C’est le grub.cfg
Je le poste et je tente le update.
A+ et encore merci.
[quote]#
DO NOT EDIT THIS FILE
It is automatically generated by /usr/sbin/grub-mkconfig using templates
from /etc/grub.d and settings from /etc/default/grub
BEGIN /etc/grub.d/00_header
set default=0
insmod ext2
set root=(hd1,2)
search --no-floppy --fs-uuid --set c1484f83-99e1-4dcd-9ead-2cb89ca3fee6
if loadfont /usr/share/grub/unicode.pf2 ; then
set gfxmode=640x480
insmod gfxterm
insmod vbe
if terminal_output gfxterm ; then true ; else
# For backward compatibility with versions of terminal.mod that don’t
# understand terminal_output
terminal gfxterm
fi
fi
set timeout=5
END /etc/grub.d/00_header
BEGIN /etc/grub.d/05_debian_theme
insmod ext2
set root=(hd1,2)
insmod png
if background_image /boot/grub/moreblue-orbit-grub.png ; then
set color_normal=black/black
set color_highlight=magenta/black
else
set menu_color_normal=cyan/blue
set menu_color_highlight=white/blue
fi
END /etc/grub.d/05_debian_theme
BEGIN /etc/grub.d/10_linux
menuentry “Debian GNU/Linux, Linux 2.6.30-2-686” {
insmod ext2
set root=(hd1,2)
linux /boot/vmlinuz-2.6.30-2-686 root=UUID=c1484f83-99e1-4dcd-9ead-2cb89ca3fee6 ro quiet
initrd /boot/initrd.img-2.6.30-2-686
menuentry “Debian GNU/Linux, Linux 2.6.30-2-686 (recovery mode)” {
insmod ext2
set root=(hd1,2)
linux /boot/vmlinuz-2.6.30-2-686 root=UUID=c1484f83-99e1-4dcd-9ead-2cb89ca3fee6 ro single
menuentry “Debian GNU/Linux, Linux 2.6.30-1-686” {
insmod ext2
set root=(hd1,2)
linux /boot/vmlinuz-2.6.30-1-686 root=UUID=c1484f83-99e1-4dcd-9ead-2cb89ca3fee6 ro quiet
initrd /boot/initrd.img-2.6.30-1-686
menuentry “Debian GNU/Linux, Linux 2.6.30-1-686 (recovery mode)” {
insmod ext2
set root=(hd1,2)
linux /boot/vmlinuz-2.6.30-1-686 root=UUID=c1484f83-99e1-4dcd-9ead-2cb89ca3fee6 ro single
menuentry “Debian GNU/Linux, Linux 2.6.26-2-686” {
insmod ext2
set root=(hd1,2)
linux /boot/vmlinuz-2.6.26-2-686 root=UUID=c1484f83-99e1-4dcd-9ead-2cb89ca3fee6 ro quiet
initrd /boot/initrd.img-2.6.26-2-686
menuentry “Debian GNU/Linux, Linux 2.6.26-2-686 (recovery mode)” {
insmod ext2
set root=(hd1,2)
linux /boot/vmlinuz-2.6.26-2-686 root=UUID=c1484f83-99e1-4dcd-9ead-2cb89ca3fee6 ro single
END /etc/grub.d/10_linux
BEGIN /etc/grub.d/30_os-prober
END /etc/grub.d/30_os-prober
BEGIN /etc/grub.d/40_custom
This file provides an easy way to add custom menu entries. Simply type the
menu entries you want to add after this comment. Be careful not to change
insmod ext2
set root=(hd1,2)
insmod ext2
set root=(hd1,2)
insmod ext2
set root=(hd1,2)
insmod ext2
set root=(hd1,2)
insmod ext2
set root=(hd1,2)
insmod ext2
set root=(hd1,2)
insmod ext2
set root=(hd1,2)
insmod ext2
set root=(hd1,2)
insmod ext2
set root=(hd1,2)
insmod ext2
set root=(hd1,2)
the ‘exec tail’ line above.
END /etc/grub.d/40_custom ###[/quote]
