Bonjour,je n’es plus rien dans mon fichier debug et se qui est garder en memoire dans le debug0 c’est ce que j’ai afficher en haut.
Pour mon fichier conf:
[code]#
/etc/proftpd.conf – This is a basic ProFTPD configuration file.
To really apply changes reload proftpd after modifications.
ServerName "Debian"
ServerType standalone
DeferWelcome off
MultilineRFC2228 on
DefaultServer on
ShowSymlinks on
TimeoutNoTransfer 600
TimeoutStalled 600
TimeoutIdle 1200
DisplayLogin welcome.msg
DisplayFirstChdir .message
ListOptions “-l”
DenyFilter *.*/
Uncomment this if you are using NIS or LDAP to retrieve passwords:
#PersistentPasswd off
Uncomment this if you would use TLS module:
#TLSEngine on
Uncomment this if you would use quota module:
#Quotas on
Uncomment this if you would use ratio module:
#Ratios on
Port 21 is the standard FTP port.
Port 21
To prevent DoS attacks, set the maximum number of child processes
to 30. If you need to allow more than 30 concurrent connections
at once, simply increase this value. Note that this ONLY works
in standalone mode, in inetd mode you should use an inetd server
that allows you to limit maximum number of processes per service
(such as xinetd)
MaxInstances 30
Set the user and group that the server normally runs at.
User nobody
Group nogroup
Umask 022 is a good standard umask to prevent new files and dirs
(second parm) from being group and world writable.
Umask 022 022
Normally, we want files to be overwriteable.
AllowOverwrite on
Delay engine reduces impact of the so-called Timing Attack described in
It is on by default.
DelayEngine off
A basic anonymous configuration, no upload directories.
<Anonymous ~ftp>
User ftp
Group nogroup
# We want clients to be able to login with “anonymous” as well as “ftp”
UserAlias anonymous ftp
# Cosmetic changes, all files belongs to ftp user
DirFakeUser on ftp
DirFakeGroup on ftp
RequireValidShell off
# Limit the maximum number of anonymous logins
MaxClients 10
# We want ‘welcome.msg’ displayed at login, and ‘.message’ displayed
# in each newly chdired directory.
# Limit WRITE everywhere in the anonymous chroot
<Directory *>
DenyAll
# Uncomment this if you’re brave.
# # Umask 022 is a good standard umask to prevent new files and dirs
# # (second parm) from being group and world writable.
# Umask 022 022
# DenyAll
# AllowAll
Pour les étapes bien, pas grand chose je les installer normalement sans faire plus de se qu’il en fallait.
