Après moult essais j’ai toujours ça :
[code]
/usr/lib/pm-utils/sleep.d/00logging suspend suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/00powersave suspend suspend:
/usr/lib/pm-utils/sleep.d/00powersave suspend suspend: success.
Running hook /etc/pm/sleep.d/10_unattended-upgrades-hibernate suspend suspend:
/etc/pm/sleep.d/10_unattended-upgrades-hibernate suspend suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/55NetworkManager suspend suspend:
Having NetworkManager put all interaces to sleep…Failed.
/usr/lib/pm-utils/sleep.d/55NetworkManager suspend suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/60_wpa_supplicant suspend suspend:
Failed to connect to wpa_supplicant - wpa_ctrl_open: No such file or directory
/usr/lib/pm-utils/sleep.d/60_wpa_supplicant suspend suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/75modules suspend suspend:
/usr/lib/pm-utils/sleep.d/75modules suspend suspend: not applicable.
Running hook /usr/lib/pm-utils/sleep.d/90clock suspend suspend:
/usr/lib/pm-utils/sleep.d/90clock suspend suspend: not applicable.
Running hook /usr/lib/pm-utils/sleep.d/94cpufreq suspend suspend:
/usr/lib/pm-utils/sleep.d/94cpufreq suspend suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/95anacron suspend suspend:
/usr/lib/pm-utils/sleep.d/95anacron suspend suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/95hdparm-apm suspend suspend:
/usr/lib/pm-utils/sleep.d/95hdparm-apm suspend suspend: not applicable.
Running hook /usr/lib/pm-utils/sleep.d/95led suspend suspend:
/usr/lib/pm-utils/sleep.d/95led suspend suspend: not applicable.
Running hook /usr/lib/pm-utils/sleep.d/98video-quirk-db-handler suspend suspend:
Using last known working set of quirks.
/usr/lib/pm-utils/sleep.d/98video-quirk-db-handler suspend suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/99video suspend suspend:
kernel.acpi_video_flags = 0
Allocated buffer at 0x11000 (base is 0x0)
ES: 0x1100 EBX: 0x0000
/usr/lib/pm-utils/sleep.d/99video suspend suspend: success.
Sat Sep 21 07:48:18 CEST 2013: performing suspend
Sat Sep 21 07:48:25 CEST 2013: Awake.
Sat Sep 21 07:48:25 CEST 2013: Running hooks for resume
Running hook /usr/lib/pm-utils/sleep.d/99video resume suspend:
Function not supported
/usr/lib/pm-utils/sleep.d/99video resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/98video-quirk-db-handler resume suspend:
/usr/lib/pm-utils/sleep.d/98video-quirk-db-handler resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/95led resume suspend:
/usr/lib/pm-utils/sleep.d/95led resume suspend: not applicable.
Running hook /usr/lib/pm-utils/sleep.d/95hdparm-apm resume suspend:
/dev/sda:
setting Advanced Power Management level to 0xfe (254)
APM_level = 254
/dev/sda:
APM_level = 254
/usr/lib/pm-utils/sleep.d/95hdparm-apm resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/95anacron resume suspend:
/usr/lib/pm-utils/sleep.d/95anacron resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/94cpufreq resume suspend:
/usr/lib/pm-utils/sleep.d/94cpufreq resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/90clock resume suspend:
/usr/lib/pm-utils/sleep.d/90clock resume suspend: not applicable.
Running hook /usr/lib/pm-utils/sleep.d/75modules resume suspend:
Reloaded unloaded modules.
/usr/lib/pm-utils/sleep.d/75modules resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/60_wpa_supplicant resume suspend:
/usr/lib/pm-utils/sleep.d/60_wpa_supplicant resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/55NetworkManager resume suspend:
Having NetworkManager wake interfaces back up…Failed.
/usr/lib/pm-utils/sleep.d/55NetworkManager resume suspend: success.
Running hook /etc/pm/sleep.d/10_unattended-upgrades-hibernate resume suspend:
/etc/pm/sleep.d/10_unattended-upgrades-hibernate resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/00powersave resume suspend:
/usr/lib/pm-utils/sleep.d/00powersave resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/00logging resume suspend:
/usr/lib/pm-utils/sleep.d/00logging resume suspend: success.
Running hook /usr/lib/pm-utils/sleep.d/000kernel-change resume suspend:
/usr/lib/pm-utils/sleep.d/000kernel-change resume suspend: success.
Sat Sep 21 07:48:28 CEST 2013: Finished.[/code]
Toujours le même problème, impossible de sortir de veille.
Je vois vraiment pas dans quelle direction chercher, une idée ?
(Note au passage, sous ubuntu la veille fonctionne, je veux pas utiliser ubuntu mais si lui y arrive, doit bien y avoir une solution)
