voilà je sais pas pourquoi mais je suis passer sous sid.
maintenant les jeux ne se lancent plus et je n’ai pas de son.
ce sont les seuls problèmes rencontrées pour le moment , comment y remédier ?
aplay -l ?
pulseaudio, alsa ?
tiens :
aplay -l :
**** List of PLAYBACK Hardware Devices ****
card 0: V8237 [VIA 8237], device 0: VIA 8237 [VIA 8237]
Subdevices: 4/4
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
card 0: V8237 [VIA 8237], device 1: VIA 8237 [VIA 8237]
Subdevices: 1/1
pulseaudio :
bash: pulseaudio : commande introuvable
Usage: /usr/sbin/alsa {unload|reload|force-unload|force-reload|suspend|resume}
alsamixer puis touche m pour activer le son …
- flèche du haut pour monter le son ( pcm default master …)
si pas ok
asoundconf list
lsmod ?
lspci | grep audio
bash: asoundconf : commande introuvable
Module Size Used by
via 33888 2
drm 137920 3 via
ppdev 6348 0
lp 8012 0
cpufreq_userspace 2768 0
cpufreq_stats 3520 0
cpufreq_conservative 6256 0
cpufreq_powersave 1292 0
firewire_sbp2 12692 0
loop 13324 0
snd_via82xx 20692 1
snd_via82xx_modem 9888 0
gameport 10248 1 snd_via82xx
snd_ac97_codec 91264 2 snd_via82xx,snd_via82xx_modem
ac97_bus 1456 1 snd_ac97_codec
snd_pcm_oss 32232 0
snd_mpu401_uart 6124 1 snd_via82xx
snd_mixer_oss 12368 1 snd_pcm_oss
snd_pcm 62420 5 snd_via82xx,snd_via82xx_modem,snd_ac97_codec,snd_pcm_oss
snd_seq_midi 5688 0
snd_rawmidi 18596 2 snd_mpu401_uart,snd_seq_midi
snd_seq_midi_event 6212 1 snd_seq_midi
snd_seq 42436 2 snd_seq_midi,snd_seq_midi_event
joydev 8576 0
snd_timer 17436 2 snd_pcm,snd_seq
evdev 8028 12
snd_seq_device 6136 3 snd_seq_midi,snd_rawmidi,snd_seq
pcspkr 2104 0
psmouse 37528 0
snd 49060 12 snd_via82xx,snd_via82xx_modem,snd_ac97_codec,snd_pcm_oss,snd_mpu401_uart,snd_mixer_oss,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
parport_pc 22420 1
i2c_viapro 6624 0
snd_page_alloc 8180 3 snd_via82xx,snd_via82xx_modem,snd_pcm
soundcore 6184 1 snd
i2c_core 20844 2 drm,i2c_viapro
serio_raw 4560 0
shpchp 26648 0
parport 31144 3 ppdev,lp,parport_pc
processor 34504 0
pci_hotplug 24400 1 shpchp
button 5060 0
ext3 107172 2
jbd 41036 1 ext3
mbcache 6924 1 ext3
hid_logitech 6520 0
ff_memless 4332 1 hid_logitech
usbhid 31568 1 hid_logitech
hid 34528 2 hid_logitech,usbhid
ide_cd_mod 24484 0
cdrom 30316 1 ide_cd_mod
ide_gd_mod 19852 4
ata_generic 4340 0
uhci_hcd 19132 0
ide_pci_generic 3632 0
sata_via 8384 0
libata 150904 2 ata_generic,sata_via
ehci_hcd 29680 0
via82cxxx 6044 3
scsi_mod 131800 2 firewire_sbp2,libata
ide_core 88100 4 ide_cd_mod,ide_gd_mod,ide_pci_generic,via82cxxx
usbcore 126004 4 usbhid,uhci_hcd,ehci_hcd
via_rhine 18676 0
mii 4664 1 via_rhine
via_agp 7564 1
firewire_ohci 18952 0
agpgart 30836 2 drm,via_agp
firewire_core 37736 2 firewire_sbp2,firewire_ohci
crc_itu_t 2148 1 firewire_core
thermal 12580 0
fan 4044 0
thermal_sys 13140 3 processor,thermal,fan
00:00.0 Host bridge: VIA Technologies, Inc. VT8378 [KM400/A] Chipset Host Bridge
00:01.0 PCI bridge: VIA Technologies, Inc. VT8237/VX700 PCI Bridge
00:0a.0 Communication controller: Agere Systems V.92 56K WinModem (rev 03)
00:0b.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6306 Fire II IEEE 1394 OHCI Link Layer Controller (rev 80)
00:0f.0 IDE interface: VIA Technologies, Inc. VIA VT6420 SATA RAID Controller (rev 80)
00:0f.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06)
00:10.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.3 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.4 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 86)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8237 ISA bridge [KT600/K8T800/K8T890 South]
00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller (rev 60)
00:11.6 Communication controller: VIA Technologies, Inc. AC’97 Modem Controller (rev 80)
00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102 [Rhine-II] (rev 78)
01:00.0 VGA compatible controller: VIA Technologies, Inc. KM400/KN400/P4M800 [S3 UniChrome] (rev 01)
grep audio ne donne pas encore de réponses.
Pour passer sous sid il faut avoir modifié son sources.list
Pour ce qui est du son chez moi cela persiste c’est énervent.
Bon courage à toi.
j’ai modif le sources.lsit et le fichier preferences dans le topic sources list au carré.
ensuite apt-get update puis apt-get dist-upgrade.
alsamixer c’est ok?
? pas asoundconf ni alsaconf dans sid, tu peut les avoir un mettant une source squeeze ou lenny
puis apt-get alsa-base alsa-utils
puis alsaconf pour le paramétrage
comment je fais tout ça ?
pour alsamixer, comment le remetre par défaut ?
alsamixer
avec les flèches tu monte le son, avec touche m (mute) tu réactive le son
et
alsactl store pour enregistrer les réglages
Pour vérifier que l’installation matérielle n’est pas en cause :
Installer VirtualBox et Windows XP ==> le son est bien là
alsamixer est dispo sur le sid (j’ai dis une connerie plus haut
as tu essayé de faire un apt-get install alsa-utils (alsa-tools)?
j’ai xp en dual boot et le son marche.
merci alsactl store ça marche !!!
au fait les jeux ne marchent toujours pas.
Hello,Ma boule de crystal ne voit rien, tu peux peut être l’aider en lui disant de qu’elle jeux il s’agis
lance les jeux en console ou dans un terminal pour voire les erreurs
mai une question par topic. donc je te sugere de re-faire un autre post pour les jeux:
d’ailleurs il y a un site dédier aux jeux sous linux:
essaye d’abord dessus.
jeuvinux.net/
