Probleme avec Sensors
J espère trouver une solution ici.
J’ai donc un soucis avec Sensors sur mon serveur. Voici les infos dessus :
[quote]00:00.0 Host bridge: VIA Technologies, Inc. VT8377 [KT400/KT600 AGP] Host Bridge (rev 80)
00:01.0 PCI bridge: VIA Technologies, Inc. VT8237 PCI Bridge
00:0f.0 RAID bus controller: VIA Technologies, Inc. VIA VT6420 SATA RAID Controller (rev 80)
00:0f.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06)
00:10.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.3 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.4 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 86)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8237 ISA bridge [KT600/K8T800/K8T890 South]
00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller (rev 60)
00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102 [Rhine-II] (rev 78)
01:00.0 VGA compatible controller: ATI Technologies Inc Radeon RV100 QY [Radeon 7000/VE][/quote]
Chipset 8237 donc.
Seul soucis, meme si le bon driver est utilisé
j’obtiens ca du coup :
[quote]chouchen:/home/lilobzh# sensors
w83697hf-isa-0290
Adapter: ISA adapter
VCore: +1.78 V (min = +0.61 V, max = +2.62 V)
+3.3V: +3.22 V (min = +1.79 V, max = +1.20 V) ALARM
+5V: +4.92 V (min = +6.83 V, max = +0.11 V) ALARM
+12V: +11.61 V (min = +0.85 V, max = +11.37 V) ALARM
-12V: +0.96 V (min = +5.49 V, max = -10.63 V) ALARM
-5V: +2.14 V (min = +0.13 V, max = -2.69 V) ALARM
V5SB: +5.30 V (min = +1.77 V, max = +0.43 V) ALARM
VBat: +2.86 V (min = +1.09 V, max = +2.56 V) ALARM
fan1: 0 RPM (min = 5152 RPM, div = 2) ALARM
fan2: 3668 RPM (min = 2960 RPM, div = 2)
temp1: +38°C (high = -128°C, hyst = -48°C) sensor = thermistor ALARM
temp2: +55.0°C (high = +80°C, hyst = +75°C) sensor = thermistor
alarms:
beep_enable:
Sound alarm enabled
Valeurs donc qui partent un peu en cacahuète
Si quelqu un pouvait me dépanner.
merci :slightly_smiling:
personne ? :s
:smt006
Je suppose que tu parles de “lm-sensors” …
Tu pourrais essayer l’install de la nouvelle version dispo sur lenny …
~$ apt-cache policy lm-sensors lm-sensors: Installé : (aucun) Candidat : 1:2.10.1-3 Table de version : 1:3.0.2-1+b2 0 990 http://ftp.fr.debian.org sid/main Packages 1:3.0.2-1+b1 0 992 http://ftp.fr.debian.org lenny/main Packages 1:2.10.1-3 0 995 http://ftp.fr.debian.org etch/main Packages
Les valeurs semblent correctes à part les min et max.
Question bete mais pourquoi tu dis que les valeurs sont bonnes ?
[quote]-12V: +0.96 V (min = +5.49 V, max = -10.63 V) ALARM
-5V: +2.14 V (min = +0.13 V, max = -2.69 V) ALARM[/quote]
les valeurs min et max, m en susi pas occupé encore :slightly_smiling:
Les voltages négatifs ne sont jamais très représentatif. À mon avis, les informations données sont correctes. Si tu veux en être sûr, vérifie avec un voltmètre.
je viens de faire le réglage des min max ce qui donne :
[quote]
VCore +1.78 V +1.71 V +1.89 V
+3.3V +3.20 V +3.14 V +3.47 V
+5V +4.84 V +4.76 V +5.24 V
+12V +11.73 V +10.82 V +13.19 V
-12V +1.04 V -13.18 V -10.80 V
-5V +2.24 V -5.25 V -4.75 V
V5SB +5.32 V +4.76 V +5.24 V
VBat +2.86 V +2.40 V +3.60 V[/quote]
il reste donc effectivement les 2 négatifs + le V5
[quote]-12V +1.04 V -13.18 V -10.80 V
V5SB +5.32 V +4.76 V +5.24 V[/quote]
Meme si ce n’est pas representatif, c’est quand meme bizarre ces valeurs :s
Enfin, c’est noté
