Bonsoir à tous,
Je viens tout juste de faire une install avec le netinst. Quand j’essai de faire un upgrade il le fait bien, jusqu’a udev… Ou il me met à la fin :
After this operation, 631kB of additional disk space will be used.
Do you want to continue [Y/n]? y
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LANG = "fr_FR.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Ne peut initialiser LC_ALL ? la locale par d?faut: Aucun fichier ou dossier de ce type
Preconfiguring packages ...
(Reading database ... 89877 files and directories currently installed.)
Preparing to replace udev 0.125-7+lenny3 (using .../archives/udev_157-1_i386.deb) ...
LANGUAGE = (unset),
LC_ALL = (unset),
Since release 150, udev requires that support for the CONFIG_SYSFS_DEPRECATED
feature is disabled in the running kernel.
Please upgrade your kernel before or while upgrading udev.
AT YOUR OWN RISK, you can force the installation of this version of udev
WHICH DOES NOT WORK WITH YOUR RUNNING KERNEL AND WILL BREAK YOUR SYSTEM
AT THE NEXT REBOOT by creating the /etc/udev/kernel-upgrade file.
There is always a safer way to upgrade, do not try this unless you
understand what you are doing!
dpkg: error processing /var/cache/apt/archives/udev_157-1_i386.deb (--unpack):
subprocess new pre-installation script returned error exit status 1
LANGUAGE = (unset),
LC_ALL = (unset),
LANGUAGE = (unset),
LC_ALL = (unset),
Errors were encountered while processing:
Une fois ce message apparu, il fait completement planté mon linux. Je n’ai plus d’interface graphique etc…
De plus, j’ai essayé d’installer le 2.6.32 et la, le kernel ne se lance même pas juste après l’avoir choisi dans le grub. Comment pourrai-je faire svp ?
Je vous remercie d’avance.
