J’ai un serveur Debian lenny 5 installé avec postfix, pop, imap, authdeamon…
Le coté POP marche nickel, j’arrive bien a m’authentifier sur le serveur en pop, lire les mail…
Actuellement je cherche a mettre en place roundcube qui lui fonctionne que sous IMAP…
sous imap j’ai quelques soucis d’authetifications…
J’ai activé le mode debugage de authdeamon pour savoir ce qui se passe… (pas d’erreurs visible) méme si je me fais refoullé par roundcube ainsi que les clients de messagerie classique.
Resultat des logs:
Jul 21 12:03:49 ks308711 imapd: Connection, ip=[::ffff:93.23.239.100]
Jul 21 12:03:49 ks308711 authdaemond: received auth request, service=imap, authtype=login
Jul 21 12:03:49 ks308711 authdaemond: authpam: trying this module
Jul 21 12:03:49 ks308711 authdaemond: authpam: sysusername=informaticien, sysuserid=<null>, sysgroupid=100, homedir=/home/informaticien, address=informaticien, fullname=, maildir=<null>, quota=<null>, options=<null>
Jul 21 12:03:49 ks308711 authdaemond: authpam: clearpasswd=<null>, passwd=x
Jul 21 12:03:49 ks308711 authdaemond: pam_service=imap, pam_username=informaticien
Jul 21 12:03:49 ks308711 authdaemond: dopam successful
Jul 21 12:03:49 ks308711 authdaemond: Authenticated: sysusername=informaticien, sysuserid=<null>, sysgroupid=100, homedir=/home/informaticien, address=informaticien, fullname=, maildir=<null>, quota=<null>, options=<null>
Jul 21 12:03:49 ks308711 authdaemond: Authenticated: clearpasswd=pass, passwd=$1$62692540$bJPzlM4HQB5f3WmYHJpjV/
Le contenu de mon authdaemonrd conf:
[code]##VERSION: $Id: authdaemonrc.in,v 1.13 2005/10/05 00:07:32 mrsam Exp $
Copyright 2000-2005 Double Precision, Inc. See COPYING for
distribution information.
authdaemonrc created from authdaemonrc.dist by sysconftool
Do not alter lines that begin with ##, they are used when upgrading
this configuration.
This file configures authdaemond, the resident authentication daemon.
Comments in this file are ignored. Although this file is intended to
be sourced as a shell script, authdaemond parses it manually, so
the acceptable syntax is a bit limited. Multiline variable contents,
with the \ continuation character, are not allowed. Everything must
fit on one line. Do not use any additional whitespace for indentation,
or anything else.
##NAME: authmodulelist:2
The authentication modules that are linked into authdaemond. The
default list is installed. You may selectively disable modules simply
by removing them from the following list. The available modules you
can use are: authuserdb authpam authpgsql authldap authmysql authcustom authpipe
authmodulelist=“authpam”
##NAME: authmodulelistorig:3
This setting is used by Courier’s webadmin module, and should be left
alone
authmodulelistorig=“authuserdb authpam authpgsql authldap authmysql authcustom authpipe”
##NAME: daemons:0
The number of daemon processes that are started. authdaemon is typically
installed where authentication modules are relatively expensive: such
as authldap, or authmysql, so it’s better to have a number of them running.
PLEASE NOTE: Some platforms may experience a problem if there’s more than
one daemon. Specifically, SystemV derived platforms that use TLI with
socket emulation. I’m suspicious of TLI’s ability to handle multiple
processes accepting connections on the same filesystem domain socket.
You may need to increase daemons if as your system load increases. Symptoms
include sporadic authentication failures. If you start getting
authentication failures, increase daemons. However, the default of 5
SHOULD be sufficient. Bumping up daemon count is only a short-term
solution. The permanent solution is to add more resources: RAM, faster
disks, faster CPUs…
daemons=5
##NAME: authdaemonvar:2
authdaemonvar is here, but is not used directly by authdaemond. It’s
used by various configuration and build scripts, so don’t touch it!
authdaemonvar=/var/run/courier/authdaemon
##NAME: DEBUG_LOGIN:0
Dump additional diagnostics to syslog
DEBUG_LOGIN=0 - turn off debugging
DEBUG_LOGIN=1 - turn on debugging
DEBUG_LOGIN=2 - turn on debugging + log passwords too
** YES ** - DEBUG_LOGIN=2 places passwords into syslog.
Note that most information is sent to syslog at level ‘debug’, so
you may need to modify your /etc/syslog.conf to be able to see it.
DEBUG_LOGIN=2
##NAME: DEFAULTOPTIONS:0
A comma-separated list of option=value pairs. Each option is applied
to an account if the account does not have its own specific value for
that option. So for example, you can set
DEFAULTOPTIONS=“disablewebmail=1,disableimap=1”
and then enable webmail and/or imap on individual accounts by setting
disablewebmail=0 and/or disableimap=0 on the account.
DEFAULTOPTIONS=""
##NAME: LOGGEROPTS:0
courierlogger(1) options, e.g. to set syslog facility
LOGGEROPTS=""
##NAME: LDAP_TLS_OPTIONS:0
Options documented in ldap.conf(5) can be set here, prefixed with ‘LDAP’.
Examples:
#LDAPTLS_CACERT=/path/to/cacert.pem
#LDAPTLS_REQCERT=demand
#LDAPTLS_CERT=/path/to/clientcert.pem
#LDAPTLS_KEY=/path/to/clientkey.pem[/code]
Le contenu de mon imapd:
[code]##VERSION: $Id: imapd.dist.in,v 1.41 2008/06/21 16:01:23 mrsam Exp $
imapd created from imapd.dist by sysconftool
this configuration.
Copyright 1998 - 2008 Double Precision, Inc. See COPYING for
This configuration file sets various options for the Courier-IMAP server
when used with the couriertcpd server.
A lot of the stuff here is documented in the manual page for couriertcpd.
NOTE - do not use \ to split long variable contents on multiple lines.
This will break the default imapd.rc script, which parses this file.
##NAME: ADDRESS:0
Address to listen on, can be set to a single IP address.
ADDRESS=127.0.0.1
ADDRESS=0
##NAME: PORT:1
Port numbers that connections are accepted on. The default is 143,
the standard IMAP port.
Multiple port numbers can be separated by commas. When multiple port
numbers are used it is possible to select a specific IP address for a
given port as “ip.port”. For example, “127.0.0.1.900,192.68.0.1.900”
accepts connections on port 900 on IP addresses 127.0.0.1 and 192.68.0.1
The previous ADDRESS setting is a default for ports that do not have
a specified IP address.
PORT=143
##NAME: AUTHSERVICE:0
It’s possible to authenticate using a different ‘service’ parameter
depending on the connection’s port. This only works with authentication
modules that use the ‘service’ parameter, such as PAM. Example:
AUTHSERVICE143=imap
AUTHSERVICE993=imaps
##NAME: MAXDAEMONS:0
Maximum number of IMAP servers started
MAXDAEMONS=40
##NAME: MAXPERIP:0
Maximum number of connections to accept from the same IP address
MAXPERIP=20
##NAME: PIDFILE:0
File where couriertcpd will save its process ID
PIDFILE=/var/run/courier/imapd.pid
##NAME: TCPDOPTS:0
Miscellaneous couriertcpd options that shouldn’t be changed.
TCPDOPTS="-nodnslookup -noidentlookup"
courierlogger(1) options.
LOGGEROPTS="-name=imapd"
##NAME: DEFDOMAIN:0
Optional default domain. If the username does not contain the
first character of DEFDOMAIN, then it is appended to the username.
If DEFDOMAIN and DOMAINSEP are both set, then DEFDOMAIN is appended
only if the username does not contain any character from DOMAINSEP.
You can set different default domains based on the the interface IP
address using the -access and -accesslocal options of couriertcpd(1).
DEFDOMAIN="@domaine.com"
##NAME: IMAP_CAPABILITY:1
IMAP_CAPABILITY specifies what most of the response should be to the
CAPABILITY command.
If you have properly configured Courier to use CRAM-MD5, CRAM-SHA1, or
CRAM-SHA256 authentication (see INSTALL), set IMAP_CAPABILITY as follows:
IMAP_CAPABILITY=“IMAP4rev1 UIDPLUS CHILDREN NAMESPACE THREAD=ORDEREDSUBJECT THREAD=REFERENCES SORT QUOTA AUTH=CRAM-MD5 AUTH=CRAM-SHA1 AUTH=CRAM-SHA256 IDLE”
IMAP_CAPABILITY=“IMAP4rev1 UIDPLUS CHILDREN NAMESPACE THREAD=ORDEREDSUBJECT THREAD=REFERENCES SORT QUOTA IDLE”
##NAME: KEYWORDS_CAPABILITY:0
IMAP_KEYWORDS=1 enables custom IMAP keywords. Set this option to 0 to
disable custom keywords.
IMAP_KEYWORDS=2 also enables custom IMAP keywords, but uses a slower
algorithm. Use this setting if keyword-related problems occur when
multiple IMAP clients are updating keywords on the same message.
IMAP_KEYWORDS=1
##NAME: ACL_CAPABILITY:0
IMAP_ACL=1 enables IMAP ACL extension. Set this option to 0 to
disable ACL capabilities announce.
IMAP_ACL=1
##NAME: SMAP1_CAPABILITY:0
EXPERIMENTAL
To enable the experimental “Simple Mail Access Protocol” extensions,
uncomment the following setting.
SMAP_CAPABILITY=SMAP1
##NAME: IMAP_CAPABILITY_ORIG:2
For use by webadmin
IMAP_CAPABILITY_ORIG=“IMAP4rev1 UIDPLUS CHILDREN NAMESPACE THREAD=ORDEREDSUBJECT THREAD=REFERENCES SORT QUOTA AUTH=CRAM-MD5 AUTH=CRAM-SHA1 AUTH=CRAM-SHA256 IDLE”
##NAME: IMAP_PROXY:0
Enable proxying. See README.proxy
IMAP_PROXY=0
##NAME: PROXY_HOSTNAME:0
Override value from gethostname() when checking if a proxy connection is
required.
PROXY_HOSTNAME=
##NAME: IMAP_PROXY_FOREIGN:0
Proxying to non-Courier servers. Re-sends the CAPABILITY command after
logging in to the remote server. May not work with all IMAP clients.
IMAP_PROXY_FOREIGN=0
##NAME: IMAP_IDLE_TIMEOUT:0
This setting controls how often
the server polls for changes to the folder, in IDLE mode (in seconds).
IMAP_IDLE_TIMEOUT=60
##NAME: IMAP_MAILBOX_SANITY_CHECK:0
Sanity check – make sure home directory and maildir’s ownership matches
the IMAP server’s effective uid and gid
IMAP_MAILBOX_SANITY_CHECK=1
##NAME: IMAP_CAPABILITY_TLS:0
The following setting will advertise SASL PLAIN authentication after
STARTTLS is established. If you want to allow SASL PLAIN authentication
with or without TLS then just comment this out, and add AUTH=PLAIN to
IMAP_CAPABILITY
IMAP_CAPABILITY_TLS="$IMAP_CAPABILITY AUTH=PLAIN"
##NAME: IMAP_TLS_ORIG:0
For use by webadmin
IMAP_CAPABILITY_TLS_ORIG="$IMAP_CAPABILITY_ORIG AUTH=PLAIN"
##NAME: IMAP_DISABLETHREADSORT:0
Set IMAP_DISABLETHREADSORT to disable the THREAD and SORT commands -
server side sorting and threading.
Those capabilities will still be advertised, but the server will reject
them. Set this option if you want to disable all the extra load from
server-side threading and sorting. Not advertising those capabilities
will simply result in the clients reading the entire folder, and sorting
it on the client side. That will still put some load on the server.
advertising these capabilities, but rejecting the commands, will stop this
silliness.
IMAP_DISABLETHREADSORT=0
##NAME: IMAP_CHECK_ALL_FOLDERS:0
Set IMAP_CHECK_ALL_FOLDERS to 1 if you want the server to check for new
mail in every folder. Not all IMAP clients use the IMAP’s new mail
indicator, but some do. Normally new mail is checked only in INBOX,
because it is a comparatively time consuming operation, and it would be
a complete waste of time unless mail filters are used to deliver
mail directly to folders.
When IMAP clients are used which support new mail indication, and when
mail filters are used to sort incoming mail into folders, setting
IMAP_CHECK_ALL_FOLDERS to 1 will allow IMAP clients to announce new
mail in folders. Note that this will result in slightly more load on the
server.
IMAP_CHECK_ALL_FOLDERS=0
##NAME: IMAP_OBSOLETE_CLIENT:0
Set IMAP_OBSOLETE_CLIENT if your IMAP client expects \NoInferiors to mean
what \HasNoChildren really means.
IMAP_OBSOLETE_CLIENT=0
##NAME: IMAP_UMASK:0
IMAP_UMASK sets the umask of the server process. The value of IMAP_UMASK is
simply passed to the “umask” command. The default value is 022.
This feature is mostly useful for shared folders, where the file permissions
of the messages may be important.
IMAP_UMASK=022
##NAME: IMAP_ULIMITD:0
IMAP_ULIMITD sets the maximum size of the data segment of the server
process. The value of IMAP_ULIMITD is simply passed to the “ulimit -d”
command (or ulimit -v). The argument to ulimi sets the upper limit on the
size of the data segment of the server process, in kilobytes. The default
value of 65536 sets a very generous limit of 64 megabytes, which should
be more than plenty for anyone.
This feature is used as an additional safety check that should stop
any potential denial-of-service attacks that exploit any kind of
a memory leak to exhaust all the available memory on the server.
It is theoretically possible that obscenely huge folders will also
result in the server running out of memory when doing server-side
sorting (by my calculations you have to have at least 100,000 messages
in a single folder, for that to happen).
IMAP_ULIMITD=65536
##NAME: IMAP_USELOCKS:0
Setting IMAP_USELOCKS to 1 will use dot-locking to support concurrent
multiple access to the same folder. This incurs slight additional
overhead. Concurrent multiple access will still work without this setting,
however occasionally a minor race condition may result in an IMAP client
downloading the same message twice, or a keyword update will fail.
IMAP_USELOCKS=1 is strongly recommended when shared folders are used.
IMAP_USELOCKS=1
##NAME: IMAP_SHAREDINDEXFILE:0
The index of all accessible folders. Do not change this setting unless
you know what you’re doing. See README.sharedfolders for additional
information.
IMAP_SHAREDINDEXFILE=/etc/courier/shared/index
##NAME: IMAP_ENHANCEDIDLE:0
If Courier was compiled with the File Alteration Monitor, setting
IMAP_ENHANCEDIDLE to 1 enables enhanced IDLE mode, where multiple
clients may open the same folder concurrently, and receive updates to
folder contents in realtime. See the imapd(8) man page for additional
information.
IMPORTANT: IMAP_USELOCKS MUST also be set to 1, and IDLE must be included
in the IMAP_CAPABILITY list.
IMAP_ENHANCEDIDLE=0
##NAME: IMAP_TRASHFOLDERNAME:0
The name of the magic trash Folder. For MSOE compatibility,
you can set IMAP_TRASHFOLDERNAME=“Deleted Items”.
IMPORTANT: If you change this, you must also change IMAP_EMPTYTRASH
IMAP_TRASHFOLDERNAME=Trash
##NAME: IMAP_EMPTYTRASH:0
The following setting is optional, and causes messages from the given
folder to be automatically deleted after the given number of days.
IMAP_EMPTYTRASH is a comma-separated list of folder:days. The default
setting, below, purges 7 day old messages from the Trash folder.
Another useful setting would be:
IMAP_EMPTYTRASH=Trash:7,Sent:30
This would also delete messages from the Sent folder (presumably copies
of sent mail) after 30 days. This is a global setting that is applied to
every mail account, and is probably useful in a controlled, corporate
environment.
Important: the purging is controlled by CTIME, not MTIME (the file time
as shown by ls). It is perfectly ordinary to see stuff in Trash that’s
a year old. That’s the file modification time, MTIME, that’s displayed.
This is generally when the message was originally delivered to this
mailbox. Purging is controlled by a different timestamp, CTIME, which is
changed when the file is moved to the Trash folder (and at other times too).
You might want to disable this setting in certain situations - it results
in a stat() of every file in each folder, at login and logout.
##NAME: IMAP_MOVE_EXPUNGE_TO_TRASH:0
Set IMAP_MOVE_EXPUNGE_TO_TRASH to move expunged messages to Trash. This
effectively allows an undo of message deletion by fishing the deleted
mail from trash. Trash can be manually expunged as usually, and mail
will get automatically expunged from Trash according to IMAP_EMPTYTRASH.
NOTE: shared folders are still expunged as usual. Shared folders are
not affected.
IMAP_MOVE_EXPUNGE_TO_TRASH=0
##NAME: OUTBOX:0
The next set of options deal with the “Outbox” enhancement.
Uncomment the following setting to create a special folder, named
INBOX.Outbox
OUTBOX=.Outbox
##NAME: SENDMAIL:0
If OUTBOX is defined, mail can be sent via the IMAP connection by copying
a message to the INBOX.Outbox folder. For all practical matters,
INBOX.Outbox looks and behaves just like any other IMAP folder. If this
folder doesn’t exist it must be created by the IMAP mail client, just
like any other IMAP folder. The kicker: any message copied or moved to
this folder is will be E-mailed by the Courier-IMAP server, by running
the SENDMAIL program. Therefore, messages copied or moved to this
folder must be well-formed RFC-2822 messages, with the recipient list
specified in the To:, Cc:, and Bcc: headers. Courier-IMAP relies on
SENDMAIL to read the recipient list from these headers (and delete the Bcc:
header) by running the command “$SENDMAIL -oi -t -f $SENDER”, with the
message piped on standard input. $SENDER will be the return address
of the message, which is set by the authentication module.
DO NOT MODIFY SENDMAIL, below, unless you know what you’re doing.
SENDMAIL=/usr/sbin/sendmail
##NAME: HEADERFROM:0
For administrative and oversight purposes, the return address, $SENDER
will also be saved in the X-IMAP-Sender mail header. This header gets
added to the sent E-mail (but it doesn’t get saved in the copy of the
message that’s saved in the folder)
WARNING - By enabling OUTBOX above, every IMAP mail client will receive
the magic OUTBOX treatment. Therefore advance LARTing is in order for
all of your lusers, until every one of them is aware of this. Otherwise if
OUTBOX is left at its default setting - a folder name that might be used
accidentally - some people may be in for a rude surprise. You can redefine
the name of the magic folder by changing OUTBOX, above. You should do that
and pick a less-obvious name. Perhaps brand it with your organizational
name ( OUTBOX=.WidgetsAndSonsOutbox )
HEADERFROM=X-IMAP-Sender
##NAME: OUTBOX_MULTIPLE_SEND:0
Remove the following comment to allow a COPY of more than one message to
the Outbox, at a time.
OUTBOX_MULTIPLE_SEND=1
##NAME: IMAPDSTART:0
IMAPDSTART is not used directly. Rather, this is a convenient flag to
be read by your system startup script in /etc/rc.d, like this:
. /etc/courier/imapd
case x$IMAPDSTART in
x[yY]*)
/usr/lib/courier/imapd.rc start
esac
The default setting is going to be NO, so you’ll have to manually flip
it to yes.
IMAPDSTART=YES
##NAME: MAILDIRPATH:0
MAILDIRPATH - directory name of the maildir directory.
MAILDIRPATH=Maildir[/code]
Le port 143 repond aux requetes sous telnet,
en tentant de me connecter en root tout cours ca marche, mais marche pas avec les autres utilisateurs, et aucunes erreur visible dans les logs… j’ai un doute sur le authdeamon ainsi que le mailpath… mon mailpath c bien /home/user/Maildir…
J’ai l’habitude de me connecté en pam cad avec les utilisateur systéme(pas d’alias(user tout cours et non user@domaine.ltd) et pas d’authentification mysql) pour des raisons d’historique…
dans les logs j’ai pas de imap login logout, authdeamon declare un seccesfull, l’association imap se passe mais pas d’authentification
Si quelqu’un a une idée sur le probléme.
