Problème avec beryl sur carte intel
Salut a tous, j’ai un problème d’accélération graphique étrange qui fait que beryl a du mal a bien afficher le contenu des fenêtres.
j’ai une carte intel gma950 et j’utilise le driver i810, beryl marchait très bien avec ubuntu, j’ai peu être oublié de faire quelque chose???
voiçi mon xorg.conf
[code]Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath “/usr/X11R6/lib/X11/fonts/75dpi”
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Section "Device"
Identifier "Intel Corporation Mobile 945GM/GMS/940GML Express Integrated Graphics Controller"
Driver "i810"
BusID "PCI:0:2:0"
EndSection
Section "Monitor"
Identifier "Écran générique"
Option "DPMS"
HorizSync 28-64
VertRefresh 43-60
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Intel Corporation Mobile 945GM/GMS/940GML Express Integrated Graphics Controller"
Monitor "Écran générique"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1280x800"
EndSubSection
Depth 4
Modes "1280x800"
EndSubSection
Depth 8
Modes "1280x800"
EndSubSection
Depth 15
Modes "1280x800"
EndSubSection
Depth 16
Modes "1280x800"
EndSubSection
Depth 24
Modes "1280x800"
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
Section "Extensions"
Option “Composite” "Enable"
EndSection[/code]
Le message d’erreur quand je fais glxinfo | grep “direct rendering”
libGL warning: 3D driver claims to not support visual 0x66 do_wait: drmWaitVBlank returned -1, IRQs don't seem to be working correctly. Try running with LIBGL_THROTTLE_REFRESH and LIBL_SYNC_REFRESH unset. direct rendering: Yes
Merci d’avance…
Il faut pas ajouter les ligne
Option “AddARGBGLXVisuals” "True"
Option “DisableGLXRootClipping” “True”
dans la section “Screen” normalement ?
Je suis pas trop “bureau 3D” enfin en cherchant “debian beryl” on trouve plein de truc
