mon journaux systeme affiche ça sans interruption:
May 1 21:44:05 localhost ccsd[6511]: Unable to connect to cluster infrastructure after 5070 seconds.
j’ai ce probleme et je ne sais meme pas ce que ça signifie?
est grave?
est grave?
hello,
A première vu ça ressemble à un problème avec ccsd, peux tu fournir plus de message, genre 10 lignes au dessus puis 10 lignes en dessous.
bonjour; oais!!! je voudrais mais ce sont dix lignes auperavant et dix lignes derrieres pareilles!!
j’aiùmerais dire des mechants choses, mais non, le sys.log report que ce que je ercrivais et le kernel.log pareil…etant donnè que je imagine l’erreur entre parentheses carrèes comme mon inode, je ne sais raiment que se passe…
alors je te passe le journaux systeme depuis ce soirb ( je n’arret plus car j’ai epur d’empirer ou perdre!!!)
May 3 01:13:49 localhost ccsd[6522]: Unable to connect to cluster infrastructure after 28680 seconds.
May 3 01:14:25 localhost ccsd[6522]: Unable to connect to cluster infrastructure after 28710 seconds.
May 3 01:15:00 localhost ccsd[6522]: Unable to connect to cluster infrastructure after 28740 seconds.
May 3 01:15:30 localhost ccsd[6522]: Unable to connect to cluster infrastructure after 28770 seconds.
May 3 01:16:00 localhost ccsd[6522]: Unable to connect to cluster infrastructure after 28800 seconds.
May 3 01:16:30 localhost ccsd[6522]: Unable to connect to cluster infrastructure after 28830 seconds.
May 3 01:17:01 localhost ccsd[6522]: Unable to connect to cluster infrastructure after 28860 seconds.
May 3 01:17:01 localhost /USR/SBIN/CRON[25158]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
May 3 01:17:31 localhost ccsd[6522]: Unable to connect to cluster infrastructure after 28890 seconds.
May 3 01:18:01 localhost ccsd[6522]: Unable to connect to cluster infrastructure after 28920 seconds.
May 3 01:18:32 localhost ccsd[6522]: Unable to connect to cluster infrastructure after 28950 seconds.
voilà ce qui se passe depuis mon migration edgy feisty…
je suis perdu mon pote!!!
le message est celui-la, j’arrive pas à configurer le cinfig.files car il ,n’existe pas et j’ai l’impression que plus de un manager de cluster rule. j’ai evrifiè sur les varies listes d’erreurs mais lmes solution me sont encomprensibles alors que le problem se prernst apparentement frequemment avec clvm et peut etrre ses conflits?
mais j’ai remoive clvm et l’erreur est là, j’arrive à comprendre que l’erreur souligne un e ligne la 63 25 mais je sui uncapable de savoir à quel inode se refere de coup: perdu!
bon je suis fatiguè, une journèe à recuperer des donnèes avant ler crash system cluster…je m’endors…à dmain
le message est celui-la, j’arrive pas à configurer le config.files car il ,n’existe pas et j’ai l’impression que plus que un manager de cluster rule sur le meme disq dur.
j’ai verifiè sur les varies listes d’erreurs mais les memess solutionsme sont encomprensibles alors que le problem se upgrade apparentement frequemment avec clvm et peut etrre ses conflits?
mais jeb remove clvm et l’erreur n’est pas là, j’arrive à comprendre que le progream identifie et soulignel’erreur 63 25 mais je suis incapable de savoir à quel inode se refere :de coup: perdu!
dMay 3 01:31:11 localhost – MARK –
c’est qui mark?d
C’est un indicateur temporel dans les logs de manière à connaitre a proximativement l’heure du plantage et ainsi avoir une plus grande facilité sur la découverte du problème.
voilà, depuis des jours, sans que je trouve l’issue, j’ai essayè de reinstaller tout ce qui concerne le cluster, mais pas des resultat, j’ai cherchè un image de cluster-config files pour en prendre des idèes, mais non j’y trouve rien, j’y comprends peu…
mark: apparaisse plusieurs fois dans la journèe sans que je comprends pourquoi.
est-ce que ça finira pour peter l’ordi?
merci à l’avance pour tout aide
celui ci est un exemple du journal syslog:
May 3 22:49:07 localhost named[7825]: USAGE 1178225347 1178196547 CPU=0.004u/0.004s CHILDCPU=0u/0s
May 3 22:49:07 localhost named[7825]: NSTATS 1178225347 1178196547
May 3 22:49:07 localhost named[7825]: XSTATS 1178225347 1178196547 RR=1 RNXD=0 RFwdR=0 RDupR=0 RFail=0 RFErr=0 RErr=0 RAXFR=0 RLame=0 ROpts=0 SSysQ=1 SAns=0 SFwdQ=0 SDupQ=0 SErr=0 RQ=0 RIQ=0 RFwdQ=0 RDupQ=0 RTCP=0 SFwdR=0 SFail=0 SFErr=0 SNaAns=0 SNXD=0 RUQ=0 RURQ=0 RUXFR=0 RUUpd=0
May 3 22:49:23 localhost ccsd[6535]: Unable to connect to cluster infrastructure after 28080 seconds.
May 3 22:49:57 localhost ccsd[6535]: Unable to connect to cluster infrastructure after 28110 seconds.
May 3 22:50:09 localhost /USR/SBIN/CRON[25405]: (root) CMD (test -x /usr/lib/atsar/atsa1 && /usr/lib/atsar/atsa1)
May 3 22:50:39 localhost ccsd[6535]: Unable to connect to cluster infrastructure after 28140 seconds.
May 3 22:51:09 localhost ccsd[6535]: Unable to connect to cluster infrastructure after 28170 seconds.
May 3 22:51:40 localhost ccsd[6535]: Unable to connect to cluster infrastructure after 28200 seconds.
May 3 22:52:16 localhost ccsd[6535]: Unable to connect to cluster infrastructure after 28230 seconds.
May 3 22:52:50 localhost ccsd[6535]: Unable to connect to cluster infrastructure after 28260 seconds.
May 3 22:53:20 localhost ccsd[6535]: Unable to connect to cluster infrastructure after 28290 seconds.
May 3 22:53:51 localhost ccsd[6535]: Unable to connect to cluster infrastructure after 28320 seconds.
May 3 22:54:21 localhost ccsd[6535]: Unable to connect to cluster infrastructure after 28350 seconds.
May 3 22:54:54 localhost ccsd[6535]: Unable to connect to cluster infrastructure after 28380 seconds.
May 3 22:55:28 localhost ccsd[6535]: Unable to connect to cluster infrastructure after 28410 seconds.
