Hello,
J’essaye de choper l’adresse de /bin/sh via un memory dumper avec ptrace(), mais le soucis est que j’ai le message d’erreur suivant :
[quote]
ptrace: Operation not permitted[/quote]
Le code source pour faire la chose est le suivant :
[code]
** memdump.c for
** Comments : a string resolver. It is basic, slow, beta, and just provided
** ‘as is’ with no warranty as code example.
** Written by Clad Strife
** on Fri Mar 18 18:33:38 2005 - Paris
#include <errno.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <sys/ptrace.h>
#include <sys/wait.h>
void resolve_string(const char *str, int pid, void *base);
int main(int ac, char **av)
void *base;
void *result;
int pid;
** We need 4 params :
** [progname] string PID 0x[base_address]
if (ac < 4) {
fprintf(stderr,
"Usage :\n%s string PID 0x[base_address]\n", av[0]);
return (1);
** We init parameters
base = (void *) strtol(av[3], 0, 16);
pid = atoi(av[2]);
** We call the resolver
resolve_string(av[1], pid, base);
** End of game.
ptrace(PTRACE_DETACH, pid, 0, 0);
return (0);
** This function is based on ptrace(). It looks each byte of the memory for
** a string matching *str.
** It will print error messages on error while attaching but not if reading
** memory fails.
long res;
int length;
int i;
int j;
int inc = sizeof(long);
int flag = 0; / disabled */
** Attach processus
if (ptrace(PTRACE_ATTACH, pid, 0, 0) < 0) {
perror("ptrace");
return;
wait4(pid, 0, 0, 0);
** length % inc should be equal to 0.
length = strlen(str) + 1;
if (length % inc) {
length += inc - (length % inc);
if ((res = malloc(length)) == 0) {
perror("malloc");
exit(1);
** _Ugly_ memory parsing.
printf ("Searching...\n");
while (1) {
for (i = 0, j = 0; i < length; i += inc, j++) {
void *tmpbase;
tmpbase = (void *) ((long) base + i);
** Read memory
if ((res[j] = ptrace(PTRACE_PEEKDATA, pid, tmpbase, 0))
== (-1)) {
** Error ?
if (errno) {
free(res);
(flag) || printf("[%s] : not found.\n",
str);
return;
** Compare data with requested string
if (!strcmp((char *) res, str)) {
printf("[%s] found in processus %d at : %p.\n",
str, pid, base);
flag = 1;
** Look next bytes
base = (void *) ((unsigned int) base + 1);
return;
}[/code]
Bref, ça merdouille avec ptrace(), pourquoi ?
