merci de ton lien
J’ai noté que tu as utilisé le paquet ntp-simple qui est maintenant obsolète : packages.debian.org/etch/ntp-simple
Contrairement à toi, je veux me synchroniser par internet et non synchroniser mes serveurs. À la place de mettre une adresse ip dans le /etc/ntp.conf, je vais donc mettre des serveurs (blog.christophelebot.fr/2006/04/ … ls-debian/ conseille fr.pool.ntp.org ).
Par contre quand j’ai ouvet /etc/ntp.conf, j’ai vu qu’il y a plein de choses :
[code]# /etc/ntp.conf, configuration for ntpd; see ntp.conf(5) for help
driftfile /var/lib/ntp/ntp.drift
Enable this if you want statistics to be logged.
#statsdir /var/log/ntpstats/
statistics loopstats peerstats clockstats
filegen loopstats file loopstats type day enable
filegen peerstats file peerstats type day enable
filegen clockstats file clockstats type day enable
You do need to talk to an NTP server or two (or three).
#server ntp.your-provider.example
pool.ntp.org maps to about 1000 low-stratum NTP servers. Your server will
pick a different set every time it starts up. Please consider joining the
server 0.debian.pool.ntp.org iburst dynamic
server 1.debian.pool.ntp.org iburst dynamic
server 2.debian.pool.ntp.org iburst dynamic
server 3.debian.pool.ntp.org iburst dynamic
Access control configuration; see /usr/share/doc/ntp-doc/html/accopt.html for
might also be helpful.
Note that “restrict” applies to both servers and clients, so a configuration
that might be intended to block requests from certain clients could also end
up blocking replies from your own upstream servers.
By default, exchange time with everybody, but don’t allow configuration.
restrict -4 default kod notrap nomodify nopeer noquery
restrict -6 default kod notrap nomodify nopeer noquery
Local users may interrogate the ntp server more closely.
restrict 127.0.0.1
restrict ::1
Clients from this (example!) subnet have unlimited access, but only if
cryptographically authenticated.
#restrict 192.168.123.0 mask 255.255.255.0 notrust
If you want to provide time to your local subnet, change the next line.
(Again, the address is an example only.)
#broadcast 192.168.123.255
If you want to listen to time broadcasts on your local subnet, de-comment the
next lines. Please do this only if you trust everybody on the network!
#disable auth
#broadcastclient[/code]J’ai 3 questions : [ol][li]les serveurs sont de la forme : server 0.debian.pool.ntp.org iburst dynamic puis-je les remplacer par server 0.fr.pool.ntp.org ? Qu’apporte le iburst et le dynamic[/li][li]Je comprend pas le passage : # By default, exchange time with everybody, but don't allow configuration.
[/li][li]Je peux commenter ceci : # Local users may interrogate the ntp server more closely.
restrict 127.0.0.1
restrict ::1vu que je ne suis pas en réseau local, non ?[/li][/ol]
