le dmesg me donne :
[ 1.086435] _OSC invalid UUID
[ 1.086437] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 1.086528] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 1.086530] pci 0000:00:01.0: PME# disabled
[ 1.086561] pci 0000:00:02.0: reg 10 64bit mmio: [0xb3000000-0xb33fffff]
[ 1.086566] pci 0000:00:02.0: reg 18 64bit mmio pref: [0xc0000000-0xcfffffff]
[ 1.086569] pci 0000:00:02.0: reg 20 io port: [0x3000-0x303f]
[ 1.086642] pci 0000:00:14.0: reg 10 64bit mmio: [0xb3600000-0xb360ffff]
[ 1.086698] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 1.086702] pci 0000:00:14.0: PME# disabled
[ 1.086749] pci 0000:00:16.0: reg 10 64bit mmio: [0xb3614000-0xb361400f]
[ 1.086809] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 1.086813] pci 0000:00:16.0: PME# disabled
[ 1.086870] pci 0000:00:1a.0: reg 10 32bit mmio: [0xb3619000-0xb36193ff]
[ 1.086941] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 1.086945] pci 0000:00:1a.0: PME# disabled
[ 1.086984] pci 0000:00:1b.0: reg 10 64bit mmio: [0xb3610000-0xb3613fff]
[ 1.087038] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 1.087042] pci 0000:00:1b.0: PME# disabled
[ 1.087176] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 1.087180] pci 0000:00:1c.0: PME# disabled
[ 1.087321] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 1.087327] pci 0000:00:1c.1: PME# disabled
[ 1.087392] pci 0000:00:1d.0: reg 10 32bit mmio: [0xb3618000-0xb36183ff]
[ 1.087463] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 1.087468] pci 0000:00:1d.0: PME# disabled
[ 1.087617] pci 0000:00:1f.2: reg 10 io port: [0x3088-0x308f]
[ 1.087623] pci 0000:00:1f.2: reg 14 io port: [0x3094-0x3097]
[ 1.087629] pci 0000:00:1f.2: reg 18 io port: [0x3080-0x3087]
[ 1.087635] pci 0000:00:1f.2: reg 1c io port: [0x3090-0x3093]
[ 1.087641] pci 0000:00:1f.2: reg 20 io port: [0x3060-0x307f]
[ 1.087647] pci 0000:00:1f.2: reg 24 32bit mmio: [0xb3617000-0xb36177ff]
[ 1.087690] pci 0000:00:1f.2: PME# supported from D3hot
[ 1.087694] pci 0000:00:1f.2: PME# disabled
[ 1.087723] pci 0000:00:1f.3: reg 10 64bit mmio: [0xb3615000-0xb36150ff]
[ 1.087737] pci 0000:00:1f.3: reg 20 io port: [0x3040-0x305f]
[ 1.087784] pci 0000:01:00.0: reg 10 32bit mmio: [0xb2000000-0xb2ffffff]
[ 1.087792] pci 0000:01:00.0: reg 14 64bit mmio pref: [0xa0000000-0xafffffff]
[ 1.087800] pci 0000:01:00.0: reg 1c 64bit mmio pref: [0xb0000000-0xb1ffffff]
[ 1.087806] pci 0000:01:00.0: reg 24 io port: [0x2000-0x207f]
[ 1.087811] pci 0000:01:00.0: reg 30 32bit mmio pref: [0xfff80000-0xffffffff]
[ 1.087874] pci 0000:00:01.0: bridge io port: [0x2000-0x2fff]
[ 1.087876] pci 0000:00:01.0: bridge 32bit mmio: [0xb2000000-0xb2ffffff]
[ 1.087880] pci 0000:00:01.0: bridge 64bit mmio pref: [0xa0000000-0xb1ffffff]
[ 1.088016] pci 0000:02:00.0: reg 10 64bit mmio pref: [0xb3430000-0xb343ffff]
[ 1.088038] pci 0000:02:00.0: reg 18 64bit mmio pref: [0xb3440000-0xb344ffff]
[ 1.088072] pci 0000:02:00.0: reg 30 32bit mmio pref: [0xfffff800-0xffffffff]
[ 1.088178] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 1.088184] pci 0000:02:00.0: PME# disabled
[ 1.088309] pci 0000:02:00.1: reg 10 64bit mmio pref: [0xb3400000-0xb340ffff]
[ 1.088459] pci 0000:02:00.1: PME# supported from D0 D3hot D3cold
[ 1.088464] pci 0000:02:00.1: PME# disabled
[ 1.088567] pci 0000:02:00.2: reg 10 64bit mmio pref: [0xb3410000-0xb341ffff]
[ 1.088716] pci 0000:02:00.2: PME# supported from D0 D3hot D3cold
[ 1.088722] pci 0000:02:00.2: PME# disabled
[ 1.088825] pci 0000:02:00.3: reg 10 64bit mmio pref: [0xb3420000-0xb342ffff]
[ 1.088972] pci 0000:02:00.3: PME# supported from D0 D3hot D3cold
[ 1.088978] pci 0000:02:00.3: PME# disabled
[ 1.089144] pci 0000:00:1c.0: bridge 64bit mmio pref: [0xb3400000-0xb34fffff]
[ 1.089247] pci 0000:03:00.0: reg 10 64bit mmio: [0xb3500000-0xb3503fff]
[ 1.089369] pci 0000:03:00.0: supports D1 D2
[ 1.089371] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ 1.089376] pci 0000:03:00.0: PME# disabled
[ 1.089460] pci 0000:00:1c.1: bridge 32bit mmio: [0xb3500000-0xb35fffff]
[ 1.089483] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 1.089649] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 1.089716] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT]
[ 1.089816] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEG0._PRT]
[ 1.090050] _OSC invalid UUID
[ 1.095932] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 10 11 12 14 15) *7
[ 1.096077] ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 10 *11 12 14 15)
[ 1.096217] ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 1.096358] ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 *10 11 12 14 15)
[ 1.096497] ACPI: PCI Interrupt Link [LNKE] (IRQs 1 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 1.096637] ACPI: PCI Interrupt Link [LNKF] (IRQs 1 3 4 5 6 10 11 12 14 15) *7
[ 1.096774] ACPI: PCI Interrupt Link [LNKG] (IRQs 1 3 4 5 6 *10 11 12 14 15)
[ 1.096914] ACPI: PCI Interrupt Link [LNKH] (IRQs 1 3 4 5 6 10 *11 12 14 15)
[ 1.096998] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 1.097005] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=none,locks=none
[ 1.097008] vgaarb: loaded
[ 1.097048] PCI: Using ACPI for IRQ routing
[ 1.097306] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 1.097311] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 1.100328] Switching to clocksource tsc
[ 1.101203] pnp: PnP ACPI init
[ 1.101209] ACPI: bus type pnp registered
[ 1.160474] pnp: PnP ACPI: found 12 devices
[ 1.160476] ACPI: ACPI bus type pnp unregistered
[ 1.160484] system 00:07: ioport range 0x680-0x69f has been reserved
[ 1.160486] system 00:07: ioport range 0xfd60-0xfd63 has been reserved
[ 1.160489] system 00:07: ioport range 0x1000-0x100f has been reserved
[ 1.160491] system 00:07: ioport range 0xffff-0xffff has been reserved
[ 1.160493] system 00:07: ioport range 0xffff-0xffff has been reserved
[ 1.160495] system 00:07: ioport range 0x400-0x453 has been reserved
[ 1.160497] system 00:07: ioport range 0x458-0x47f has been reserved
[ 1.160498] system 00:07: ioport range 0x500-0x57f has been reserved
[ 1.160500] system 00:07: ioport range 0x164e-0x164f has been reserved
[ 1.160504] system 00:09: ioport range 0x454-0x457 has been reserved
[ 1.160508] system 00:0a: iomem range 0xfed1c000-0xfed1ffff has been reserved
[ 1.160511] system 00:0a: iomem range 0xfed10000-0xfed17fff has been reserved
[ 1.160513] system 00:0a: iomem range 0xfed18000-0xfed18fff has been reserved
[ 1.160515] system 00:0a: iomem range 0xfed19000-0xfed19fff has been reserved
[ 1.160517] system 00:0a: iomem range 0xe0000000-0xefffffff has been reserved
[ 1.160519] system 00:0a: iomem range 0xfed20000-0xfed3ffff has been reserved
[ 1.160521] system 00:0a: iomem range 0xfed90000-0xfed93fff has been reserved
[ 1.160523] system 00:0a: iomem range 0xff000000-0xff000fff has been reserved
[ 1.160526] system 00:0a: iomem range 0xff010000-0xffffffff could not be reserved
[ 1.160528] system 00:0a: iomem range 0xfee00000-0xfeefffff could not be reserved
[ 1.160530] system 00:0a: iomem range 0x9fa00000-0x9fa00fff has been reserved
[ 1.160534] system 00:0b: iomem range 0x20000000-0x201fffff has been reserved
[ 1.160536] system 00:0b: iomem range 0x40004000-0x40004fff has been reserved
[ 1.165225] pci 0000:01:00.0: BAR 6: no parent found for of device [0xfff80000-0xffffffff]
[ 1.165288] pci 0000:02:00.0: BAR 6: no parent found for of device [0xfffff800-0xffffffff]
[ 1.165380] pci 0000:01:00.0: BAR 6: can't allocate mem resource [0xb2000000-0xb1ffffff]
[ 1.165382] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 1.165384] pci 0000:00:01.0: IO window: 0x2000-0x2fff
[ 1.165387] pci 0000:00:01.0: MEM window: 0xb2000000-0xb2ffffff
[ 1.165389] pci 0000:00:01.0: PREFETCH window: 0x000000a0000000-0x000000b1ffffff
[ 1.165394] pci 0000:00:1c.0: PCI bridge, secondary bus 0000:02
[ 1.165395] pci 0000:00:1c.0: IO window: disabled
[ 1.165405] pci 0000:00:1c.0: MEM window: 0x9fb00000-0x9fbfffff
[ 1.165410] pci 0000:00:1c.0: PREFETCH window: 0x000000b3400000-0x000000b34fffff
[ 1.165418] pci 0000:00:1c.1: PCI bridge, secondary bus 0000:03
[ 1.165420] pci 0000:00:1c.1: IO window: disabled
[ 1.165426] pci 0000:00:1c.1: MEM window: 0xb3500000-0xb35fffff
[ 1.165431] pci 0000:00:1c.1: PREFETCH window: disabled
[ 1.165443] alloc irq_desc for 16 on node -1
[ 1.165445] alloc kstat_irqs on node -1
[ 1.165449] pci 0000:00:01.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.165452] pci 0000:00:01.0: setting latency timer to 64
[ 1.165463] alloc irq_desc for 17 on node -1
[ 1.165464] alloc kstat_irqs on node -1
[ 1.165467] pci 0000:00:1c.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 1.165472] pci 0000:00:1c.0: setting latency timer to 64
[ 1.165482] pci 0000:00:1c.1: PCI INT B -> GSI 16 (level, low) -> IRQ 16
[ 1.165487] pci 0000:00:1c.1: setting latency timer to 64
[ 1.165491] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 1.165493] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffffffffffff]
[ 1.165495] pci_bus 0000:01: resource 0 io: [0x2000-0x2fff]
[ 1.165497] pci_bus 0000:01: resource 1 mem: [0xb2000000-0xb2ffffff]
[ 1.165499] pci_bus 0000:01: resource 2 pref mem [0xa0000000-0xb1ffffff]
[ 1.165501] pci_bus 0000:02: resource 1 mem: [0x9fb00000-0x9fbfffff]
[ 1.165502] pci_bus 0000:02: resource 2 pref mem [0xb3400000-0xb34fffff]
[ 1.165504] pci_bus 0000:03: resource 1 mem: [0xb3500000-0xb35fffff]
[ 1.165522] NET: Registered protocol family 2
[ 1.165635] IP route cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.166321] TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
[ 1.167960] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.168166] TCP: Hash tables configured (established 524288 bind 65536)
[ 1.168168] TCP reno registered
[ 1.168233] NET: Registered protocol family 1
[ 1.168245] pci 0000:00:02.0: Boot video device
[ 1.168259] alloc irq_desc for 21 on node -1
[ 1.168260] alloc kstat_irqs on node -1
[ 1.168265] pci 0000:00:14.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
[ 1.169477] pci 0000:00:14.0: PCI INT A disabled
[ 1.169487] pci 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.183529] pci 0000:00:1a.0: PCI INT A disabled
[ 1.183561] alloc irq_desc for 23 on node -1
[ 1.183562] alloc kstat_irqs on node -1
[ 1.183565] pci 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 1.199517] pci 0000:00:1d.0: PCI INT A disabled
[ 1.199585] Unpacking initramfs...
[ 1.368863] Freeing initrd memory: 9091k freed
[ 1.369885] Simple Boot Flag at 0x44 set to 0x1
[ 1.370345] audit: initializing netlink socket (disabled)
[ 1.370352] type=2000 audit(1346339955.140:1): initialized
[ 1.373307] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.374288] VFS: Disk quotas dquot_6.5.2
[ 1.374325] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.374380] msgmni has been set to 7611
[ 1.374582] alg: No test for stdrng (krng)
[ 1.374617] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.374619] io scheduler noop registered
[ 1.374620] io scheduler anticipatory registered
[ 1.374621] io scheduler deadline registered
[ 1.374659] io scheduler cfq registered (default)
[ 1.374728] alloc irq_desc for 24 on node -1
[ 1.374729] alloc kstat_irqs on node -1
[ 1.374737] pcieport 0000:00:01.0: irq 24 for MSI/MSI-X
[ 1.374741] pcieport 0000:00:01.0: setting latency timer to 64
[ 1.374858] alloc irq_desc for 25 on node -1
[ 1.374859] alloc kstat_irqs on node -1
[ 1.374868] pcieport 0000:00:1c.0: irq 25 for MSI/MSI-X
[ 1.374880] pcieport 0000:00:1c.0: setting latency timer to 64
[ 1.375034] alloc irq_desc for 26 on node -1
[ 1.375036] alloc kstat_irqs on node -1
[ 1.375045] pcieport 0000:00:1c.1: irq 26 for MSI/MSI-X
[ 1.375057] pcieport 0000:00:1c.1: setting latency timer to 64
[ 1.376088] Linux agpgart interface v0.103
[ 1.376115] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.376395] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 1.376434] PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:MSE0] at 0x60,0x64 irq 1,12
[ 1.393455] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.393459] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.393522] mice: PS/2 mouse device common for all mice
[ 1.393550] rtc_cmos 00:08: RTC can wake from S4
[ 1.393572] rtc_cmos 00:08: rtc core: registered rtc_cmos as rtc0
[ 1.393603] rtc0: alarms up to one month, 242 bytes nvram, hpet irqs
[ 1.393610] cpuidle: using governor ladder
[ 1.393611] cpuidle: using governor menu
[ 1.393614] No iBFT detected.
[ 1.393809] TCP cubic registered
[ 1.393889] NET: Registered protocol family 10
[ 1.394339] Mobile IPv6
[ 1.394341] NET: Registered protocol family 17
[ 1.394389] PM: Resume from disk failed.
[ 1.394395] registered taskstats version 1
[ 1.395577] rtc_cmos 00:08: setting system clock to 2012-08-30 15:19:15 UTC (1346339955)
[ 1.395631] Initalizing network drop monitor service
[ 1.395654] Freeing unused kernel memory: 592k freed
[ 1.395729] Write protecting the kernel read-only data: 4240k
[ 1.406070] udev[116]: starting version 164
[ 1.411681] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
[ 1.438718] usbcore: registered new interface driver usbfs
[ 1.438746] usbcore: registered new interface driver hub
[ 1.438795] usbcore: registered new device driver usb
[ 1.447219] SCSI subsystem initialized
[ 1.449238] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.449266] ehci_hcd 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.449304] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 1.449308] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 1.449326] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 1.449367] ehci_hcd 0000:00:1a.0: debug port 2
[ 1.453239] ehci_hcd 0000:00:1a.0: cache line size of 32 is not supported
[ 1.453256] ehci_hcd 0000:00:1a.0: irq 16, io mem 0xb3619000
[ 1.458788] libata version 3.00 loaded.
[ 1.460773] tg3.c:v3.116 (December 3, 2010)
[ 1.460832] tg3 0000:02:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.460842] tg3 0000:02:00.0: setting latency timer to 64
[ 1.467851] sdhci: Secure Digital Host Controller Interface driver
[ 1.467853] sdhci: Copyright(c) Pierre Ossman
[ 1.469012] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 1.469032] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.469035] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.469037] usb usb1: Product: EHCI Host Controller
[ 1.469039] usb usb1: Manufacturer: Linux 2.6.32-5-amd64 ehci_hcd
[ 1.469041] usb usb1: SerialNumber: 0000:00:1a.0
[ 1.469140] usb usb1: configuration #1 chosen from 1 choice
[ 1.469163] hub 1-0:1.0: USB hub found
[ 1.469167] hub 1-0:1.0: 2 ports detected
[ 1.469216] xhci_hcd 0000:00:14.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
[ 1.469243] xhci_hcd 0000:00:14.0: setting latency timer to 64
[ 1.469247] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.469256] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.469339] xhci_hcd 0000:00:14.0: cache line size of 32 is not supported
[ 1.469354] xhci_hcd 0000:00:14.0: irq 21, io mem 0xb3600000
[ 1.469380] usb usb2: config 1 interface 0 altsetting 0 endpoint 0x81 has no SuperSpeed companion descriptor
[ 1.469386] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.469388] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.469389] usb usb2: Product: xHCI Host Controller
[ 1.469391] usb usb2: Manufacturer: Linux 2.6.32-5-amd64 xhci_hcd
[ 1.469392] usb usb2: SerialNumber: 0000:00:14.0
[ 1.469440] usb usb2: configuration #1 chosen from 1 choice
[ 1.469443] xHCI xhci_add_endpoint called for root hub
[ 1.469445] xHCI xhci_check_bandwidth called for root hub
[ 1.469475] hub 2-0:1.0: USB hub found
[ 1.469481] hub 2-0:1.0: 8 ports detected
[ 1.469548] ahci 0000:00:1f.2: version 3.0
[ 1.469564] alloc irq_desc for 19 on node -1
[ 1.469566] alloc kstat_irqs on node -1
[ 1.469573] ahci 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 1.469609] alloc irq_desc for 27 on node -1
[ 1.469611] alloc kstat_irqs on node -1
[ 1.469623] ahci 0000:00:1f.2: irq 27 for MSI/MSI-X
[ 1.469652] ahci: SSS flag set, parallel bus scan disabled
[ 1.478047] tg3 0000:02:00.0: eth0: Tigon3 [partno(BCM57785) rev 57785100] (PCI Express) MAC address b8:88:e3:09:5c:f5
[ 1.478049] tg3 0000:02:00.0: eth0: attached PHY is 57765 (10/100/1000Base-T Ethernet) (WireSpeed[1])
[ 1.478052] tg3 0000:02:00.0: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 1.478054] tg3 0000:02:00.0: eth0: dma_rwctrl[00000001] dma_mask[64-bit]
[ 1.478110] sdhci-pci 0000:02:00.1: SDHCI controller found [14e4:16bc] (rev 10)
[ 1.478130] sdhci-pci 0000:02:00.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 1.478132] sdhci-pci 0000:02:00.1: Invalid iomem size. You may experience problems.
[ 1.478259] mmc0: Unknown controller version (2). You may experience problems.
[ 1.478360] sdhci-pci 0000:02:00.1: setting latency timer to 64
[ 1.478395] Registered led device: mmc0::
[ 1.478463] mmc0: SDHCI controller on PCI [0000:02:00.1] using ADMA
[ 1.484264] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x5 impl SATA mode
[ 1.484267] ahci 0000:00:1f.2: flags: 64bit ncq stag pm led clo pio slum part ems apst
[ 1.484274] ahci 0000:00:1f.2: setting latency timer to 64
[ 1.492273] scsi0 : ahci
[ 1.492354] scsi1 : ahci
[ 1.492407] scsi2 : ahci
[ 1.492460] scsi3 : ahci
[ 1.492518] scsi4 : ahci
[ 1.492569] scsi5 : ahci
[ 1.492670] ata1: SATA max UDMA/133 abar m2048@0xb3617000 port 0xb3617100 irq 27
[ 1.492672] ata2: DUMMY
[ 1.492675] ata3: SATA max UDMA/133 abar m2048@0xb3617000 port 0xb3617200 irq 27
[ 1.492676] ata4: DUMMY
[ 1.492677] ata5: DUMMY
[ 1.492678] ata6: DUMMY
[ 1.492703] ehci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 1.492726] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.492730] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 1.492739] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 3
[ 1.492768] ehci_hcd 0000:00:1d.0: debug port 2
[ 1.496644] ehci_hcd 0000:00:1d.0: cache line size of 32 is not supported
[ 1.496656] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xb3618000
[ 1.512943] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.512959] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.512962] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.512964] usb usb3: Product: EHCI Host Controller
[ 1.512966] usb usb3: Manufacturer: Linux 2.6.32-5-amd64 ehci_hcd
[ 1.512968] usb usb3: SerialNumber: 0000:00:1d.0
[ 1.513033] usb usb3: configuration #1 chosen from 1 choice
[ 1.513061] hub 3-0:1.0: USB hub found
[ 1.513069] hub 3-0:1.0: 2 ports detected
[ 1.780044] usb 1-1: new high speed USB device using ehci_hcd and address 2
[ 1.812030] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.861031] ata1.00: ATA-8: TOSHIBA MQ01ABD100, AX002J, max UDMA/100
[ 1.861035] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 1.862755] ata1.00: configured for UDMA/100
[ 1.876094] scsi 0:0:0:0: Direct-Access ATA TOSHIBA MQ01ABD1 AX00 PQ: 0 ANSI: 5
[ 1.916316] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.916320] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.916384] usb 1-1: configuration #1 chosen from 1 choice
[ 1.916470] hub 1-1:1.0: USB hub found
[ 1.916561] hub 1-1:1.0: 6 ports detected
[ 2.027904] usb 3-1: new high speed USB device using ehci_hcd and address 2
[ 2.160191] usb 3-1: New USB device found, idVendor=8087, idProduct=0024
[ 2.160195] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.160255] usb 3-1: configuration #1 chosen from 1 choice
[ 2.160369] hub 3-1:1.0: USB hub found
[ 2.160441] hub 3-1:1.0: 8 ports detected
[ 2.231904] usb 1-1.1: new full speed USB device using ehci_hcd and address 3
[ 2.331101] usb 1-1.1: New USB device found, idVendor=0489, idProduct=e046
[ 2.331105] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.331108] usb 1-1.1: Product: BCM20702A0
[ 2.331111] usb 1-1.1: Manufacturer: Broadcom Corp
[ 2.331113] usb 1-1.1: SerialNumber: 08EDB9F735A6
[ 2.331169] usb 1-1.1: configuration #1 chosen from 1 choice
[ 2.407822] usb 1-1.3: new high speed USB device using ehci_hcd and address 4
[ 2.570352] usb 1-1.3: New USB device found, idVendor=1bcf, idProduct=2c18
[ 2.570356] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.570360] usb 1-1.3: Product: HD Webcam
[ 2.570362] usb 1-1.3: Manufacturer: NC.21411.0022180242ALM0007
[ 2.570421] usb 1-1.3: configuration #1 chosen from 1 choice
[ 2.599568] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.601087] ata3.00: ACPI _SDD failed (AE 0x5)
[ 7.912410] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 7.913930] ata3.00: ACPI _SDD failed (AE 0x5)
[ 7.913931] ata3.00: ACPI: failed the second time, disabled
[ 7.913934] ata3.00: ATAPI: MATSHITADVD-RAM UJ8C0, 1.00, max UDMA/133
[ 7.915114] ata3.00: configured for UDMA/133
[ 7.929881] scsi 2:0:0:0: CD-ROM MATSHITA DVD-RAM UJ8C0 1.00 PQ: 0 ANSI: 5
[ 7.935694] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 7.935697] Uniform CD-ROM driver Revision: 3.20
[ 7.935939] sr 2:0:0:0: Attached scsi CD-ROM sr0
[ 7.936455] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
[ 7.936458] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 7.936513] sd 0:0:0:0: [sda] Write Protect is off
[ 7.936516] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 7.936539] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 7.936679] sda:
[ 7.938783] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 7.938804] sr 2:0:0:0: Attached scsi generic sg1 type 5
[ 8.222971] sda1 sda2 sda3 sda4 < sda5 sda6 >
[ 8.263167] sd 0:0:0:0: [sda] Attached SCSI disk
[ 8.883700] PM: Starting manual resume from disk
[ 8.883703] PM: Resume from partition 8:6
[ 8.883704] PM: Checking hibernation image.
[ 8.894127] PM: Error -22 checking image file
[ 8.894129] PM: Resume from disk failed.
[ 8.929968] kjournald starting. Commit interval 5 seconds
[ 8.929973] EXT3-fs: mounted filesystem with ordered data mode.
[ 10.429735] udev[449]: starting version 164
[ 10.826946] ACPI: SSDT 0000000096df8018 0083B (v01 PmRef Cpu0Cst 00003001 INTL 20100121)
[ 10.827433] ACPI: AC Adapter [ACAD] (on-line)
[ 10.827815] Monitor-Mwait will be used to enter C-1 state
[ 10.827830] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0C:00/input/input2
[ 10.827837] ACPI: Power Button [PWRB]
[ 10.827842] Monitor-Mwait will be used to enter C-2 state
[ 10.827886] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0D:00/input/input3
[ 10.827918] processor LNXCPU:00: registered as cooling_device0
[ 10.827962] ACPI: Lid Switch [LID0]
[ 10.827997] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0E:00/input/input4
[ 10.828001] ACPI: Sleep Button [SLPB]
[ 10.828590] ACPI: SSDT 0000000096df9a98 00303 (v01 PmRef ApIst 00003000 INTL 20100121)
[ 10.829147] ACPI: SSDT 0000000096df7d98 00119 (v01 PmRef ApCst 00003000 INTL 20100121)
[ 10.830018] processor LNXCPU:01: registered as cooling_device1
[ 10.830086] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
[ 10.830091] ACPI: Power Button [PWRF]
[ 10.831061] processor LNXCPU:02: registered as cooling_device2
[ 10.831885] processor LNXCPU:03: registered as cooling_device3
[ 10.832720] processor LNXCPU:04: registered as cooling_device4
[ 10.833490] processor LNXCPU:05: registered as cooling_device5
[ 10.834288] processor LNXCPU:06: registered as cooling_device6
[ 10.835069] processor LNXCPU:07: registered as cooling_device7
[ 10.997638] input: PC Speaker as /devices/platform/pcspkr/input/input6
[ 11.075849] ACPI: WMI: Mapper loaded
[ 11.130586] ACPI: Battery Slot [BAT1] (battery present)
[ 11.188404] acer-wmi: Acer Laptop ACPI-WMI Extras
[ 11.188412] acer-wmi: No or unsupported WMI interface, unable to load
[ 11.450709] [drm] Initialized drm 1.1.0 20060810
[ 11.626882] nouveau 0000:01:00.0: power state changed by ACPI to D0
[ 11.626930] nouveau 0000:01:00.0: power state changed by ACPI to D0
[ 11.626936] nouveau 0000:01:00.0: enabling device (0006 -> 0007)
[ 11.626942] nouveau 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 11.626946] nouveau 0000:01:00.0: setting latency timer to 64
[ 11.629121] [drm] nouveau 0000:01:00.0: Unsupported chipset 0x0e7120a2
[ 11.629200] nouveau 0000:01:00.0: PCI INT A disabled
[ 11.629205] nouveau: probe of 0000:01:00.0 failed with error -22
[ 11.883964] Linux video capture interface: v2.00
[ 11.902919] uvcvideo: Found UVC 1.00 device HD Webcam (1bcf:2c18)
[ 11.911371] input: HD Webcam as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.0/input/input7
[ 11.911419] usbcore: registered new interface driver uvcvideo
[ 11.911422] USB Video Class driver (v0.1.0)
[ 13.490844] input: PS/2 Logitech Wheel Mouse as /devices/platform/i8042/serio1/input/input8
[ 15.697507] Adding 3156984k swap on /dev/sda6. Priority:-1 extents:1 across:3156984k
[ 15.871015] EXT3 FS on sda5, internal journal
[ 15.997685] loop: module loaded
[ 17.278060] fuse init (API version 7.13)
[ 18.901084] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input9
[ 19.554929] alloc irq_desc for 28 on node -1
[ 19.554931] alloc kstat_irqs on node -1
[ 19.554937] tg3 0000:02:00.0: irq 28 for MSI/MSI-X
[ 19.554939] alloc irq_desc for 29 on node -1
[ 19.554940] alloc kstat_irqs on node -1
[ 19.554942] tg3 0000:02:00.0: irq 29 for MSI/MSI-X
[ 19.554944] alloc irq_desc for 30 on node -1
[ 19.554945] alloc kstat_irqs on node -1
[ 19.554947] tg3 0000:02:00.0: irq 30 for MSI/MSI-X
[ 19.554949] alloc irq_desc for 31 on node -1
[ 19.554950] alloc kstat_irqs on node -1
[ 19.554953] tg3 0000:02:00.0: irq 31 for MSI/MSI-X
[ 19.554956] alloc irq_desc for 32 on node -1
[ 19.554957] alloc kstat_irqs on node -1
[ 19.554960] tg3 0000:02:00.0: irq 32 for MSI/MSI-X
[ 19.747105] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 21.282632] Bluetooth: Core ver 2.15
[ 21.282726] NET: Registered protocol family 31
[ 21.282728] Bluetooth: HCI device and connection manager initialized
[ 21.282730] Bluetooth: HCI socket layer initialized
[ 21.326711] tg3 0000:02:00.0: eth0: Link is up at 100 Mbps, full duplex
[ 21.326713] tg3 0000:02:00.0: eth0: Flow control is on for TX and on for RX
[ 21.327025] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 21.705207] Bluetooth: L2CAP ver 2.14
[ 21.705210] Bluetooth: L2CAP socket layer initialized
[ 22.073662] Bluetooth: RFCOMM TTY layer initialized
[ 22.073667] Bluetooth: RFCOMM socket layer initialized
[ 22.073669] Bluetooth: RFCOMM ver 1.11
[ 22.330430] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 22.330432] Bluetooth: BNEP filters: protocol multicast
[ 22.441071] Bridge firewalling registered
[ 22.762573] Bluetooth: SCO (Voice Link) ver 0.6
[ 22.762577] Bluetooth: SCO socket layer initialized
[ 23.522752] lp: driver loaded but no devices found
[ 23.652271] ppdev: user-space parallel port driver
[ 31.674301] eth0: no IPv6 routers present
[ 32.077133] CPU0 attaching NULL sched-domain.
[ 32.077140] CPU1 attaching NULL sched-domain.
[ 32.077143] CPU2 attaching NULL sched-domain.
[ 32.077146] CPU3 attaching NULL sched-domain.
[ 32.077149] CPU4 attaching NULL sched-domain.
[ 32.077152] CPU5 attaching NULL sched-domain.
[ 32.077154] CPU6 attaching NULL sched-domain.
[ 32.077157] CPU7 attaching NULL sched-domain.
[ 32.134167] CPU0 attaching sched-domain:
[ 32.134174] domain 0: span 0-1 level SIBLING
[ 32.134177] groups: group ffff88000520fae0 cpus 0 (cpu_power = 589) group ffff88000524fae0 cpus 1 (cpu_power = 589)
[ 32.134212] domain 1: span 0-7 level MC
[ 32.134215] groups: group ffff88000520fbf0 cpus 0-1 (cpu_power = 1178) group ffff88000528fbf0 cpus 2-3 (cpu_power = 1178) group ffff88000530fbf0 cpus 4-5 (cpu_power = 1178) group ffff88000538fbf0 cpus 6-7 (cpu_power = 1178)
[ 32.134232] CPU1 attaching sched-domain:
[ 32.134235] domain 0: span 0-1 level SIBLING
[ 32.134238] groups: group ffff88000524fae0 cpus 1 (cpu_power = 589) group ffff88000520fae0 cpus 0 (cpu_power = 589)
[ 32.134246] domain 1: span 0-7 level MC
[ 32.134249] groups: group ffff88000520fbf0 cpus 0-1 (cpu_power = 1178) group ffff88000528fbf0 cpus 2-3 (cpu_power = 1178) group ffff88000530fbf0 cpus 4-5 (cpu_power = 1178) group ffff88000538fbf0 cpus 6-7 (cpu_power = 1178)
[ 32.134264] CPU2 attaching sched-domain:
[ 32.134267] domain 0: span 2-3 level SIBLING
[ 32.134270] groups: group ffff88000528fae0 cpus 2 (cpu_power = 589) group ffff8800052cfae0 cpus 3 (cpu_power = 589)
[ 32.134278] domain 1: span 0-7 level MC
[ 32.134280] groups: group ffff88000528fbf0 cpus 2-3 (cpu_power = 1178) group ffff88000530fbf0 cpus 4-5 (cpu_power = 1178) group ffff88000538fbf0 cpus 6-7 (cpu_power = 1178) group ffff88000520fbf0 cpus 0-1 (cpu_power = 1178)
[ 32.134295] CPU3 attaching sched-domain:
[ 32.134298] domain 0: span 2-3 level SIBLING
[ 32.134300] groups: group ffff8800052cfae0 cpus 3 (cpu_power = 589) group ffff88000528fae0 cpus 2 (cpu_power = 589)
[ 32.134309] domain 1: span 0-7 level MC
[ 32.134311] groups: group ffff88000528fbf0 cpus 2-3 (cpu_power = 1178) group ffff88000530fbf0 cpus 4-5 (cpu_power = 1178) group ffff88000538fbf0 cpus 6-7 (cpu_power = 1178) group ffff88000520fbf0 cpus 0-1 (cpu_power = 1178)
[ 32.134326] CPU4 attaching sched-domain:
[ 32.134329] domain 0: span 4-5 level SIBLING
[ 32.134331] groups: group ffff88000530fae0 cpus 4 (cpu_power = 589) group ffff88000534fae0 cpus 5 (cpu_power = 589)
[ 32.134340] domain 1: span 0-7 level MC
[ 32.134342] groups: group ffff88000530fbf0 cpus 4-5 (cpu_power = 1178) group ffff88000538fbf0 cpus 6-7 (cpu_power = 1178) group ffff88000520fbf0 cpus 0-1 (cpu_power = 1178) group ffff88000528fbf0 cpus 2-3 (cpu_power = 1178)
[ 32.134357] CPU5 attaching sched-domain:
[ 32.134360] domain 0: span 4-5 level SIBLING
[ 32.134362] groups: group ffff88000534fae0 cpus 5 (cpu_power = 589) group ffff88000530fae0 cpus 4 (cpu_power = 589)
[ 32.134370] domain 1: span 0-7 level MC
[ 32.134373] groups: group ffff88000530fbf0 cpus 4-5 (cpu_power = 1178) group ffff88000538fbf0 cpus 6-7 (cpu_power = 1178) group ffff88000520fbf0 cpus 0-1 (cpu_power = 1178) group ffff88000528fbf0 cpus 2-3 (cpu_power = 1178)
[ 32.134388] CPU6 attaching sched-domain:
[ 32.134391] domain 0: span 6-7 level SIBLING
[ 32.134393] groups: group ffff88000538fae0 cpus 6 (cpu_power = 589) group ffff8800053cfae0 cpus 7 (cpu_power = 589)
[ 32.134401] domain 1: span 0-7 level MC
[ 32.134404] groups: group ffff88000538fbf0 cpus 6-7 (cpu_power = 1178) group ffff88000520fbf0 cpus 0-1 (cpu_power = 1178) group ffff88000528fbf0 cpus 2-3 (cpu_power = 1178) group ffff88000530fbf0 cpus 4-5 (cpu_power = 1178)
[ 32.134419] CPU7 attaching sched-domain:
[ 32.134421] domain 0: span 6-7 level SIBLING
[ 32.134424] groups: group ffff8800053cfae0 cpus 7 (cpu_power = 589) group ffff88000538fae0 cpus 6 (cpu_power = 589)
[ 32.134432] domain 1: span 0-7 level MC
[ 32.134435] groups: group ffff88000538fbf0 cpus 6-7 (cpu_power = 1178) group ffff88000520fbf0 cpus 0-1 (cpu_power = 1178) group ffff88000528fbf0 cpus 2-3 (cpu_power = 1178) group ffff88000530fbf0 cpus 4-5 (cpu_power = 1178)
[ 64.526102] UDF-fs: No VRS found
[ 64.526106] UDF-fs: No partition found (1)
[ 64.529888] ISO 9660 Extensions: Microsoft Joliet Level 3
[ 64.574440] ISO 9660 Extensions: RRIP_1991A
Et le lspci -n :
00:00.0 0600: 8086:0154 (rev 09)
00:01.0 0604: 8086:0151 (rev 09)
00:02.0 0300: 8086:0166 (rev 09)
00:14.0 0c03: 8086:1e31 (rev 04)
00:16.0 0780: 8086:1e3a (rev 04)
00:1a.0 0c03: 8086:1e2d (rev 04)
00:1b.0 0403: 8086:1e20 (rev 04)
00:1c.0 0604: 8086:1e10 (rev c4)
00:1c.1 0604: 8086:1e12 (rev c4)
00:1d.0 0c03: 8086:1e26 (rev 04)
00:1f.0 0601: 8086:1e57 (rev 04)
00:1f.2 0106: 8086:1e03 (rev 04)
00:1f.3 0c05: 8086:1e22 (rev 04)
01:00.0 0300: 10de:0fd2 (rev a1)
02:00.0 0200: 14e4:16b5 (rev 10)
02:00.1 0805: 14e4:16bc (rev 10)
02:00.2 0880: 14e4:16be (rev 10)
02:00.3 0880: 14e4:16bf (rev 10)
03:00.0 0280: 14e4:4359
Quant au syslog, qu’est-ce que c’est ?
