Merci de prendre la mal a la racine.
Alors commençons :
└─ $ lspci -nn
00:00.0 Host bridge [0600]: Intel Corporation Core Processor DRAM Controller [8086:0040] (rev 02)
00:01.0 PCI bridge [0604]: Intel Corporation Core Processor PCI Express x16 Root Port [8086:0041] (rev 02)
00:16.0 Communication controller [0780]: Intel Corporation 5 Series/3400 Series Chipset HECI Controller [8086:3b64] (rev 06)
00:16.3 Serial controller [0700]: Intel Corporation 5 Series/3400 Series Chipset KT Controller [8086:3b67] (rev 06)
00:19.0 Ethernet controller [0200]: Intel Corporation 82578DM Gigabit Network Connection [8086:10ef] (rev 06)
00:1a.0 USB controller [0c03]: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller [8086:3b3c] (rev 06)
00:1b.0 Audio device [0403]: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio [8086:3b56] (rev 06)
00:1d.0 USB controller [0c03]: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller [8086:3b34] (rev 06)
00:1e.0 PCI bridge [0604]: Intel Corporation 82801 PCI Bridge [8086:244e] (rev a6)
00:1f.0 ISA bridge [0601]: Intel Corporation 5 Series Chipset LPC Interface Controller [8086:3b0a] (rev 06)
00:1f.2 IDE interface [0101]: Intel Corporation 5 Series/3400 Series Chipset 4 port SATA IDE Controller [8086:3b20] (rev 06)
00:1f.3 SMBus [0c05]: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller [8086:3b30] (rev 06)
00:1f.5 IDE interface [0101]: Intel Corporation 5 Series/3400 Series Chipset 2 port SATA IDE Controller [8086:3b26] (rev 06)
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GT218 [GeForce 310] [10de:0a63] (rev a2)
01:00.1 Audio device [0403]: NVIDIA Corporation High Definition Audio Controller [10de:0be3] (rev a1)
ff:00.0 Host bridge [0600]: Intel Corporation Core Processor QuickPath Architecture Generic Non-core Registers [8086:2c61] (rev 02)
ff:00.1 Host bridge [0600]: Intel Corporation Core Processor QuickPath Architecture System Address Decoder [8086:2d01] (rev 02)
ff:02.0 Host bridge [0600]: Intel Corporation Core Processor QPI Link 0 [8086:2d10] (rev 02)
ff:02.1 Host bridge [0600]: Intel Corporation Core Processor QPI Physical 0 [8086:2d11] (rev 02)
ff:02.2 Host bridge [0600]: Intel Corporation Core Processor Reserved [8086:2d12] (rev 02)
ff:02.3 Host bridge [0600]: Intel Corporation Core Processor Reserved [8086:2d13] (rev 02)
└─ $ ll /dev/
Display all 159 possibilities? (y or n)
autofs fb0 loop5 ptmx stderr tty19 tty33 tty48 tty62 vcs5
block/ fd/ loop6 pts/ stdin tty2 tty34 tty49 tty63 vcs6
bsg/ full loop7 random stdout tty20 tty35 tty5 tty7 vcs7
btrfs-control fuse loop-control root tpm0 tty21 tty36 tty50 tty8 vcsa
bus/ gpmctl MAKEDEV rtc tty tty22 tty37 tty51 tty9 vcsa1
cdrom hidraw0 mapper/ rtc0 tty0 tty23 tty38 tty52 ttyS0 vcsa2
cdrw hidraw1 mcelog sda tty1 tty24 tty39 tty53 ttyS1 vcsa3
char/ hpet mem sda1 tty10 tty25 tty4 tty54 ttyS2 vcsa4
console input/ net/ sda2 tty11 tty26 tty40 tty55 ttyS3 vcsa5
core kmsg network_latency sda3 tty12 tty27 tty41 tty56 uinput vcsa6
cpu/ log network_throughput sg0 tty13 tty28 tty42 tty57 urandom vcsa7
cpu_dma_latency loop0 null sg1 tty14 tty29 tty43 tty58 vcs vga_arbiter
disk/ loop1 oldmem shm/ tty15 tty3 tty44 tty59 vcs1 watchdog
dri/ loop2 port snapshot tty16 tty30 tty45 tty6 vcs2 xconsole
dvd loop3 ppp snd/ tty17 tty31 tty46 tty60 vcs3 zero
dvdrw loop4 psaux sr0 tty18 tty32 tty47 tty61 vcs4
Pour les erreurs au boot, effectivement j’ai un FAIL rouge lors du démarrage (il m’indique que aucun module est installé pour Open Sound System ).
Impossible de retrouver (grep) la ligne dans le dmesg, je me permet de vous le laisser tel quel :
└─ $ dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.2.0-4-686-pae (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP Debian 3.2.41-2+deb7u2
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009c000 (usable)
[ 0.000000] BIOS-e820: 000000000009c000 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000bf54f000 (usable)
[ 0.000000] BIOS-e820: 00000000bf54f000 - 00000000bf597000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000bf597000 - 00000000bf5a2000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000bf5a2000 - 00000000bf5a6000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000bf5a6000 - 00000000bf5cf000 (reserved)
[ 0.000000] BIOS-e820: 00000000bf5cf000 - 00000000bf5d1000 (usable)
[ 0.000000] BIOS-e820: 00000000bf5d1000 - 00000000bf5f2000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000bf5f2000 - 00000000bf602000 (reserved)
[ 0.000000] BIOS-e820: 00000000bf602000 - 00000000bf60c000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000bf60c000 - 00000000bf60e000 (reserved)
[ 0.000000] BIOS-e820: 00000000bf60e000 - 00000000bf61f000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000bf61f000 - 00000000bf647000 (reserved)
[ 0.000000] BIOS-e820: 00000000bf647000 - 00000000bf68a000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000bf68a000 - 00000000bf800000 (usable)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed40000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 0000000138000000 (usable)
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.6 present.
[ 0.000000] DMI: LENOVO 5554W3F/ , BIOS 5JKT49AUS 08/27/2010
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x138000 max_arch_pfn = 0x1000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-DFFFF uncachable
[ 0.000000] E0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F00000000 write-back
[ 0.000000] 1 base 100000000 mask FC0000000 write-back
[ 0.000000] 2 base 0C0000000 mask FC0000000 uncachable
[ 0.000000] 3 base 138000000 mask FF8000000 uncachable
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000c0000000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00fcd30] fcd30
[ 0.000000] initial memory mapped : 0 - 01a00000
[ 0.000000] Base memory trampoline at [c0098000] 98000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000379fe000
[ 0.000000] 0000000000 - 0000200000 page 4k
[ 0.000000] 0000200000 - 0037800000 page 2M
[ 0.000000] 0037800000 - 00379fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 379fe000 @ 19f9000-1a00000
[ 0.000000] RAMDISK: 36c00000 - 375f8000
[ 0.000000] ACPI: RSDP 000f0410 00024 (v02 LENOVO)
[ 0.000000] ACPI: XSDT bf597088 00064 (v01 LENOVO TC-5J 00000131 AMI 00010013)
[ 0.000000] ACPI: FACP bf5a0ac8 000F4 (v03 LENOVO TC-5J 00000131 AMI 00010013)
[ 0.000000] ACPI Warning: 32/64 FACS address mismatch in FADT - two FACS tables! (20110623/tbfadt-365)
[ 0.000000] ACPI Warning: 32/64X FACS address mismatch in FADT - 0xBF609E40/0x00000000BF609E80, using 32 (20110623/tbfadt-489)
[ 0.000000] ACPI: DSDT bf597180 09947 (v02 LENOVO TC-5J 00000131 INTL 20051117)
[ 0.000000] ACPI: FACS bf609e40 00040
[ 0.000000] ACPI: APIC bf5a0bc0 00072 (v01 LENOVO TC-5J 00000131 AMI 00010013)
[ 0.000000] ACPI: SSDT bf5a0c38 0014E (v01 LENOVO TC-5J 00000131 MSFT 03000001)
[ 0.000000] ACPI: MCFG bf5a0d88 0003C (v01 LENOVO TC-5J 00000131 MSFT 00000097)
[ 0.000000] ACPI: SLIC bf5a0dc8 00176 (v01 LENOVO TC-5J 00000131 AMI 00010013)
[ 0.000000] ACPI: HPET bf5a0f40 00038 (v01 LENOVO TC-5J 00000131 AMI. 00000003)
[ 0.000000] ACPI: ASF! bf5a0f78 000A0 (v32 LENOVO TC-5J 00000131 TFSM 000F4240)
[ 0.000000] ACPI: TCPA bf5a1018 00032 (v02 LENOVO TC-5J 00000131 MSFT 01000013)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 4102MB HIGHMEM available.
[ 0.000000] 889MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 379fe000
[ 0.000000] low ram: 0 - 379fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000379fe
[ 0.000000] HighMem 0x000379fe -> 0x00138000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[5] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009c
[ 0.000000] 0: 0x00000100 -> 0x000bf54f
[ 0.000000] 0: 0x000bf5cf -> 0x000bf5d1
[ 0.000000] 0: 0x000bf68a -> 0x000bf800
[ 0.000000] 0: 0x00100000 -> 0x00138000
[ 0.000000] On node 0 totalpages: 1013331
[ 0.000000] free_area_init_node: node 0, pgdat c1412600, node_mem_map f4500200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3948 pages, LIFO batch:0
[ 0.000000] Normal zone: 1748 pages used for memmap
[ 0.000000] Normal zone: 221994 pages, LIFO batch:31
[ 0.000000] HighMem zone: 8205 pages used for memmap
[ 0.000000] HighMem zone: 777404 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x04] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x05] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x00] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009c000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at bf800000 (gap: bf800000:20800000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 14 pages/cpu @f79b3000 s33280 r0 d24064 u57344
[ 0.000000] pcpu-alloc: s33280 r0 d24064 u57344 alloc=14*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1003346
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-686-pae root=UUID=5a5c258b-b5df-44ae-8bd5-e309658f58d7 ro quiet
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] Initializing HighMem for node 0 (000379fe:00138000)
[ 0.000000] Memory: 3996852k/5111808k available (2847k kernel code, 56472k reserved, 1352k data, 416k init, 3142436k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xffd36000 - 0xfffff000 (2852 kB)
[ 0.000000] pkmap : 0xffa00000 - 0xffc00000 (2048 kB)
[ 0.000000] vmalloc : 0xf81fe000 - 0xff9fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf79fe000 ( 889 MB)
[ 0.000000] .init : 0xc141a000 - 0xc1482000 ( 416 kB)
[ 0.000000] .data : 0xc12c7e80 - 0xc1419f40 (1352 kB)
[ 0.000000] .text : 0xc1000000 - 0xc12c7e80 (2847 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f4006000 soft=f4008000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 3059.373 MHz processor.
[ 0.000001] Calibrating delay loop (skipped), value calculated using timer frequency.. 6118.74 BogoMIPS (lpj=12237492)
[ 0.000004] pid_max: default: 32768 minimum: 301
[ 0.000028] Security Framework initialized
[ 0.000032] AppArmor: AppArmor disabled by boot time parameter
[ 0.000043] Mount-cache hash table entries: 512
[ 0.000127] Initializing cgroup subsys cpuacct
[ 0.000131] Initializing cgroup subsys memory
[ 0.000137] Initializing cgroup subsys devices
[ 0.000139] Initializing cgroup subsys freezer
[ 0.000140] Initializing cgroup subsys net_cls
[ 0.000142] Initializing cgroup subsys blkio
[ 0.000146] Initializing cgroup subsys perf_event
[ 0.000167] CPU: Physical Processor ID: 0
[ 0.000168] CPU: Processor Core ID: 0
[ 0.000172] mce: CPU supports 9 MCE banks
[ 0.000182] CPU0: Thermal monitoring enabled (TM1)
[ 0.000188] using mwait in idle threads.
[ 0.000522] ACPI: Core revision 20110623
[ 0.003629] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.004045] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.043645] CPU0: Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz stepping 02
[ 0.151397] Performance Events: PEBS fmt1+, Westmere events, Intel PMU driver.
[ 0.151403] ... version: 3
[ 0.151404] ... bit width: 48
[ 0.151405] ... generic registers: 4
[ 0.151406] ... value mask: 0000ffffffffffff
[ 0.151407] ... max period: 000000007fffffff
[ 0.151409] ... fixed-purpose events: 3
[ 0.151410] ... event mask: 000000070000000f
[ 0.151544] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.151624] CPU 1 irqstacks, hard=f40d4000 soft=f40d6000
[ 0.151625] Booting Node 0, Processors #1
[ 0.151627] smpboot cpu 1: start_ip = 98000
[ 0.162026] Initializing CPU#1
[ 0.259273] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.259370] CPU 2 irqstacks, hard=f4104000 soft=f4106000
[ 0.259371] #2
[ 0.259372] smpboot cpu 2: start_ip = 98000
[ 0.269513] Initializing CPU#2
[ 0.366974] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.367065] CPU 3 irqstacks, hard=f4116000 soft=f4118000
[ 0.367067] #3 Ok.
[ 0.367068] smpboot cpu 3: start_ip = 98000
[ 0.377205] Initializing CPU#3
[ 0.474795] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.474824] Brought up 4 CPUs
[ 0.474825] Total of 4 processors activated (24472.33 BogoMIPS).
[ 0.477408] devtmpfs: initialized
[ 0.477525] PM: Registering ACPI NVS region at bf54f000 (294912 bytes)
[ 0.477533] PM: Registering ACPI NVS region at bf5a2000 (16384 bytes)
[ 0.477534] PM: Registering ACPI NVS region at bf5d1000 (135168 bytes)
[ 0.477539] PM: Registering ACPI NVS region at bf602000 (40960 bytes)
[ 0.477541] PM: Registering ACPI NVS region at bf60e000 (69632 bytes)
[ 0.477543] PM: Registering ACPI NVS region at bf647000 (274432 bytes)
[ 0.477655] print_constraints: dummy:
[ 0.477695] NET: Registered protocol family 16
[ 0.477763] ACPI: bus type pci registered
[ 0.477811] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.477814] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.477815] PCI: Using MMCONFIG for extended config space
[ 0.477816] PCI: Using configuration type 1 for base access
[ 0.478292] bio: create slab <bio-0> at 0
[ 0.478356] ACPI: Added _OSI(Module Device)
[ 0.478357] ACPI: Added _OSI(Processor Device)
[ 0.478359] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.478361] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.479264] ACPI: EC: Look up EC in DSDT
[ 0.480342] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.483649] ACPI: SSDT bf602c18 0038C (v01 AMI IST 00000001 MSFT 03000001)
[ 0.483905] ACPI: Dynamic OEM Table Load:
[ 0.483907] ACPI: SSDT (null) 0038C (v01 AMI IST 00000001 MSFT 03000001)
[ 0.484414] ACPI: Interpreter enabled
[ 0.484419] ACPI: (supports S0 S3 S4 S5)
[ 0.484433] ACPI: Using IOAPIC for interrupt routing
[ 0.484616] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.489437] ACPI: No dock devices found.
[ 0.489439] HEST: Table not found.
[ 0.489441] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.489540] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.489618] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.489620] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.489622] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.489624] pci_root PNP0A08:00: host bridge window [mem 0xc0000000-0xffffffff]
[ 0.489633] pci 0000:00:00.0: [8086:0040] type 0 class 0x000600
[ 0.489664] pci 0000:00:01.0: [8086:0041] type 1 class 0x000604
[ 0.489690] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.489727] pci 0000:00:16.0: [8086:3b64] type 0 class 0x000780
[ 0.489754] pci 0000:00:16.0: reg 10: [mem 0xfb149000-0xfb14900f 64bit]
[ 0.489843] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.489867] pci 0000:00:16.3: [8086:3b67] type 0 class 0x000700
[ 0.489883] pci 0000:00:16.3: reg 10: [io 0xf100-0xf107]
[ 0.489892] pci 0000:00:16.3: reg 14: [mem 0xfb148000-0xfb148fff]
[ 0.489991] pci 0000:00:19.0: [8086:10ef] type 0 class 0x000200
[ 0.490007] pci 0000:00:19.0: reg 10: [mem 0xfb120000-0xfb13ffff]
[ 0.490015] pci 0000:00:19.0: reg 14: [mem 0xfb147000-0xfb147fff]
[ 0.490023] pci 0000:00:19.0: reg 18: [io 0xf020-0xf03f]
[ 0.490080] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.490102] pci 0000:00:1a.0: [8086:3b3c] type 0 class 0x000c03
[ 0.490121] pci 0000:00:1a.0: reg 10: [mem 0xfb146000-0xfb1463ff]
[ 0.490201] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.490225] pci 0000:00:1b.0: [8086:3b56] type 0 class 0x000403
[ 0.490240] pci 0000:00:1b.0: reg 10: [mem 0xfb140000-0xfb143fff 64bit]
[ 0.490303] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.490328] pci 0000:00:1d.0: [8086:3b34] type 0 class 0x000c03
[ 0.490347] pci 0000:00:1d.0: reg 10: [mem 0xfb145000-0xfb1453ff]
[ 0.490428] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.490448] pci 0000:00:1e.0: [8086:244e] type 1 class 0x000604
[ 0.490509] pci 0000:00:1f.0: [8086:3b0a] type 0 class 0x000601
[ 0.490619] pci 0000:00:1f.2: [8086:3b20] type 0 class 0x000101
[ 0.490640] pci 0000:00:1f.2: reg 10: [io 0xf0f0-0xf0f7]
[ 0.490649] pci 0000:00:1f.2: reg 14: [io 0xf0e0-0xf0e3]
[ 0.490657] pci 0000:00:1f.2: reg 18: [io 0xf0d0-0xf0d7]
[ 0.490665] pci 0000:00:1f.2: reg 1c: [io 0xf0c0-0xf0c3]
[ 0.490673] pci 0000:00:1f.2: reg 20: [io 0xf0b0-0xf0bf]
[ 0.490681] pci 0000:00:1f.2: reg 24: [io 0xf0a0-0xf0af]
[ 0.490727] pci 0000:00:1f.3: [8086:3b30] type 0 class 0x000c05
[ 0.490741] pci 0000:00:1f.3: reg 10: [mem 0xfb144000-0xfb1440ff 64bit]
[ 0.490761] pci 0000:00:1f.3: reg 20: [io 0xf000-0xf01f]
[ 0.490792] pci 0000:00:1f.5: [8086:3b26] type 0 class 0x000101
[ 0.490808] pci 0000:00:1f.5: reg 10: [io 0xf090-0xf097]
[ 0.490817] pci 0000:00:1f.5: reg 14: [io 0xf080-0xf083]
[ 0.490825] pci 0000:00:1f.5: reg 18: [io 0xf070-0xf077]
[ 0.490833] pci 0000:00:1f.5: reg 1c: [io 0xf060-0xf063]
[ 0.490839] pci 0000:00:1f.5: reg 20: [io 0xf050-0xf05f]
[ 0.490845] pci 0000:00:1f.5: reg 24: [io 0xf040-0xf04f]
[ 0.490918] pci 0000:01:00.0: [10de:0a63] type 0 class 0x000300
[ 0.490926] pci 0000:01:00.0: reg 10: [mem 0xfa000000-0xfaffffff]
[ 0.490934] pci 0000:01:00.0: reg 14: [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.490943] pci 0000:01:00.0: reg 1c: [mem 0xd0000000-0xd1ffffff 64bit pref]
[ 0.490949] pci 0000:01:00.0: reg 24: [io 0xe000-0xe07f]
[ 0.490954] pci 0000:01:00.0: reg 30: [mem 0xfb000000-0xfb07ffff pref]
[ 0.490997] pci 0000:01:00.1: [10de:0be3] type 0 class 0x000403
[ 0.491005] pci 0000:01:00.1: reg 10: [mem 0xfb080000-0xfb083fff]
[ 0.491078] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.491080] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.491083] pci 0000:00:01.0: bridge window [mem 0xfa000000-0xfb0fffff]
[ 0.491085] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.491137] pci 0000:00:1e.0: PCI bridge to [bus 02-02] (subtractive decode)
[ 0.491146] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.491148] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.491150] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.491152] pci 0000:00:1e.0: bridge window [mem 0xc0000000-0xffffffff] (subtractive decode)
[ 0.491160] pci_bus 0000:00: on NUMA node 0
[ 0.491162] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.491325] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR20._PRT]
[ 0.491434] pci0000:00: Requesting ACPI _OSC control (0x1d)
[ 0.491544] pci0000:00: ACPI _OSC control (0x1d) granted
[ 0.495184] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.495217] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.495249] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.495281] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.495313] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.495345] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0
[ 0.495377] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 7 10 11 12 14 15)
[ 0.495409] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *7 10 11 12 14 15)
[ 0.495485] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.495487] vgaarb: loaded
[ 0.495488] vgaarb: bridge control possible 0000:01:00.0
[ 0.495515] PCI: Using ACPI for IRQ routing
[ 0.500569] PCI: Discovered peer bus ff
[ 0.500595] pci 0000:ff:00.0: [8086:2c61] type 0 class 0x000600
[ 0.500610] pci 0000:ff:00.1: [8086:2d01] type 0 class 0x000600
[ 0.500626] pci 0000:ff:02.0: [8086:2d10] type 0 class 0x000600
[ 0.500640] pci 0000:ff:02.1: [8086:2d11] type 0 class 0x000600
[ 0.500654] pci 0000:ff:02.2: [8086:2d12] type 0 class 0x000600
[ 0.500667] pci 0000:ff:02.3: [8086:2d13] type 0 class 0x000600
[ 0.500800] PCI: pci_cache_line_size set to 64 bytes
[ 0.500848] reserve RAM buffer: 000000000009c000 - 000000000009ffff
[ 0.500850] reserve RAM buffer: 00000000bf54f000 - 00000000bfffffff
[ 0.500852] reserve RAM buffer: 00000000bf5d1000 - 00000000bfffffff
[ 0.500854] reserve RAM buffer: 00000000bf800000 - 00000000bfffffff
[ 0.500934] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.500938] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.502949] Switching to clocksource hpet
[ 0.504083] pnp: PnP ACPI init
[ 0.504092] ACPI: bus type pnp registered
[ 0.504133] pnp 00:00: [bus 00-ff]
[ 0.504135] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.504137] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.504139] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.504140] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.504142] pnp 00:00: [mem 0x00000000 window]
[ 0.504143] pnp 00:00: [mem 0xc0000000-0xffffffff window]
[ 0.504174] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.504209] pnp 00:01: [mem 0xfed14000-0xfed19fff]
[ 0.504211] pnp 00:01: [mem 0xe0000000-0xefffffff]
[ 0.504212] pnp 00:01: [mem 0xfed90000-0xfed93fff]
[ 0.504214] pnp 00:01: [mem 0xfed20000-0xfed3ffff]
[ 0.504215] pnp 00:01: [mem 0xfee00000-0xfee0ffff]
[ 0.504244] system 00:01: [mem 0xfed14000-0xfed19fff] has been reserved
[ 0.504246] system 00:01: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.504248] system 00:01: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.504251] system 00:01: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.504253] system 00:01: [mem 0xfee00000-0xfee0ffff] has been reserved
[ 0.504255] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.504301] pnp 00:02: [io 0x0000-0xffffffffffffffff disabled]
[ 0.504303] pnp 00:02: [io 0x0a00-0x0a7f]
[ 0.504330] system 00:02: [io 0x0a00-0x0a7f] has been reserved
[ 0.504332] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.504505] pnp 00:03: [dma 4]
[ 0.504507] pnp 00:03: [io 0x0000-0x000f]
[ 0.504508] pnp 00:03: [io 0x0081-0x0083]
[ 0.504509] pnp 00:03: [io 0x0087]
[ 0.504511] pnp 00:03: [io 0x0089-0x008b]
[ 0.504512] pnp 00:03: [io 0x008f]
[ 0.504513] pnp 00:03: [io 0x00c0-0x00df]
[ 0.504531] pnp 00:03: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.504538] pnp 00:04: [io 0x0070-0x0071]
[ 0.504544] pnp 00:04: [irq 8]
[ 0.504562] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.504568] pnp 00:05: [io 0x0061]
[ 0.504585] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.504600] pnp 00:06: [io 0x0010-0x001f]
[ 0.504601] pnp 00:06: [io 0x0022-0x003f]
[ 0.504603] pnp 00:06: [io 0x0044-0x005f]
[ 0.504604] pnp 00:06: [io 0x0062-0x0063]
[ 0.504605] pnp 00:06: [io 0x0065-0x006f]
[ 0.504607] pnp 00:06: [io 0x0072-0x007f]
[ 0.504608] pnp 00:06: [io 0x0080]
[ 0.504609] pnp 00:06: [io 0x0084-0x0086]
[ 0.504610] pnp 00:06: [io 0x0088]
[ 0.504612] pnp 00:06: [io 0x008c-0x008e]
[ 0.504613] pnp 00:06: [io 0x0090-0x009f]
[ 0.504615] pnp 00:06: [io 0x00a2-0x00bf]
[ 0.504616] pnp 00:06: [io 0x00e0-0x00ef]
[ 0.504618] pnp 00:06: [io 0x04d0-0x04d1]
[ 0.504619] pnp 00:06: [mem 0x00000000-0xffffffffffffffff disabled]
[ 0.504654] system 00:06: [io 0x04d0-0x04d1] has been reserved
[ 0.504656] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.504663] pnp 00:07: [io 0x00f0-0x00ff]
[ 0.504667] pnp 00:07: [irq 13]
[ 0.504684] pnp 00:07: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.504869] pnp 00:08: [io 0x03f8-0x03ff]
[ 0.504874] pnp 00:08: [irq 4]
[ 0.504875] pnp 00:08: [dma 0 disabled]
[ 0.504917] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.505034] pnp 00:09: [mem 0xfed40000-0xfed44fff]
[ 0.505053] pnp 00:09: Plug and Play ACPI device, IDs PNP0c31 (active)
[ 0.505156] pnp 00:0a: [io 0x0400-0x047f]
[ 0.505158] pnp 00:0a: [io 0x1180-0x119f]
[ 0.505159] pnp 00:0a: [io 0x0500-0x057f]
[ 0.505161] pnp 00:0a: [mem 0x00000000-0x0009ffff]
[ 0.505162] pnp 00:0a: [mem 0xfed1c000-0xfed1ffff]
[ 0.505164] pnp 00:0a: [mem 0xfec00000-0xfecfffff]
[ 0.505165] pnp 00:0a: [mem 0xfed08000-0xfed08fff]
[ 0.505167] pnp 00:0a: [mem 0xff000000-0xffffffff]
[ 0.505168] pnp 00:0a: [mem 0xfed00400-0xfed13fff]
[ 0.505200] system 00:0a: [io 0x0400-0x047f] has been reserved
[ 0.505202] system 00:0a: [io 0x1180-0x119f] has been reserved
[ 0.505204] system 00:0a: [io 0x0500-0x057f] has been reserved
[ 0.505207] system 00:0a: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.505209] system 00:0a: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.505211] system 00:0a: [mem 0xfec00000-0xfecfffff] could not be reserved
[ 0.505213] system 00:0a: [mem 0xfed08000-0xfed08fff] has been reserved
[ 0.505215] system 00:0a: [mem 0xff000000-0xffffffff] has been reserved
[ 0.505218] system 00:0a: [mem 0xfed00400-0xfed13fff] could not be reserved
[ 0.505220] system 00:0a: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.505303] pnp 00:0b: [mem 0xfed00000-0xfed003ff]
[ 0.505332] pnp 00:0b: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.505455] pnp: PnP ACPI: found 12 devices
[ 0.505456] ACPI: ACPI bus type pnp unregistered
[ 0.505458] PnPBIOS: Disabled by ACPI PNP
[ 0.541695] PCI: max bus depth: 1 pci_try_num: 2
[ 0.541708] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.541710] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.541713] pci 0000:00:01.0: bridge window [mem 0xfa000000-0xfb0fffff]
[ 0.541716] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.541719] pci 0000:00:1e.0: PCI bridge to [bus 02-02]
[ 0.541735] pci 0000:00:01.0: setting latency timer to 64
[ 0.541740] pci 0000:00:1e.0: setting latency timer to 64
[ 0.541743] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.541745] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.541746] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.541748] pci_bus 0000:00: resource 7 [mem 0xc0000000-0xffffffff]
[ 0.541750] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.541751] pci_bus 0000:01: resource 1 [mem 0xfa000000-0xfb0fffff]
[ 0.541753] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.541755] pci_bus 0000:02: resource 4 [io 0x0000-0x0cf7]
[ 0.541756] pci_bus 0000:02: resource 5 [io 0x0d00-0xffff]
[ 0.541758] pci_bus 0000:02: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.541760] pci_bus 0000:02: resource 7 [mem 0xc0000000-0xffffffff]
[ 0.541761] pci_bus 0000:ff: resource 0 [io 0x0000-0xffff]
[ 0.541763] pci_bus 0000:ff: resource 1 [mem 0x00000000-0xfffffffff]
[ 0.541805] NET: Registered protocol family 2
[ 0.541847] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.541982] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.542468] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.542711] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.542712] TCP reno registered
[ 0.542715] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.542722] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.542801] NET: Registered protocol family 1
[ 0.582814] pci 0000:01:00.0: Boot video device
[ 0.582837] PCI: CLS 64 bytes, default 64
[ 0.582872] Unpacking initramfs...
[ 0.768698] Freeing initrd memory: 10208k freed
[ 0.770866] audit: initializing netlink socket (disabled)
[ 0.770875] type=2000 audit(1369119535.616:1): initialized
[ 0.781550] highmem bounce pool size: 64 pages
[ 0.781554] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.782276] VFS: Disk quotas dquot_6.5.2
[ 0.782299] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.782360] msgmni has been set to 1688
[ 0.782481] alg: No test for stdrng (krng)
[ 0.782502] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.782505] io scheduler noop registered
[ 0.782506] io scheduler deadline registered
[ 0.782518] io scheduler cfq registered (default)
[ 0.782580] pcieport 0000:00:01.0: setting latency timer to 64
[ 0.782603] pcieport 0000:00:01.0: irq 40 for MSI/MSI-X
[ 0.782661] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 0.782663] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 0.782665] pci 0000:01:00.1: Signaling PME through PCIe PME interrupt
[ 0.782667] pcie_pme 0000:00:01.0:pcie01: service driver pcie_pme loaded
[ 0.782679] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.782692] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.782694] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.782940] intel_idle: MWAIT substates: 0x1120
[ 0.782942] intel_idle: v0.4 model 0x25
[ 0.782943] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 0.782972] ERST: Table is not found!
[ 0.782973] GHES: HEST is not enabled!
[ 0.782982] isapnp: Scanning for PnP cards...
[ 1.135773] isapnp: No Plug & Play device found
[ 1.135821] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.156221] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.181997] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.221727] 0000:00:16.3: ttyS1 at I/O 0xf100 (irq = 17) is a 16550A
[ 1.221904] Linux agpgart interface v0.103
[ 1.222088] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.224862] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.224867] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.224971] mousedev: PS/2 mouse device common for all mice
[ 1.224996] rtc_cmos 00:04: RTC can wake from S4
[ 1.225098] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 1.225124] rtc0: alarms up to one year, y3k, 114 bytes nvram, hpet irqs
[ 1.225179] cpuidle: using governor ladder
[ 1.225245] cpuidle: using governor menu
[ 1.225391] TCP cubic registered
[ 1.225453] NET: Registered protocol family 10
[ 1.225929] Mobile IPv6
[ 1.225931] NET: Registered protocol family 17
[ 1.225934] Registering the dns_resolver key type
[ 1.225951] Using IPI No-Shortcut mode
[ 1.226294] PM: Hibernation image not present or could not be loaded.
[ 1.226301] registered taskstats version 1
[ 1.226855] rtc_cmos 00:04: setting system clock to 2013-05-21 06:58:56 UTC (1369119536)
[ 1.226900] Initializing network drop monitor service
[ 1.227011] Freeing unused kernel memory: 416k freed
[ 1.227201] Write protecting the kernel text: 2848k
[ 1.227253] Write protecting the kernel read-only data: 1096k
[ 1.227255] NX-protecting the kernel data: 3296k
[ 1.238158] udevd[57]: starting version 175
[ 1.250188] usbcore: registered new interface driver usbfs
[ 1.250209] usbcore: registered new interface driver hub
[ 1.250467] e1000e: Intel(R) PRO/1000 Network Driver - 1.5.1-k
[ 1.250469] e1000e: Copyright(c) 1999 - 2011 Intel Corporation.
[ 1.250511] e1000e 0000:00:19.0: setting latency timer to 64
[ 1.250603] e1000e 0000:00:19.0: irq 41 for MSI/MSI-X
[ 1.259255] SCSI subsystem initialized
[ 1.261675] usbcore: registered new device driver usb
[ 1.262031] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.271559] libata version 3.00 loaded.
[ 1.456696] e1000e 0000:00:19.0: eth0: (PCI Express:2.5GT/s:Width x1) 44:87:fc:f1:30:c7
[ 1.456699] e1000e 0000:00:19.0: eth0: Intel(R) PRO/1000 Network Connection
[ 1.456741] e1000e 0000:00:19.0: eth0: MAC: 9, PHY: 9, PBA No: FFFFFF-0FF
[ 1.456786] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 1.456790] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 1.456824] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 1.456849] ehci_hcd 0000:00:1a.0: debug port 2
[ 1.460771] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[ 1.460800] ehci_hcd 0000:00:1a.0: irq 16, io mem 0xfb146000
[ 1.472870] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 1.472901] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.472905] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.472909] usb usb1: Product: EHCI Host Controller
[ 1.472912] usb usb1: Manufacturer: Linux 3.2.0-4-686-pae ehci_hcd
[ 1.472915] usb usb1: SerialNumber: 0000:00:1a.0
[ 1.473134] hub 1-0:1.0: USB hub found
[ 1.473142] hub 1-0:1.0: 2 ports detected
[ 1.473212] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.473215] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 1.473222] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.473242] ehci_hcd 0000:00:1d.0: debug port 2
[ 1.477202] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 1.477213] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xfb145000
[ 1.492807] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.492880] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.492885] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.492888] usb usb2: Product: EHCI Host Controller
[ 1.492891] usb usb2: Manufacturer: Linux 3.2.0-4-686-pae ehci_hcd
[ 1.492894] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.493121] hub 2-0:1.0: USB hub found
[ 1.493127] hub 2-0:1.0: 2 ports detected
[ 1.493194] ata_piix 0000:00:1f.2: version 2.13
[ 1.493216] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.648459] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.648861] scsi0 : ata_piix
[ 1.649062] scsi1 : ata_piix
[ 1.649996] ata1: SATA max UDMA/133 cmd 0xf0f0 ctl 0xf0e0 bmdma 0xf0b0 irq 19
[ 1.650000] ata2: SATA max UDMA/133 cmd 0xf0d0 ctl 0xf0c0 bmdma 0xf0b8 irq 19
[ 1.650062] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 1.768190] Refined TSC clocksource calibration: 3058.999 MHz.
[ 1.768197] Switching to clocksource tsc
[ 1.784152] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[ 1.804095] ata_piix 0000:00:1f.5: SCR access via SIDPR is available but doesn't work
[ 1.804109] ata_piix 0000:00:1f.5: setting latency timer to 64
[ 1.804382] scsi2 : ata_piix
[ 1.804565] scsi3 : ata_piix
[ 1.805343] ata3: SATA max UDMA/133 cmd 0xf090 ctl 0xf080 bmdma 0xf050 irq 19
[ 1.805345] ata4: SATA max UDMA/133 cmd 0xf070 ctl 0xf060 bmdma 0xf058 irq 19
[ 1.916308] usb 1-1: New USB device found, idVendor=8087, idProduct=0020
[ 1.916313] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.916720] hub 1-1:1.0: USB hub found
[ 1.916921] hub 1-1:1.0: 6 ports detected
[ 2.027570] usb 2-1: new high-speed USB device number 2 using ehci_hcd
[ 2.159763] usb 2-1: New USB device found, idVendor=8087, idProduct=0020
[ 2.159768] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.160167] hub 2-1:1.0: USB hub found
[ 2.160377] hub 2-1:1.0: 8 ports detected
[ 2.430928] usb 2-1.1: new high-speed USB device number 3 using ehci_hcd
[ 2.522950] usb 2-1.1: New USB device found, idVendor=0409, idProduct=005a
[ 2.522955] usb 2-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.523348] hub 2-1.1:1.0: USB hub found
[ 2.523561] hub 2-1.1:1.0: 2 ports detected
[ 2.594558] usb 2-1.2: new low-speed USB device number 4 using ehci_hcd
[ 2.691838] usb 2-1.2: New USB device found, idVendor=413c, idProduct=2107
[ 2.691843] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.691847] usb 2-1.2: Product: Dell USB Entry Keyboard
[ 2.691850] usb 2-1.2: Manufacturer: DELL
[ 2.762192] usb 2-1.3: new low-speed USB device number 5 using ehci_hcd
[ 2.858445] usb 2-1.3: New USB device found, idVendor=046d, idProduct=c05a
[ 2.858451] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.858454] usb 2-1.3: Product: USB Optical Mouse
[ 2.858457] usb 2-1.3: Manufacturer: Logitech
[ 2.863245] input: DELL Dell USB Entry Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/input/input0
[ 2.863318] generic-usb 0003:413C:2107.0001: input,hidraw0: USB HID v1.10 Keyboard [DELL Dell USB Entry Keyboard] on usb-0000:00:1d.0-1.2/input0
[ 2.865569] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0/input/input1
[ 2.865653] generic-usb 0003:046D:C05A.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:1d.0-1.3/input0
[ 2.865663] usbcore: registered new interface driver usbhid
[ 2.865665] usbhid: USB HID core driver
[ 2.993439] ata2.01: failed to resume link (SControl 0)
[ 2.993514] ata1.01: failed to resume link (SControl 0)
[ 3.149137] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 3.149151] ata1.01: SATA link down (SStatus 0 SControl 0)
[ 3.149277] ata2.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 3.149290] ata2.01: SATA link down (SStatus 0 SControl 0)
[ 3.149300] ata2.01: link offline, clearing class 3 to NONE
[ 3.157374] ata2.00: ATAPI: HL-DT-STDVD-RAM GH60N, NY02, max UDMA/100
[ 3.157587] ata1.00: ATA-8: ST3250318AS, CC66, max UDMA/100
[ 3.157593] ata1.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 3.173338] ata2.00: configured for UDMA/100
[ 3.173597] ata1.00: configured for UDMA/100
[ 3.173930] scsi 0:0:0:0: Direct-Access ATA ST3250318AS CC66 PQ: 0 ANSI: 5
[ 3.182158] scsi 1:0:0:0: CD-ROM HL-DT-ST DVD-RAM GH60N NY02 PQ: 0 ANSI: 5
[ 3.185952] sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 3.186000] sd 0:0:0:0: [sda] Write Protect is off
[ 3.186002] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.186028] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.214506] sda: sda1 sda2 sda3
[ 3.215358] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.216684] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 3.216822] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 3.224006] sr0: scsi3-mmc drive: 40x/40x writer dvd-ram cd/rw xa/form2 cdda tray
[ 3.224009] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 3.224113] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 4.033315] PM: Starting manual resume from disk
[ 4.033318] PM: Hibernation image partition 8:3 present
[ 4.033319] PM: Looking for hibernation image.
[ 4.045200] PM: Image not found (code -22)
[ 4.045204] PM: Hibernation image not present or could not be loaded.
[ 4.080487] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.481130] udevd[391]: starting version 175
[ 6.062481] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 6.062487] ACPI: Power Button [PWRB]
[ 6.062540] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 6.062544] ACPI: Power Button [PWRF]
[ 6.066943] wmi: Mapper loaded
[ 6.303178] ACPI: Requesting acpi_cpufreq
[ 6.346006] input: PC Speaker as /devices/platform/pcspkr/input/input4
[ 6.350487] iTCO_vendor_support: vendor-support=0
[ 6.350796] tpm_tis 00:09: 1.2 TPM (device-id 0x0, rev-id 78)
[ 6.351243] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 6.351306] iTCO_wdt: Found a Q57 TCO device (Version=2, TCOBASE=0x0460)
[ 6.351507] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 6.413232] [drm] Initialized drm 1.1.0 20060810
[ 6.551779] nouveau 0000:01:00.0: setting latency timer to 64
[ 6.551804] [drm] nouveau 0000:01:00.0: Detected an NV50 generation card (0x0a8180a2)
[ 6.559302] [drm] nouveau 0000:01:00.0: Checking PRAMIN for VBIOS
[ 6.621597] [drm] nouveau 0000:01:00.0: ... appears to be valid
[ 6.621599] [drm] nouveau 0000:01:00.0: Using VBIOS from PRAMIN
[ 6.621601] [drm] nouveau 0000:01:00.0: BIT BIOS found
[ 6.621603] [drm] nouveau 0000:01:00.0: Bios version 70.18.3e.00
[ 6.621605] [drm] nouveau 0000:01:00.0: TMDS table version 2.0
[ 6.622023] [drm] nouveau 0000:01:00.0: MXM: no VBIOS data, nothing to do
[ 6.622026] [drm] nouveau 0000:01:00.0: DCB version 4.0
[ 6.622028] [drm] nouveau 0000:01:00.0: DCB outp 00: 02000300 00000000
[ 6.622031] [drm] nouveau 0000:01:00.0: DCB outp 01: 040113b6 0f200010
[ 6.622037] [drm] nouveau 0000:01:00.0: DCB outp 02: 04011372 00020010
[ 6.622041] [drm] nouveau 0000:01:00.0: DCB conn 00: 00000000
[ 6.622044] [drm] nouveau 0000:01:00.0: DCB conn 01: 00202146
[ 6.622051] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0xD2BF
[ 6.661744] [drm] nouveau 0000:01:00.0: 0xD562: Condition still not met after 20ms, skipping following opcodes
[ 6.681551] [drm] nouveau 0000:01:00.0: 0xD566: Condition still not met after 20ms, skipping following opcodes
[ 6.681578] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0xD726
[ 6.689267] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0xE255
[ 6.689277] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0xE26E
[ 6.731715] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0xE355
[ 6.731720] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table at offset 0xE3BA
[ 6.751525] [drm] nouveau 0000:01:00.0: 0xD133: Condition still not met after 20ms, skipping following opcodes
[ 6.756127] [TTM] Zone kernel: Available graphics memory: 432520 kiB
[ 6.756131] [TTM] Zone highmem: Available graphics memory: 2003738 kiB
[ 6.756135] [TTM] Initializing pool allocator
[ 6.756143] [TTM] Initializing DMA pool allocator
[ 6.756158] [drm] nouveau 0000:01:00.0: Detected 512MiB VRAM (DDR3)
[ 6.756168] mtrr: type mismatch for c0000000,10000000 old: write-back new: write-combining
[ 6.756184] [drm] nouveau 0000:01:00.0: 512 MiB GART (aperture)
[ 6.818731] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 6.818733] [drm] No driver support for vblank timestamp query.
[ 7.540264] [drm] nouveau 0000:01:00.0: 3 available performance level(s)
[ 7.540267] [drm] nouveau 0000:01:00.0: 0: core 135MHz shader 270MHz memory 135MHz voltage 850mV
[ 7.540270] [drm] nouveau 0000:01:00.0: 1: core 405MHz shader 810MHz memory 405MHz voltage 900mV
[ 7.540273] [drm] nouveau 0000:01:00.0: 3: core 589MHz shader 1402MHz memory 790MHz voltage 1000mV
[ 7.540275] [drm] nouveau 0000:01:00.0: c: core 405MHz shader 810MHz memory 405MHz voltage 900mV
[ 7.687916] [drm] nouveau 0000:01:00.0: allocated 1680x1050 fb: 0x310000, bo f3a0b200
[ 7.688026] fbcon: nouveaufb (fb0) is primary device
[ 7.729278] Console: switching to colour frame buffer device 210x65
[ 7.731984] fb0: nouveaufb frame buffer device
[ 7.731985] drm: registered panic notifier
[ 7.731989] [drm] Initialized nouveau 1.0.0 20120316 for 0000:01:00.0 on minor 0
[ 8.464665] Adding 1952764k swap on /dev/sda3. Priority:-1 extents:1 across:1952764k
[ 8.485333] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 8.804916] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 8.944785] loop: module loaded
[ 9.758862] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 10.580611] e1000e 0000:00:19.0: irq 41 for MSI/MSI-X
[ 10.636364] e1000e 0000:00:19.0: irq 41 for MSI/MSI-X
[ 10.636617] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.670143] RPC: Registered named UNIX socket transport module.
[ 10.670150] RPC: Registered udp transport module.
[ 10.670154] RPC: Registered tcp transport module.
[ 10.670159] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 10.740347] FS-Cache: Loaded
[ 10.782560] FS-Cache: Netfs 'nfs' registered for caching
[ 10.802692] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 12.098480] e1000e: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: None
[ 12.098484] e1000e 0000:00:19.0: eth0: 10/100 speed: disabling TSO
[ 12.098586] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 14.034714] lp: driver loaded but no devices found
[ 14.068545] ppdev: user-space parallel port driver
[ 22.238175] eth0: no IPv6 routers present
