[size=150]bonsoir a tous, voila mon problème, quand j’allume mon PC l’écran affiche ça:
[/size]
Early console in decompress_kernel
Decompressing Linux. . . Parsing ELF. . . No relocation needed. . . done.
Booting the kernel.
loading, please wait. . .
Volume group “yoo-debian-vg” not found
Skipping volume group yoo-debian-vg
Unable to find LVM volume yoo-debian-vg/root
Volum group “yoo-debian-vg” not found
skipping volume group yoo-debian-vg
Unable to find LVM volume yoo-debian-vg/swap_1
Please unlock disk sda5_crypt:
[size=150]et la quant je tape le mot de passe sa fait :[/size]
Please unlock disk sda5_crypt: Reading all physical volumes. This may take a while. . .
Found volume group “yoo-debian-vg” using metadata type lvm2
3 logical volume(s) in volume group “yoo-debian-vg” now active
cryptsetup: sda5_crypt set un successfully
Target filesystem doesn’t have requested /sbin/ini.
/bin/sh: 0: can’t access tty: job control turned off
[size=150]je crois que c’est linux debian jessie 3.14-1-686
GNU GRUB 2.00-22[/size]
[size=150]Merci pour votre aide…;[/size]
