Bonjour, je suis sur Debian Etch et je veux installer slapd ainsi que samba donc.
Dès que je veux le lancer il me dit :
[quote]Starting OpenLDAP: slapd - failed.
The operation failed but no output was produced. For hints on what went
wrong please refer to the system’s logfiles (e.g. /var/log/syslog) or
try running the daemon in Debug mode like via “slapd -d 16383” (warning:
this will create copious output).
Below, you can find the command line options used by this script to
run slapd. Do not forget to specify those options if you
want to look to debugging output:
slapd -g openldap -u openldap -f /etc/ldap/slapd.conf
invoke-rc.d: initscript slapd, action “start” failed.
dpkg: error processing slapd (–configure):
subprocess post-installation script returned error exit status 1
Setting up db4.2-util (4.2.52+dfsg-5) …
Setting up ldap-utils (2.4.11-1) …
Errors were encountered while processing:
slapd
A package failed to install. Trying to recover:
Setting up slapd (2.4.11-1) …
Backing up /etc/ldap/slapd.conf in /var/backups/slapd-2.4.11-1… done.
slapd[/quote]
Mon fichier de config :
[quote]# Specific Backend Directives for bdb:
Backend specific directives apply to this backend until another
‘backend’ directive occurs
backend bdb
checkpoint 512 30
Specific Backend Directives for ‘other’:
#backend
Specific Directives for database #1, of type bdb:
Database specific directives apply to this databasse until another
‘database’ directive occurs
database bdb
The base of your directory in database #1
######## Donnez le nom de votre base LDAP (normalement debconf a rajouté pour vous cette ligne)
suffix “dc=XXXXXXX,dc=XXXXXXXX”
######## Donnez le nom de votre base LDAP avec le nom Admin. ( ligne à créer)
rootdn “cn=admin,dc=XXXXXXXXXXXx,dc=XXXXXXXX”
######## Dans une console root lancez la commande slappasswd, donnez votre mot de passe que vous aviez
######## mis à l’installation de slapd (dans debconf), la commande vous renvoie le mot de passe crypté,
######## copiez le. ( ligne à créer)
rootpw {SSHA}ecUmYLMqgXsSyx3yQODiXkimaoZkAzdk
Where the database file are physically stored for database #1
directory “/var/lib/ldap”
Indexing options for database #1
index objectClass eq
Save the time that the entry gets modified, for database #1
lastmod on
Where to store the replica logs for database #1
replogfile /var/lib/ldap/replog
The userPassword by default can be changed
by the entry owning it if they are authenticated.
Others should not be able to see it, except the
admin entry below
These access lines apply to database #1 only
access to attrs=userPassword
by dn=“cn=admin,dc=XXXXXXX,dc=XXXX” write
by anonymous auth
by self write
by * none
Ensure read access to the base for things like
supportedSASLMechanisms. Without this you may
have problems with SASL not knowing what
mechanisms are available and the like.
Note that this is covered by the ‘access to *’
ACL below too but if you change that as people
are wont to do you’ll still need this if you
want SASL (and possible other things) to work
happily.
access to dn.base="" by * read
The admin dn has full write access, everyone else
can read everything.
access to *
by dn=“cn=admin,dc=XXXXXX,dc=XXX” write
by * read[/quote]
Si vous avez une idée ? Merci d’avance, je perds patience là…
