Salut à tous !
J’ai un problème sur mon serveur, que je présente dans le fil de discussion suivant, dont je détaille le partitionnement dans cet autre fil et au sujet duquel de nombreuses informations sont résumées sur un autre forum. J’ai tenté de le mettre à jour et j’ai obtenu le message suivant :
Configuration de linux-image-2.6.26-2-amd64
Error running the boot loader in test mode
An error occurred while running the lilo boot loader in test mode.
A log is available in /var/log/lilo_log.1431. Please edit /etc/lilo.conf
manually and re-run lilo to fix that issue and keep this system
bootable.
Voici le contenu de /var/log/lilo_log.1431 :
Warning: LBA32 addressing assumed
Fatal: Not all RAID-1 disks are active; use '-H' to install to active disks only
Et celui de /etc/lilo.conf :
# Automatically added by lilo postinst script
large-memory
# /etc/lilo.conf - See: `lilo(8)' and `lilo.conf(5)',
# --------------- `install-mbr(8)', `/usr/share/doc/lilo/',
# and `/usr/share/doc/mbr/'.
# | !! Reminder !! |
# | Don't forget to run `lilo' after you make changes to this |
# | conffile, `/boot/bootmess.txt' (if you have created it), or |
# | install a new kernel. The computer will most likely fail to |
# | boot if a kernel-image post-install script or you don't |
# | remember to run `lilo'. |
# Specifies the boot device. This is where Lilo installs its boot
# block. It can be either a partition, or the raw device, in which
# case it installs in the MBR, and will overwrite the current MBR.
boot=/dev/md0
# Specifies the device that should be mounted as root. (`/')
root=/dev/mapper/volume--lvm--1-volume2
# This option may be needed for some software RAID installs.
raid-extra-boot=mbr-only
# Enable map compaction:
# Tries to merge read requests for adjacent sectors into a single
# read request. This drastically reduces load time and keeps the
# map smaller. Using `compact' is especially recommended when
# booting from a floppy disk. It is disabled here by default
# because it doesn't always work.
# compact
# Installs the specified file as the new boot sector
# You have the choice between: text, bmp, and menu
# Look in lilo.conf(5) manpage for details
#install=menu
# Specifies the location of the map file
map=/boot/map
# You can set a password here, and uncomment the `restricted' lines
# in the image definitions below to make it so that a password must
# be typed to boot anything but a default configuration. If a
# command line is given, other than one specified by an `append'
# statement in `lilo.conf', the password will be required, but a
# standard default boot will not require one.
# This will, for instance, prevent anyone with access to the
# console from booting with something like `Linux init=/bin/sh',
# and thus becoming `root' without proper authorization.
# Note that if you really need this type of security, you will
# likely also want to use `install-mbr' to reconfigure the MBR
# program, as well as set up your BIOS to disallow booting from
# removable disk or CD-ROM, then put a password on getting into the
# BIOS configuration as well. Please RTFM `install-mbr(8)'.
# password=tatercounter2000
# Specifies the number of deciseconds (0.1 seconds) LILO should
# wait before booting the first image.
delay=20
# You can put a customized boot message up if you like. If you use
# `prompt', and this computer may need to reboot unattended, you
# must specify a `timeout', or it will sit there forever waiting
# for a keypress. `single-key' goes with the `alias' lines in the
# `image' configurations below. eg: You can press `1' to boot
# `Linux', `2' to boot `LinuxOLD', if you uncomment the `alias'.
# message=/boot/bootmess.txt
# prompt
# delay=100
# timeout=100
# Specifies the VGA text mode at boot time. (normal, extended, ask, <mode>)
# vga=ask
# vga=9
# Kernel command line options that apply to all installed images go
# here. See: The `boot-prompt-HOWTO' and `kernel-parameters.txt' in
# the Linux kernel `Documentation' directory.
# append=""
# If you used a serial console to install Debian, this option should be
# enabled by default.
# serial=
# Boot up Linux by default.
default=Linux
image=/vmlinuz
label=Linux
read-only
# restricted
# alias=1
initrd=/initrd.img
image=/vmlinuz.old
label=LinuxOLD
read-only
optional
# restricted
# alias=2
initrd=/initrd.img.old
# If you have another OS on this machine to boot, you can uncomment the
# following lines, changing the device name on the `other' line to
# where your other OS' partition is.
# other=/dev/hda4
# label=HURD
# restricted
# alias=3
Effectivement, je conserve une partie de mes disques pour un usage ultérieur.
Comme il s’agit d’un serveur, de surcroit auquel je n’ai pas accès physiquement puisqu’il est chez ma sœur, avant de me lancer dans un bricolage hasardeux, je préfère venir me renseigner ici sur la marche à suivre et les conseils qui pourraient m’être donnés.
À bientôt.
Le Farfadet Spatial
