Bonsoir tout le monde,
Voilà, j’ai installé cups pour que je puisse partager mon imprimante sur mon réseau, j’ai donc suvi ce tuto, people.via.ecp.fr/~alexis/format … mante.html
J’ai donc installé les paquets nécessaires sur le serveur, j’ai installé l’imprimante sur le serveur, elle fonctionne sur le serveur, j’ai donc installé cupsys-client, j’a configuré le fichier de conf comme indiqué dans le tuto, donc, voici le fichier de conf,
[quote]#
Sample client configuration file for the Common UNIX Printing System
(CUPS).
Copyright 1997-2005 by Easy Software Products, all rights reserved.
These coded instructions, statements, and computer programs are the
property of Easy Software Products and are protected by Federal
copyright law. Distribution and use rights are outlined in the file
“LICENSE.txt” which should have been included with this file. If this
file is missing or damaged please contact Easy Software Products
at:
Attn: CUPS Licensing Information
44141 Airport View Drive, Suite 204
Hollywood, Maryland 20636 USA
Voice: (301) 373-9600
EMail: cups-info@cups.org
WWW: cups.org
This is the CUPS client configuration file. This file is used to
define client-specific parameters, such as the default server or
default encryption settings.
ServerName: the hostname of your server. By default CUPS will use the
hostname of the system or the value of the CUPS_SERVER environment
variable. ONLY ONE SERVER NAME MAY BE SPECIFIED AT A TIME. To use
more than one server you must use a local scheduler with browsing
and possibly polling.
ServerName 192.168.1.2
Encryption: whether or not to use encryption; this depends on having
the OpenSSL library linked into the CUPS library.
Possible values:
Always - Always use encryption (SSL)
Never - Never use encryption
Required - Use TLS encryption upgrade
IfRequested - Use encryption if the server requests it
The default value is “IfRequested”. This parameter can also be set
using the CUPS_ENCRYPTION environment variable.
#Encryption Always
#Encryption Never
#Encryption Required
#Encryption IfRequested
Mais donc, lorsque j’installe sur un des pc, je vais dans l’interface d’administration de cups, je rajoute l’imprimante, mais elle ne semble pas détecté !
Que faire ?
