[code]/etc/gdm/Xsession: Beginning session setup…
2243 (dpy) 17:06:40 [0] read_settings(): stalonetray 0.7.6 [ XPM:yes DEBUG:yes KDE:yes ] starting
2243 (:0.0) 17:06:40 [0] tray_update_root_bg_pmap(): could not update root background pixmap
2243 (:0.0) 17:06:40 [0] tray_acquire_selection(): ok, got _NET_SYSTEM_TRAY selection
2243 (:0.0) 17:06:41 [0] tray_update_root_bg_pmap(): could not update root background pixmap
tint2 : nb monitor 1, nb desktop 2
tint2 : pixmap background detection failed
tint2 : another systray is running
conky: aucun processus tué
Conky: invalid configuration file ‘/home/val/.conky/.conkyrc’
Conky: statfs ‘/media/My Passport’: No such file or directory
Conky: desktop window (8a) is root window
Conky: window type - override
Conky: drawing to created window (0x1000001)
Conky: drawing to double buffer
2243 (:0.0) 17:07:04 [0] add_icon(): 0x1400058: icon added as hidden
2243 (:0.0) 17:07:04 [0] icon_track_visibility_changes(): 0x1400058: showing
2243 (:0.0) 17:13:29 [0] remove_icon(): 0x1400058: icon removed
ERROR: ld.so: object ‘libjvm.so’ from LD_PRELOAD cannot be preloaded: ignored.
ERROR: ld.so: object ‘libawt.so’ from LD_PRELOAD cannot be preloaded: ignored.
2243 (:0.0) 17:13:35 [0] add_icon(): 0x140000c: icon added as visible
2243 (:0.0) 17:21:20 [0] add_icon(): 0x1a00058: icon added as hidden
2243 (:0.0) 17:21:20 [0] icon_track_visibility_changes(): 0x1a00058: showing
2243 (:0.0) 17:22:29 [0] remove_icon(): 0x1a00058: icon removed
2243 (:0.0) 17:23:05 [0] remove_icon(): 0x140000c: icon removed
2243 (:0.0) 17:56:17 [0] add_icon(): 0x1400021: icon added as hidden
2243 (:0.0) 17:56:17 [0] icon_track_visibility_changes(): 0x1400021: showing
2243 (:0.0) 18:00:23 [0] icon_track_visibility_changes(): 0x1400021: hiding
2243 (:0.0) 18:00:23 [0] embedder_unembed(): failed to move 0x805a32b out of the tray
2243 (:0.0) 18:00:23 [0] remove_icon(): 0x1400021: icon removed
2243 (:0.0) 18:07:22 [0] add_icon(): 0x140000c: icon added as visible
2243 (:0.0) 18:07:57 [0] remove_icon(): 0x140000c: icon removed
2243 (:0.0) 18:10:22 [0] add_icon(): 0x140000c: icon added as visible
2243 (:0.0) 18:10:28 [0] remove_icon(): 0x140000c: icon removed
2243 (:0.0) 18:12:05 [0] add_icon(): 0x1600059: icon added as hidden
2243 (:0.0) 18:12:05 [0] icon_track_visibility_changes(): 0x1600059: showing
2243 (:0.0) 18:13:15 [0] add_icon(): 0x1800072: icon added as hidden
2243 (:0.0) 18:13:15 [0] icon_track_visibility_changes(): 0x1800072: showing
2243 (:0.0) 18:13:19 [0] remove_icon(): 0x1600059: icon removed
2243 (:0.0) 18:13:35 [0] add_icon(): 0x1600072: icon added as hidden
2243 (:0.0) 18:13:35 [0] icon_track_visibility_changes(): 0x1600072: showing
2243 (:0.0) 18:13:38 [0] remove_icon(): 0x1600072: icon removed
2243 (:0.0) 18:13:44 [0] remove_icon(): 0x1800072: icon removed
2243 (:0.0) 18:13:46 [0] add_icon(): 0x1600072: icon added as hidden
2243 (:0.0) 18:13:46 [0] icon_track_visibility_changes(): 0x1600072: showing
/usr/share/decibel-audio-player/src/modules/CtrlPanel.py:87: GtkWarning: gtk_range_set_range: assertion `min < max’ failed
self.sclSeek.set_range(0, self.currTrackLength)
2243 (:0.0) 18:15:33 [0] add_icon(): 0x1800021: icon added as hidden
2243 (:0.0) 18:15:33 [0] icon_track_visibility_changes(): 0x1800021: showing
2243 (:0.0) 18:15:47 [0] icon_track_visibility_changes(): 0x1800021: hiding
2243 (:0.0) 18:15:47 [0] embedder_unembed(): failed to move 0x805a32b out of the tray
2243 (:0.0) 18:15:47 [0] remove_icon(): 0x1800021: icon removed
2243 (:0.0) 18:17:56 [0] add_icon(): 0x1800072: icon added as hidden
2243 (:0.0) 18:17:56 [0] icon_track_visibility_changes(): 0x1800072: showing
2243 (:0.0) 18:17:58 [0] remove_icon(): 0x1800072: icon removed
(thunar:2477): Thunar-WARNING **: Failed to launch the volume manager (L’exécution du processus fils « thunar-volman » a échoué (Aucun fichier ou répertoire de ce type)), make sure you have the “thunar-volman” package installed.
** (totem:2672): WARNING **: Failed to create dbus proxy for org.gnome.SettingsDaemon: Could not get owner of name ‘org.gnome.SettingsDaemon’: no such name
2243 (:0.0) 18:30:41 [0] add_icon(): 0x1800059: icon added as hidden
2243 (:0.0) 18:30:41 [0] icon_track_visibility_changes(): 0x1800059: showing
2243 (:0.0) 18:30:44 [0] remove_icon(): 0x1800059: icon removed
2243 (:0.0) 19:11:33 [0] remove_icon(): 0x1600072: icon removed
2243 (:0.0) 19:26:08 [0] add_icon(): 0x140000c: icon added as visible
2243 (:0.0) 19:46:46 [0] remove_icon(): 0x140000c: icon removed
(thunar:2863): Thunar-WARNING **: Failed to launch the volume manager (L’exécution du processus fils « thunar-volman » a échoué (Aucun fichier ou répertoire de ce type)), make sure you have the “thunar-volman” package installed.
(terminator:3584): Vte-WARNING **: Erreur lors de la compilation de l’expression régulière « [:<:]//([-A-Za-z0-9]+(:[-A-Za-z0-9,?;.:/!%$^&~"#’]+)?@)?[-A-Za-z0-9.]+(:[0-9]+)?(/[-A-Za-z0-9_$.+!(),;:@&=?/~#%’]*[^]’.}>)
2243 (:0.0) 02:30:49 [0] add_icon(): 0x1c00059: icon added as visible
sending IMStart with 0 chars to 0xb1c3008
sending IMEnd with 1 chars to 0xb1c3008, text=^
sending IMEnd with 1 chars to 0xb1c3008, text=ê
2243 (:0.0) 02:37:41 [0] remove_icon(): 0x140000c: icon removed
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:4: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_about.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:5: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_volume.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:7: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_mic.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:8: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_line-in.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:9: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_attach.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:10: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_book.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:11: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_book.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:12: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_book.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:13: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_book.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:16: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_dialog_info.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:17: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_dialog_question.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:18: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_dialog_error.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:19: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_dialog_warning.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:21: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_dnd.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:22: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_dnd_multiple.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:24: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_add.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:26: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_bold.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:27: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_cancel.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:28: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_cdrom.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:29: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_clear.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:30: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_close.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:31: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_convert.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:32: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_copy.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:33: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_cut.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:34: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_delete.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:35: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_execute.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:36: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_find.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:37: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_find-and-replace.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:38: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_floppy.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:39: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_goto-bottom.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:40: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_goto-first.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:41: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_goto-last.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:42: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_goto-top.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:43: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_go-back.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:44: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_go-down.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:45: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_go-forward.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:46: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_go-up.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:47: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_help.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:48: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_home.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:49: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_index.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:50: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_italic.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:52: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_jump-to.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:53: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_justify-center.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:54: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_justify-fill.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:55: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_justify-left.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:56: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_justify-right.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:57: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_missing-image.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:58: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_new.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:59: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_no.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:60: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_ok.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:61: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_open.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:62: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_paste.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:63: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_print.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:64: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_print-preview.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:65: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_preferences.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:66: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_properties.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:67: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_quit.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:68: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_redo.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:69: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_refresh.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:70: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_remove.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:71: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_revert-to-saved.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:72: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_save.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:73: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_save-as.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:74: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_select-color.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:75: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_select-font.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:76: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_sort-ascending.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:77: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_sort-descending.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:78: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_spell-check.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:79: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_stop.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:80: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_strikethrough.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:81: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_undelete.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:82: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_underline.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:83: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_undo.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:84: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_yes.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:85: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_zoom-100.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:86: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_zoom-fit.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:87: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_zoom-in.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:88: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_zoom-out.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:90: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_preferences.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:91: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_preferences.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:93: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_edit.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:94: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_import.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:95: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_export.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:96: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_insert-image.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:97: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_insert-object.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:98: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_insert-table.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:99: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_connect.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:100: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_disconnect.svg »
/usr/share/themes/Cukoo-spit/gtk-2.0/iconrc:101: Incapable de localiser le fichier image dans le chemin des pixmaps : « stock_reset.svg »
2243 (:0.0) 02:38:08 [0] remove_icon(): 0x1c00059: icon removed
2243 (:0.0) 03:40:12 [0] add_icon(): 0x140000c: icon added as visible
** Message: GetValue variable 1 (1)
** Message: GetValue variable 2 (2)
2243 (:0.0) 03:40:24 [0] add_icon(): 0x1600003: icon added as hidden
2243 (:0.0) 03:40:24 [0] icon_track_visibility_changes(): 0x1600003: showing
(gossip:3717): GLib-CRITICAL **: g_io_channel_write_chars: assertion `channel != NULL’ failed
2243 (:0.0) 03:43:16 [0] add_icon(): 0x1e00021: icon added as hidden
2243 (:0.0) 03:43:16 [0] icon_track_visibility_changes(): 0x1e00021: showing
2243 (:0.0) 03:43:34 [0] icon_track_visibility_changes(): 0x1e00021: hiding
2243 (:0.0) 03:43:34 [0] embedder_unembed(): failed to move 0x805a32b out of the tray
2243 (:0.0) 03:43:34 [0] remove_icon(): 0x1e00021: icon removed
2243 (:0.0) 03:46:05 [0] remove_icon(): 0x140000c: icon removed
2243 (:0.0) 03:50:36 [0] add_icon(): 0x140000c: icon added as visible
2243 (:0.0) 03:50:56 [0] remove_icon(): 0x140000c: icon removed
2243 (:0.0) 03:51:36 [0] add_icon(): 0x140000c: icon added as visible
2243 (:0.0) 03:54:12 [0] remove_icon(): 0x140000c: icon removed
2243 (:0.0) 03:54:24 [0] add_icon(): 0x140000c: icon added as visible
2243 (:0.0) 03:57:03 [0] remove_icon(): 0x140000c: icon removed
2243 (:0.0) 03:57:26 [0] add_icon(): 0x140000c: icon added as visible
2243 (:0.0) 03:59:25 [0] remove_icon(): 0x140000c: icon removed
2243 (:0.0) 04:02:18 [0] add_icon(): 0x140000c: icon added as visible
2243 (:0.0) 04:06:32 [0] remove_icon(): 0x140000c: icon removed
2243 (:0.0) 04:07:18 [0] remove_icon(): 0x1600003: icon removed
2243 (:0.0) 04:07:56 [0] add_icon(): 0x1400003: icon added as hidden
2243 (:0.0) 04:07:56 [0] icon_track_visibility_changes(): 0x1400003: showing
2243 (:0.0) 08:29:42 [0] add_icon(): 0x160000c: icon added as visible
2243 (:0.0) 08:31:09 [0] remove_icon(): 0x160000c: icon removed
2243 (:0.0) 08:33:14 [0] add_icon(): 0x160000c: icon added as visible
2243 (:0.0) 08:33:14 [0] icon_track_visibility_changes(): 0x1400003: hiding
2243 (:0.0) 08:33:14 [0] embedder_unembed(): failed to move 0x805a32b out of the tray
2243 (:0.0) 08:33:14 [0] remove_icon(): 0x1400003: icon removed
2243 (:0.0) 08:35:06 [0] remove_icon(): 0x160000c: icon removed
2243 (:0.0) 08:42:40 [0] add_icon(): 0x140000c: icon added as visible
2243 (:0.0) 08:42:48 [0] add_icon(): 0x1600003: icon added as hidden
2243 (:0.0) 08:42:48 [0] icon_track_visibility_changes(): 0x1600003: showing
2243 (:0.0) 08:43:05 [0] remove_icon(): 0x1600003: icon removed
2243 (:0.0) 08:43:21 [0] remove_icon(): 0x140000c: icon removed
2243 (:0.0) 08:52:31 [0] add_icon(): 0x1400059: icon added as hidden
2243 (:0.0) 08:52:31 [0] icon_track_visibility_changes(): 0x1400059: showing
2243 (:0.0) 08:55:27 [0] add_icon(): 0x160000c: icon added as visible
2243 (:0.0) 08:56:52 [0] remove_icon(): 0x160000c: icon removed
debug: clean_operation(‘adobereader’), options = ‘[(u’cache’, True)]‘
debug: clean_operation(‘amsn’), options = ‘[(u’logs’, True)]‘
debug: clean_operation(‘bash’), options = ‘[(u’history’, True)]‘
debug: clean_operation(‘beagle’), options = ‘[(u’cache’, True), (u’indexes’, True), (u’logs’, True)]‘
debug: clean_operation(‘chromium’), options = ‘[(u’cache’, True), (u’cookies’, True), (u’history’, True), (u’current_session’, True)]'
debug: clean_operation(‘elinks’), options = ‘[(u’history’, True)]'
debug: clean_operation(‘emesene’), options = ‘[(u’logs’, True)]'
debug: clean_operation(‘epiphany’), options = '[(‘cache’, True), (‘cookies’, True), (‘download_history’, True), (‘passwords’, True), (‘places’, True)]'
debug: clean_operation(‘exaile’), options = 'None’
debug: clean_operation(‘firefox’), options = '[(‘cache’, True), (‘cookies’, True), (‘download_history’, True), (‘forms’, True), (‘url_history’, True), (‘passwords’, True), (‘places’, True), (‘session_restore’, True), (‘vacuum’, True)]'
debug: clean_operation(‘flash’), options = 'None’
debug: clean_operation(‘gimp’), options = 'None’
debug: clean_operation(‘gl-117’), options = ‘[(u’log’, True)]'
debug: clean_operation(‘googleearth’), options = ‘None’
debug: clean_operation(‘hippo_opensim_viewer’), options = ‘[(u’Cache’, True), (u’Logs’, True)]'
debug: clean_operation(‘java’), options = ‘[(u’Cache’, True)]'
debug: clean_operation(‘kde’), options = '[(‘cache’, True), (‘tmp’, True)]'
debug: clean_operation(‘midnightcommander’), options = ‘[(u’history’, True)]'
debug: clean_operation(‘thumbnails’), options = 'None’
debug: clean_operation(‘openofficeorg’), options = '[(‘cache’, True), (‘recent_documents’, True)]'
debug: clean_operation(‘opera’), options = '[(‘cache’, True), (‘cookies’, True)]'
debug: clean_operation(‘realplayer’), options = ‘[(u’cookies’, True)]'
debug: clean_operation(‘recoll’), options = ‘[(u’index’, True)]'
debug: clean_operation(‘rhythmbox’), options = ‘[(u’online_databases’, True)]'
debug: clean_operation(‘rpmbuild’), options = ‘None’
debug: clean_operation(‘secondlife_viewer’), options = ‘[(u’Cache’, True), (u’Logs’, True)]'
debug: clean_operation(‘skype’), options = 'None’
debug: clean_operation(‘system’), options = '[(‘apt-autoclean’, True), (‘desktop_entry’, True), (‘cache’, True), (‘clipboard’, True), (‘tmp’, True), (‘rotated_logs’, True), (‘localizations’, True), (‘yum’, True), (‘recent_documents’, True), (‘trash’, True)]'
Warning: invalid path ‘calendar.lotr’ where expecting a locale
Warning: invalid path ‘calendar.freebsd’ where expecting a locale
Warning: invalid path ‘calendar.australia’ where expecting a locale
Warning: invalid path ‘calendar.world’ where expecting a locale
Warning: invalid path ‘calendar.discordian’ where expecting a locale
Warning: invalid path ‘calendar.belgium’ where expecting a locale
Warning: invalid path ‘calendar.debian’ where expecting a locale
Warning: invalid path ‘calendar.birthday’ where expecting a locale
Warning: invalid path ‘calendar.christian’ where expecting a locale
Warning: invalid path ‘calendar.history’ where expecting a locale
Warning: invalid path ‘calendar.all’ where expecting a locale
Warning: invalid path ‘calendar.german’ where expecting a locale
Warning: invalid path ‘calendar.newzealand’ where expecting a locale
Warning: invalid path ‘calendar.computer’ where expecting a locale
Warning: invalid path ‘calendar.holiday’ where expecting a locale
Warning: invalid path ‘calendar.pagan’ where expecting a locale
Warning: invalid path ‘calendar.croatian’ where expecting a locale
Warning: invalid path ‘calendar.french’ where expecting a locale
Warning: invalid path ‘calendar.judaic’ where expecting a locale
Warning: invalid path ‘calendar.eu’ where expecting a locale
Warning: invalid path ‘calendar.southafrica’ where expecting a locale
Warning: invalid path ‘calendar.argentina’ where expecting a locale
Warning: invalid path ‘calendar.ubuntu’ where expecting a locale
Warning: invalid path ‘calendar.usholiday’ where expecting a locale
Warning: invalid path ‘calendar.music’ where expecting a locale
Warning: invalid path ‘calendar.russian’ where expecting a locale
Warning: invalid path ‘thunar.css’ where expecting a locale
info: removing '/var/log/dmesg.0’
info: removing '/var/log/gdm/:0.log.1’
info: removing '/var/log/Xorg.0.log.old’
info: removing '/tmp/libgksu-dM6y44/.Xauthority’
info: removing '/tmp/libgksu-dM6y44/.Xauthority.tmp’
Exception while getting running operation ‘system’: 'Exécutable non trouvé : yum’
Traceback (most recent call last):
File “/usr/bin/bleachbit”, line 448, in clean_operation
for ret in backends[operation].other_cleanup(really_delete):
File “/usr/share/bleachbit/CleanerBackend.py”, line 705, in other_cleanup
bytes = Unix.yum_clean()
File “/usr/share/bleachbit/Unix.py”, line 469, in yum_clean
raise RuntimeError((‘Executable not found: %s’) % ‘yum’)
RuntimeError: Exécutable non trouvé : yum
debug: clean_operation(‘transmission’), options = 'None’
debug: clean_operation(‘tremulous’), options = ‘[(u’cache’, True)]‘
debug: clean_operation(‘vim’), options = ‘[(u’history’, True)]‘
debug: clean_operation(‘vuze’), options = ‘[(u’cache’, True), (u’tmp’, True), (u’logs’, True)]'
debug: clean_operation(‘wine’), options = ‘[(u’tmp’, True)]'
debug: clean_operation(‘winetricks’), options = 'None’
debug: clean_operation(‘xchat’), options = ‘None’
debug: clean_operation(‘xchat’), options = 'None’
File “/usr/share/bleachbit/CleanerBackend.py”, line 690, in other_cleanup
bytes = Unix.apt_autoclean()
File “/usr/share/bleachbit/Unix.py”, line 342, in apt_autoclean
raise RuntimeError(line)
RuntimeError: E: Impossible d’ouvrir le fichier verrou /var/cache/apt/archives/lock - open (13 Permission non accordée)
info: removing '/home/val/.cache/Thunar/thumbnailers.cache’
info: removing '/home/val/.cache/Thunar/metafile.tdb’
info: removing '/home/val/.cache/Thunar’
info: removing '/home/val/.recently-used.xbel’
Exception while getting running operation ‘system’: 'E: Impossible d’ouvrir le fichier verrou /var/cache/apt/archives/lock - open (13 Permission non accordée)'
2243 (:0.0) 08:57:38 [0] add_icon(): 0x180000c: icon added as visible
ERROR: meta.c (179): wmf_header_read: this isn’t a wmf file
2243 (:0.0) 08:59:47 [0] remove_icon(): 0x180000c: icon removed
(lxappearance:4410): Gtk-WARNING **: Error loading theme icon ‘gtk-go-back-ltr’ for stock: Impossible d’ouvrir le fichier « /usr/share/icons/black-white_2-Style/scalable/actions/gtk-go-back-ltr.png » : Aucun fichier ou répertoire de ce type
(lxappearance:4410): Gtk-WARNING **: Error loading theme icon ‘gtk-go-forward-ltr’ for stock: Impossible d’ouvrir le fichier « /usr/share/icons/black-white_2-Style/scalable/actions/gtk-go-forward-ltr.png » : Aucun fichier ou répertoire de ce type
(lxappearance:4410): Gtk-WARNING **: Error loading theme icon ‘gtk-stop’ for stock: Impossible d’ouvrir le fichier « /usr/share/icons/black-white_2-Style/scalable/actions/gtk-stop.png » : Aucun fichier ou répertoire de ce type
(lxappearance:4410): Gtk-WARNING **: Error loading theme icon ‘gtk-find’ for stock: Impossible d’ouvrir le fichier « /usr/share/icons/black-white_2-Style/scalable/actions/gtk-find.png » : Aucun fichier ou répertoire de ce type
(lxappearance:4406): Gtk-WARNING **: Error loading theme icon ‘gtk-close’ for stock: Impossible d’ouvrir le fichier « /usr/share/icons/black-white_2-Style/scalable/actions/gtk-close.png » : Aucun fichier ou répertoire de ce type
(lxappearance:4406): Gtk-WARNING **: Error loading theme icon ‘gtk-add’ for stock: Impossible d’ouvrir le fichier « /usr/share/icons/black-white_2-Style/scalable/actions/gtk-add.png » : Aucun fichier ou répertoire de ce type
2243 (:0.0) 09:00:42 [0] add_icon(): 0x1600003: icon added as hidden
2243 (:0.0) 09:00:42 [0] icon_track_visibility_changes(): 0x1600003: showing
2243 (:0.0) 09:01:42 [0] add_icon(): 0x180000c: icon added as visible
2243 (:0.0) 09:02:38 [0] remove_icon(): 0x180000c: icon removed
2243 (:0.0) 09:03:14 [0] remove_icon(): 0x1600003: icon removed
2243 (:0.0) 09:04:26 [0] add_icon(): 0x160000c: icon added as visible
2243 (:0.0) 09:15:07 [0] remove_icon(): 0x160000c: icon removed
2243 (:0.0) 09:48:07 [0] add_icon(): 0x160000c: icon added as visible
2243 (:0.0) 09:53:10 [0] remove_icon(): 0x1400059: icon removed
2243 (:0.0) 09:54:18 [0] add_icon(): 0x140005d: icon added as hidden
2243 (:0.0) 09:54:18 [0] icon_track_visibility_changes(): 0x140005d: showing
2243 (:0.0) 09:55:40 [0] remove_icon(): 0x140005d: icon removed
2243 (:0.0) 09:55:44 [0] add_icon(): 0x1400071: icon added as hidden
2243 (:0.0) 09:55:44 [0] icon_track_visibility_changes(): 0x1400071: showing
2243 (:0.0) 09:56:13 [0] remove_icon(): 0x160000c: icon removed
2243 (:0.0) 10:08:18 [0] remove_icon(): 0x1400071: icon removed
2243 (:0.0) 10:23:50 [0] add_icon(): 0x1400071: icon added as hidden
2243 (:0.0) 10:23:50 [0] icon_track_visibility_changes(): 0x1400071: showing
2243 (:0.0) 10:33:00 [0] remove_icon(): 0x1400071: icon removed
2243 (:0.0) 10:33:01 [0] add_icon(): 0x140000c: icon added as visible
2243 (:0.0) 10:33:44 [0] add_icon(): 0x1600021: icon added as hidden
2243 (:0.0) 10:33:44 [0] icon_track_visibility_changes(): 0x1600021: showing
2243 (:0.0) 10:37:49 [0] remove_icon(): 0x140000c: icon removed
2243 (:0.0) 10:38:01 [0] icon_track_visibility_changes(): 0x1600021: hiding
2243 (:0.0) 10:38:01 [0] embedder_unembed(): failed to move 0x805a32b out of the tray
2243 (:0.0) 10:38:01 [0] remove_icon(): 0x1600021: icon removed
2243 (:0.0) 10:39:24 [0] add_icon(): 0x140000c: icon added as visible
** Message: GetValue variable 2 (2)[/code]
C’est grave ?
