voici pour le main.cf
[code]smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
append_dot_mydomain = no
myhostname = mail.smatrixium.be
alias_maps = hash:/etc/aliases
alias_database = hash:/etc/aliases
myorigin = /etc/mailname
mydestination = localhost.localdomain
relayhost =
mynetworks = 127.0.0.0/8, 10.0.0.0/24
mailbox_command = procmail -a "$EXTENSION"
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
virtual_alias_domains =
virtual_alias_maps = mysql:/etc/postfix/mysql-virtual_forwardings.cf mysql:/etc/postfix/mysql-virtual_email2email.cf
virtual_mailbox_domains = mysql:/etc/postfix/mysql-virtual_domains.cf
virtual_mailbox_maps = mysql:/etc/postfix/mysql-virtual_mailboxes.cf
virtual_mailbox_base = /
virtual_maildir_limit_message = Sorry, the user’s maildir has overdrawn his diskspace quota, please try again later
virtual_mailbox_extended = yes
virtual_mailbox_limit_override = yes
virtual_mailbox_overquota_bounce = yes
virtual_uid_maps = static:1001
virtual_gid_maps = static:1001
smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination ,reject_rbl_client sbl-xbl.spamhaus.org
content_filter = smtp-amavis:[127.0.0.1]:10024
receive_override_options = no_address_mappings
home_mailbox = Mail/
broken_sasl_auth_clients = yes
smtpd_sasl_auth_enable = yes
smtpd_sasl_local_domain =
smtpd_sender_restrictions = permit_sasl_authenticated, permit_mynetworks
smtp_use_tls = yes
smtpd_use_tls = yes
smtp_tls_note_starttls_offer = yes
smtpd_tls_key_file = /etc/postfix/ssl/smtpd.pem
smtpd_tls_cert_file = /etc/postfix/ssl/smtpd.pem
smtpd_tls_CAfile = /etc/postfix/ssl/smtpd.pem
smtpd_tls_loglevel = 1
smtpd_tls_received_header = yes
smtpd_tls_session_cache_timeout = 3600s
tls_random_source = dev:/dev/urandom
smtpd_helo_required = yes
smtpd_helo_restrictions = reject_non_fqdn_hostname
pour le master.cf
[code]smtp inet n - n - - smtpd
-o cleanup_service_name=pre-cleanup
pickup fifo n - - 60 1 pickup
cleanup unix n - - - 0 cleanup
qmgr fifo n - - 300 1 qmgr
rewrite unix - - - - - trivial-rewrite
bounce unix - - - - 0 bounce
defer unix - - - - 0 bounce
trace unix - - - - 0 bounce
verify unix - - - - 1 verify
flush unix n - - 1000? 0 flush
proxymap unix - - n - - proxymap
smtp unix - - - - - smtp
relay unix - - - - - smtp
showq unix n - - - - showq
error unix - - - - - error
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - n - - lmtp
anvil unix - - n - 1 anvil
maildrop unix - n n - - pipe
flags=DRhu user=vmail argv=/usr/local/bin/maildrop -d ${recipient}
uucp unix - n n - - pipe
flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
ifmail unix - n n - - pipe
flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp unix - n n - - pipe
flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -d -t$nexthop -f$sender $recipient
scalemail-backend unix - n n - 2 pipe
flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
smtps inet n - n - - smtpd -o smtpd_tls_wrappermode=yes -o smtpd_sasl_auth_enable=yes
587 inet n - n - - smtpd -o smtpd_enforce_tls=yes -o smtpd_sasl_auth_enable=yes
pre-cleanup unix n - - - 0 cleanup
-o virtual_alias_maps=
-o canonical_maps=
-o sender_canonical_maps=
-o recipient_canonical_maps=
-o masquerade_domains=
smtp-amavis unix - - - - 2 lmtp
-o smtp_data_done_timeout=1200
-o lmtp_send_xforward_command=yes
-o disable_dns_lookups=yes
127.0.0.1:10025 inet n - - - - smtpd
-o content_filter=
-o local_recipient=
-o relay_recipient_maps=
-o smtpd_restriction_classes=
-o smtpd_client_restrictions=
-o smtpd_helo_restrictions=
-o smtpd_sender_restrictions=
-o smtpd_recipient_restrictions=permit_mynetworks,reject
-o mynetworks=127.0.0.0/8
-o strict_rfc821_envelopes=yes
-o receive_override_options=no_unknown_recipient_checks,no_header_body_checks
