Bjr a tous,
Je reviens vers vous car jai un probleme avec ma messagerie. J’utilise debian 4 (etch) où j’ai installé postfix. Je n’arrive pas a faire fonctionner normalement l’antivirus clamav sous postfix. Je l’ai installé et configuré mais dans mes logs, jai toujour ceci :
[size=85]Oct 25 11:54:25 mail2 amavis[11104]: (11104-05) (!!) ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can’t connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 44) line 268.
Oct 25 11:54:25 mail2 amavis[11104]: (11104-05) (!!) WARN: all primary virus scanners failed, considering backups
Oct 25 11:54:25 mail2 amavis[11139]: (11139-02) (!!) ClamAV-clamd av-scanner FAILED: Too many retries to talk to /var/run/clamav/clamd.ctl (Can’t connect to UNIX socket /var/run/clamav/clamd.ctl: No such file or directory) at (eval 44) line 268.
Oct 25 11:54:25 mail2 amavis[11139]: (11139-02) (!!) WARN: all primary virus scanners failed, considering backups
Oct 25 11:57:28 mail2 postfix/anvil[11146]: statistics: max connection rate 1/60s for (smtp:202.78.72.23) at Oct 25 11:54:03
Oct 25 11:57:28 mail2 postfix/anvil[11146]: statistics: max connection count 1 for (smtp:202.78.72.23) at Oct 25 11:54:03
Oct 25 11:57:28 mail2 postfix/anvil[11146]: statistics: max cache size 1 at Oct 25 11:54:03[/size]
Peut etre dû à un probleme de configuration.
Je sollicite votre aide pour resoudre mon probleme.
Merci à tous.
