Problème avec paquet Redmine après mise à jours : uninitialized constant Redmine::I18n
Bonjour tout le monde,
J’utilise redmine en instance de production sur une VM sous Debian, or depuis une mise à jours (via aptitude) du paquet redmine j’ai une erreur maintenant. ( uninitialized constant Redmine::I18n )
J’ai essayé de poster sur le forum redmine (https://www.redmine.org/boards/2/topics/59432), mais il m’ont renvoyé vers la communauté Debian.
Est-ce que certains d’entre vous saurai comment regler cette erreur ?
root! vps:/usr/share/redmine# bundle exec rails server webrick -e production
=> Booting WEBrick
=> Rails 5.2.4.2 application starting in production on http://0.0.0.0:3000
=> Run `rails server -h` for more startup options
Exiting
Traceback (most recent call last):
    67: from bin/rails:4:in `<main>'
    66: from /var/lib/gems/2.5.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:31:in `require'
    65: from /var/lib/gems/2.5.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in `require_with_bootsnap_lfi'
    64: from /var/lib/gems/2.5.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/loaded_features_index.rb:92:in `register'
    63: from /var/lib/gems/2.5.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `block in require_with_bootsnap_lfi'
    62: from /var/lib/gems/2.5.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `require'
    61: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/commands.rb:18:in `<top (required)>'
    60: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/command.rb:46:in `invoke'
    59: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/command/base.rb:69:in `perform'
    58: from /var/lib/gems/2.5.0/gems/thor-1.0.1/lib/thor.rb:392:in `dispatch'
    57: from /var/lib/gems/2.5.0/gems/thor-1.0.1/lib/thor/invocation.rb:127:in `invoke_command'
    56: from /var/lib/gems/2.5.0/gems/thor-1.0.1/lib/thor/command.rb:27:in `run'
    55: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/commands/server/server_command.rb:142:in `perform'
    54: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/commands/server/server_command.rb:142:in `tap'
    53: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/commands/server/server_command.rb:147:in `block in perform'
    52: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/commands/server/server_command.rb:53:in `start'
    51: from /var/lib/gems/2.5.0/gems/rack-2.2.2/lib/rack/server.rb:311:in `start'
    50: from /var/lib/gems/2.5.0/gems/rack-2.2.2/lib/rack/server.rb:379:in `handle_profiling'
    49: from /var/lib/gems/2.5.0/gems/rack-2.2.2/lib/rack/server.rb:312:in `block in start'
    48: from /var/lib/gems/2.5.0/gems/rack-2.2.2/lib/rack/server.rb:422:in `wrapped_app'
    47: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/commands/server/server_command.rb:27:in `app'
    46: from /var/lib/gems/2.5.0/gems/rack-2.2.2/lib/rack/server.rb:249:in `app'
    45: from /var/lib/gems/2.5.0/gems/rack-2.2.2/lib/rack/server.rb:349:in `build_app_and_options_from_config'
    44: from /var/lib/gems/2.5.0/gems/rack-2.2.2/lib/rack/builder.rb:66:in `parse_file'
    43: from /var/lib/gems/2.5.0/gems/rack-2.2.2/lib/rack/builder.rb:105:in `load_file'
    42: from /var/lib/gems/2.5.0/gems/rack-2.2.2/lib/rack/builder.rb:116:in `new_from_string'
    41: from /var/lib/gems/2.5.0/gems/rack-2.2.2/lib/rack/builder.rb:116:in `eval'
    40: from config.ru:3:in `block in <main>'
    39: from /var/lib/gems/2.5.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:31:in `require'
    38: from /var/lib/gems/2.5.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in `require_with_bootsnap_lfi'
    37: from /var/lib/gems/2.5.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/loaded_features_index.rb:92:in `register'
    36: from /var/lib/gems/2.5.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `block in require_with_bootsnap_lfi'
    35: from /var/lib/gems/2.5.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `require'
    34: from /usr/share/redmine/config/environment.rb:5:in `<top (required)>'
    33: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/application.rb:361:in `initialize!'
    32: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/initializable.rb:60:in `run_initializers'
    31: from /usr/lib/ruby/2.5.0/tsort.rb:205:in `tsort_each'
    30: from /usr/lib/ruby/2.5.0/tsort.rb:226:in `tsort_each'
    29: from /usr/lib/ruby/2.5.0/tsort.rb:347:in `each_strongly_connected_component'
    28: from /usr/lib/ruby/2.5.0/tsort.rb:347:in `call'
    27: from /usr/lib/ruby/2.5.0/tsort.rb:347:in `each'
    26: from /usr/lib/ruby/2.5.0/tsort.rb:349:in `block in each_strongly_connected_component'
    25: from /usr/lib/ruby/2.5.0/tsort.rb:415:in `each_strongly_connected_component_from'
    24: from /usr/lib/ruby/2.5.0/tsort.rb:415:in `call'
    23: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/initializable.rb:50:in `tsort_each_child'
    22: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/initializable.rb:50:in `each'
    21: from /usr/lib/ruby/2.5.0/tsort.rb:421:in `block in each_strongly_connected_component_from'
    20: from /usr/lib/ruby/2.5.0/tsort.rb:431:in `each_strongly_connected_component_from'
    19: from /usr/lib/ruby/2.5.0/tsort.rb:422:in `block (2 levels) in each_strongly_connected_component_from'
    18: from /usr/lib/ruby/2.5.0/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
    17: from /usr/lib/ruby/2.5.0/tsort.rb:228:in `block in tsort_each'
    16: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/initializable.rb:61:in `block in run_initializers'
    15: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/initializable.rb:32:in `run'
    14: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/initializable.rb:32:in `instance_exec'
    13: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/engine.rb:619:in `block in <class:Engine>'
    12: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/engine.rb:619:in `each'
    11: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/engine.rb:620:in `block (2 levels) in <class:Engine>'
    10: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/engine.rb:662:in `load_config_initializer'
     9: from /var/lib/gems/2.5.0/gems/activesupport-5.2.4.2/lib/active_support/notifications.rb:170:in `instrument'
     8: from /var/lib/gems/2.5.0/gems/railties-5.2.4.2/lib/rails/engine.rb:663:in `block in load_config_initializer'
     7: from /var/lib/gems/2.5.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:55:in `load'
     6: from /var/lib/gems/2.5.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:55:in `load'
     5: from /usr/share/redmine/config/initializers/10-patches.rb:18:in `<top (required)>'
     4: from /usr/share/redmine/config/initializers/10-patches.rb:19:in `<module:ActiveRecord>'
     3: from /usr/share/redmine/config/initializers/10-patches.rb:20:in `<class:Base>'
     2: from /var/lib/gems/2.5.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/active_support.rb:60:in `load_missing_constant'
     1: from /var/lib/gems/2.5.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/active_support.rb:17:in `allow_bootsnap_retry'
/var/lib/gems/2.5.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/active_support.rb:61:in `block in load_missing_constant': uninitialized constant Redmine::I18n (NameError)
Merci d’avance,
personne n’a d’idée ? :frowning:
Bonjour AnGe7
Je n’utilise pas Redmine et je ne le connais pas.
Mais la dernière ligne du retour que tu nous donnes,
nous indique qu’il y aurait une erreur de nom de constante I18n (Internationalisation)
En faisant des recherches, j’ai trouvé ce fil de discussion
dont le contenu pourrait peut-être t’aider.
Hello,
Merci pour ton aide,
j’ai regardé le lien que tu m’a donné mais ça ne m’a pas vraiment aidé :frowning:
j’ai installé le repository buster-backport et mis à jours le paquet redmine, c’est revenu… merci.
Merci à toi pour le retour.
