:1d.1-2
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
PCI: Setting latency timer of device 0000:00:1f.2 to 64
ahci 0000:00:1f.2: AHCI 0001.0000 32 slots 4 ports 1.5 Gbps 0xf impl IDE mode
ahci 0000:00:1f.2: flags: 64bit ncq pm led slum part
ata1: SATA max UDMA/133 cmd 0xF883CD00 ctl 0x0 bmdma 0x0 irq 50
ata2: SATA max UDMA/133 cmd 0xF883CD80 ctl 0x0 bmdma 0x0 irq 50
ata3: SATA max UDMA/133 cmd 0xF883CE00 ctl 0x0 bmdma 0x0 irq 50
ata4: SATA max UDMA/133 cmd 0xF883CE80 ctl 0x0 bmdma 0x0 irq 50
ata1: dev 0 cfg 49:2f00 82:346b 83:7701 84:4003 85:3469 86:3401 87:4003 88:207f
ata1: dev 0 ATA-7, max UDMA/133, 312500000 sectors: LBA48
ata1: dev 0 configured for UDMA/133
scsi0 : ahci
ata2: no device found (phy stat 00000000)
scsi1 : ahci
ata3: no device found (phy stat 00000000)
scsi2 : ahci
ata4: no device found (phy stat 00000000)
scsi3 : ahci
Vendor: ATA       Model: ST3160828AS       Rev: 8.03
Type:   Direct-Access                      ANSI SCSI revision: 05
ACPI: PCI Interrupt 0000:03:08.0[A] -> GSI 20 (level, low) -> IRQ 50
e100: eth0: e100_probe: addr 0xdfcff000, irq 50, MAC addr 00:13:20:BE:67:E9
SCSI device sda: 312500000 512-byte hdwr sectors (160000 MB)
SCSI device sda: drive cache: write back
sda: sda1 sda2 sda3 sda4 < sda5 sda6 sda7 sda8 >
sd 0:0:0:0: Attached scsi disk sda
kjournald starting.  Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
mice: PS/2 mouse device common for all mice
hw_random: RNG not detected
input: PC Speaker as /class/input/input2
hda: ATAPI 48X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
Linux agpgart interface v0.101 © Dave Jones
agpgart: Detected an Intel 915G Chipset.
agpgart: Detected 7932K stolen memory.
agpgart: AGP aperture is 256M @ 0xc0000000
ACPI: PCI Interrupt 0000:00:1b.0[A] -> GSI 16 (level, low) -> IRQ 169
PCI: Setting latency timer of device 0000:00:1b.0 to 64
Real Time Clock Driver v1.12
Zapata Telephony Interface Registered on major 196
Zaptel Version: 1.2.4 Echo Canceller: KB1
ACPI: PCI Interrupt 0000:03:01.0[A] -> GSI 17 (level, low) -> IRQ 177
Freshmaker version: 73
Freshmaker passed register test
Module 0: Not installed
Module 1: Not installed
ProSLIC on module 2 failed to powerup within 501 ms (0 mV only)
– DID YOU REMEMBER TO PLUG IN THE HD POWER CABLE TO THE TDM400P??
Unable to do INITIAL ProSLIC powerup on module 2
Module 2: FAILED FXS (FCC)
Module 3: Installed – AUTO FXO (FCC mode)
Found a Wildcard TDM: Wildcard TDM400P REV I (1 modules)
CSLIP: code copyright 1989 Regents of the University of California
ISDN subsystem Rev: 1.1.2.3/1.1.2.3/1.1.2.2/1.1.2.3/1.1.2.2/1.1.2.2 loaded
HiSax: Linux Driver for passive ISDN cards
HiSax: Version 3.5 (module)
HiSax: Layer1 Revision 2.46.2.5
HiSax: Layer2 Revision 2.30.2.4
HiSax: TeiMgr Revision 2.20.2.3
HiSax: Layer3 Revision 2.22.2.3
HiSax: LinkLayer Revision 2.59.2.4
Adding 3903752k swap on /dev/sda5.  Priority:-1 extents:1 across:3903752k
EXT3 FS on sda6, internal journal
EXT3 FS on sda7, internal journal
EXT3 FS on sda8, internal journal
NTFS driver 2.1.25 [Flags: R/W MODULE].
NTFS volume version 3.1.
e100: eth0: e100_watchdog: link up, 100Mbps, full-duplex
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver[/quote]
j’ai remarqué que j’avais plusieur fichiers dmesg dans ce dossier, c’est normal ?
[quote]$ ls /var/log/dmesg*
/var/log/dmesg    /var/log/dmesg.1.gz  /var/log/dmesg.3.gz
/var/log/dmesg.0  /var/log/dmesg.2.gz  /var/log/dmesg.4.gz[/quote]
