En faisant vlc -v voici la sortie de la commande :
gerard@gerard-BONEFISH:~$ vlc -v
VLC media player 2.0.6 Twoflower (revision 2.0.6-0-gbe9623c)
[0x8c608f0] main libvlc warning: This doesn’t look like a valid plugins cache
[0x8c608f0] main libvlc: Lancement de vlc avec l’interface par défaut. Utilisez « cvlc » pour démarrer VLC sans interface.
[NULL @ 0xb0f2dee0] Value 4686111960511545344,000000 for parameter ‘b’ out of range
[NULL @ 0xb0f2dee0] Value 4683532506232782848,000000 for parameter ‘ab’ out of range
[NULL @ 0xb0f2dee0] Value 4705844345939427328,000000 for parameter ‘bt’ out of range
[NULL @ 0xb0f2dee0] Value 4617315517961601024,000000 for parameter ‘me_method’ out of range
[NULL @ 0xb0f2dee0] Value 4622945017495814144,000000 for parameter ‘g’ out of range
[NULL @ 0xb0f2dee0] Value 4611686018427387904,000000 for parameter ‘qmin’ out of range
[NULL @ 0xb0f2dee0] Value 4629418941960159232,000000 for parameter ‘qmax’ out of range
[NULL @ 0xb0f2dee0] Value 4613937818241073152,000000 for parameter ‘qdiff’ out of range
[NULL @ 0xb0f2dee0] Value -4616189618054758400,000000 for parameter ‘wpredp’ out of range
[NULL @ 0xb0f2dee0] Value 4607182418800017408,000000 for parameter ‘bug’ out of range
[NULL @ 0xb0f2dee0] Value 4607182418800017408,000000 for parameter ‘er’ out of range
[NULL @ 0xb0f2dee0] Value 4607182418800017408,000000 for parameter ‘err_detect’ out of range
[NULL @ 0xb0f2dee0] Value 4613937818241073152,000000 for parameter ‘ec’ out of range
[NULL @ 0xb0f2dee0] Value 4620693217682128896,000000 for parameter ‘ildctcmp’ out of range
[NULL @ 0xb0f2dee0] Value 4620693217682128896,000000 for parameter ‘subq’ out of range
[NULL @ 0xb0f2dee0] Value 4696837138094751744,000000 for parameter ‘ibias’ out of range
[NULL @ 0xb0f2dee0] Value 4696837138094751744,000000 for parameter ‘pbias’ out of range
[NULL @ 0xb0f2dee0] Value 4642507528377204736,000000 for parameter ‘lmin’ out of range
[NULL @ 0xb0f2dee0] Value 4660262442142531584,000000 for parameter ‘lmax’ out of range
[NULL @ 0xb0f2dee0] Value 4696130710463840256,000000 for parameter ‘flags2’ out of range
[NULL @ 0xb0f2dee0] Value 4607182418800017408,000000 for parameter ‘threads’ out of range
[NULL @ 0xb0f2dee0] Value 4620693217682128896,000000 for parameter ‘nssew’ out of range
[NULL @ 0xb0f2dee0] Value -4586705114244317184,000000 for parameter ‘profile’ out of range
[NULL @ 0xb0f2dee0] Value -4586705114244317184,000000 for parameter ‘level’ out of range
[NULL @ 0xb0f2dee0] Value 4623507967449235456,000000 for parameter ‘skipcmp’ out of range
[NULL @ 0xb0f2dee0] Value 4642507528377204736,000000 for parameter ‘mblmin’ out of range
[NULL @ 0xb0f2dee0] Value 4660262442142531584,000000 for parameter ‘mblmax’ out of range
[NULL @ 0xb0f2dee0] Value 4643211215818981376,000000 for parameter ‘mepc’ out of range
[NULL @ 0xb0f2dee0] Value 4607182418800017408,000000 for parameter ‘bidir_refine’ out of range
[NULL @ 0xb0f2dee0] Value -4616189618054758400,000000 for parameter ‘cqp’ out of range
[NULL @ 0xb0f2dee0] Value 4627730092099895296,000000 for parameter ‘keyint_min’ out of range
[NULL @ 0xb0f2dee0] Value 4607182418800017408,000000 for parameter ‘refs’ out of range
[NULL @ 0xb0f2dee0] Value -4616189618054758400,000000 for parameter ‘directpred’ out of range
[NULL @ 0xb0f2dee0] Value 4618441417868443648,000000 for parameter ‘sc_factor’ out of range
[NULL @ 0xb0f2dee0] Value 4643211215818981376,000000 for parameter ‘mv0_threshold’ out of range
[NULL @ 0xb0f2dee0] Value 4630826316843712512,000000 for parameter ‘b_sensitivity’ out of range
[NULL @ 0xb0f2dee0] Value -4616189618054758400,000000 for parameter ‘compression_level’ out of range
[NULL @ 0xb0f2dee0] Value -4616189618054758400,000000 for parameter ‘min_prediction_order’ out of range
[NULL @ 0xb0f2dee0] Value -4616189618054758400,000000 for parameter ‘max_prediction_order’ out of range
[NULL @ 0xb0f2dee0] Value -4616189618054758400,000000 for parameter ‘prediction_order_method’ out of range
[NULL @ 0xb0f2dee0] Value -4616189618054758400,000000 for parameter ‘min_partition_order’ out of range
[NULL @ 0xb0f2dee0] Value -4616189618054758400,000000 for parameter ‘max_partition_order’ out of range
[NULL @ 0xb0f2dee0] Value 4607182418800017408,000000 for parameter ‘ticks_per_frame’ out of range
[NULL @ 0xb0f2dee0] Value 4611686018427387904,000000 for parameter ‘color_primaries’ out of range
[NULL @ 0xb0f2dee0] Value 4611686018427387904,000000 for parameter ‘color_trc’ out of range
[NULL @ 0xb0f2dee0] Value 4611686018427387904,000000 for parameter ‘colorspace’ out of range
[NULL @ 0xb0f2dee0] Value -4616189618054758400,000000 for parameter ‘aq_mode’ out of range
[NULL @ 0xb0f2dee0] Value -4616189618054758400,000000 for parameter ‘rc_lookahead’ out of range
[NULL @ 0xb0f2dee0] Value -4616189618054758400,000000 for parameter ‘lpc_type’ out of range
[NULL @ 0xb0f2dee0] Value -4616189618054758400,000000 for parameter ‘lpc_passes’ out of range
[NULL @ 0xb0f2dee0] Value 4613937818241073152,000000 for parameter ‘thread_type’ out of range
[NULL @ 0xb0f2dee0] Value -4616189618054758400,000000 for parameter ‘request_sample_fmt’ out of range
[0x8ffcf80] xcb_xv vout display error: no available XVideo adaptor
[0x9348ff0] main audio output warning: PTS is out of range (-8984), dropping buffer
[0x9348ff0] main audio output warning: PTS is out of range (-24819), dropping buffer
[0x8ffdc38] main video output warning: picture is too late to be displayed (missing 21 ms)
Dois-je le configurer mais comment ? Merci d’avance.
