Problème avec driver NVIDIA
Lorsque j’essaie d’installer le Driver nvidia (avec le .run téléchargé sur le site de nvidia) il a un problème. Voici le log
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Fri Feb 27 08:50:29 2009
option status:
  license pre-accepted    : false
  update                  : false
  force update            : false
  expert                  : false
  uninstall               : false
  driver info             : false
  no precompiled interface: false
  no ncurses color        : false
  query latest driver ver : false
  OpenGL header files     : true
  no questions            : false
  silent                  : false
  no backup               : false
  kernel module only      : false
  sanity                  : false
  add this kernel         : false
  no runlevel check       : false
  no network              : false
  no ABI note             : false
  no RPMs                 : false
  force tls               : (not specified)
  force compat32 tls      : (not specified)
  X install prefix        : /usr/X11R6
  OpenGL install prefix   : /usr
  compat32 install prefix : (not specified)
  installer install prefix: /usr
  utility install prefix  : /usr
  kernel name             : (not specified)
  kernel include path     : (not specified)
  kernel source path      : (not specified)
  kernel output path      : (not specified)
  kernel install path     : (not specified)
  proc mount point        : /proc
  ui                      : (not specified)
  tmpdir                  : /tmp
  ftp mirror              : ftp://download.nvidia.com
  RPM file list           : (not specified)
Using: nvidia-installer ncurses user interface
-> License accepted.
-> No precompiled kernel interface was found to match your kernel; would you li
   ke the installer to attempt to download a kernel interface for your kernel f
   rom the NVIDIA ftp site (ftp://download.nvidia.com)? (Answer: Yes)
-> No matching precompiled kernel interface was found on the NVIDIA ftp site;
   this means that the installer will need to compile a kernel interface for
   your kernel.
-> Performing CC test with CC="gcc-4.1".
ERROR: Unable to determine the version of the kernel sources located in
       '/lib/modules/2.6.26-1-686/build'.  Please make sure you have installed
       the kernel source files for your kernel and that they are properly
       configured; on Red Hat Linux systems, for example, be sure you have the
       'kernel-source' RPM installed.  If you know the correct kernel source
       files are installed, you may specify the kernel source path with the
       '--kernel-source-path' command line option.
ERROR: Installation has failed.  Please see the file
       '/var/log/nvidia-installer.log' for details.  You may find suggestions
       on fixing installation problems in the README available on the Linux
       driver download page at www.nvidia.com.
Je suis sur Lenny.
Merci d’avance!
Ce n’est pas la bonne façon d’installer les pilotes NVIDIA sous Debian. Utilise les paquets (dépôt non-free).
ok… j’ai une geforce 8800 gts 512. J’installe quel paquet…?
C’est expliqué ici [1].
[1] wiki.debian.org/NvidiaGraphicsDr … 8a17864946
Et si tu ne comprends pas l’anglais, il y a un tuto dans Trucs & Astuces pour nVidia écrit par l’ami debianhadic.
Un lien pour l’article de truc & astuce?
heu…faut pas pousser quand même!!!
le sujet est sur la premiere page :unamused:
ah lol! je croyais que Truc & Astuce était une sorte de site web… :smt005
désolé…
