Mon cas est similaire à celui-ci http://forum.ubuntu-fr.org/viewtopic.php?id=1251611
j’ai donc suivi ce qu’il a fait: lancer audacity dans une console, voici les messages que j’obtiens
[quote]ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm_dmix.c:957:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
Expression ‘ret’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 1670
Expression ‘AlsaOpen( &alsaApi->baseHostApiRep, params, streamDir, &self->pcm )’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 1830
Expression ‘PaAlsaStreamComponent_Initialize( &self->capture, alsaApi, inParams, StreamDirection_In, NULL != callback )’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 2092
Expression ‘PaAlsaStream_Initialize( stream, alsaHostApi, inputParameters, outputParameters, sampleRate, framesPerBuffer, callback, streamFlags, userData )’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 2764
Expression ‘stream->playback.pcm’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 4541
ALSA lib pcm_dsnoop.c:612:(snd_pcm_dsnoop_open) unable to open slave
Expression ‘stream->playback.pcm’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 4541[/quote]
Audacity se lance malge ces messages, mais le systeme se bloque rapidemment.
autre chose, parmi les messages lors du boot se trouve un Warning
