Probleme channels conf "me tv"
bonjour,
je tente de creer un channels conf pour me tv ,j’ai une carte “avermedia super 007”
voila le probleme lors du scan
root@debian:/home/debianaku# w_scan -c FR -x > channels.conf w_scan version 20100316 (compiled for DVB API 5.1) using settings for FRANCE DVB aerial DVB-T FR frontend_type DVB-T, channellist 5 output format initial tuning data Info: using DVB adapter auto detection. main:2930: FATAL: ***** NO USEABLE DVB CARD FOUND. ***** Please check wether dvb driver is loaded and verify that no dvb application (i.e. vdr) is running. root@debian:/home/debianaku#
un lspci
00:00.0 Host bridge: ATI Technologies Inc RD780 Northbridge only dual slot PCI-e_GFX and HT1 K8 part 00:02.0 PCI bridge: ATI Technologies Inc RD790 PCI to PCI bridge (external gfx0 port A) 00:03.0 PCI bridge: ATI Technologies Inc RD790 PCI to PCI bridge (external gfx0 port B) 00:06.0 PCI bridge: ATI Technologies Inc RD790 PCI to PCI bridge (PCI express gpp port C) 00:11.0 SATA controller: ATI Technologies Inc SB700/SB800 SATA Controller [IDE mode] 00:12.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller 00:12.1 USB Controller: ATI Technologies Inc SB700 USB OHCI1 Controller 00:12.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller 00:13.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller 00:13.1 USB Controller: ATI Technologies Inc SB700 USB OHCI1 Controller 00:13.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller 00:14.0 SMBus: ATI Technologies Inc SBx00 SMBus Controller (rev 3c) 00:14.1 IDE interface: ATI Technologies Inc SB700/SB800 IDE Controller 00:14.2 Audio device: ATI Technologies Inc SBx00 Azalia (Intel HDA) 00:14.3 ISA bridge: ATI Technologies Inc SB700/SB800 LPC host controller 00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge 00:14.5 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI2 Controller 00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration 00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map 00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller 00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control 01:00.0 VGA compatible controller: nVidia Corporation GT216 [GeForce GT 220] (rev a2) 01:00.1 Audio device: nVidia Corporation High Definition Audio Controller (rev a1) 02:00.0 VGA compatible controller: nVidia Corporation G96 [GeForce 9500 GT] (rev a1) 03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 03) 04:05.0 Multimedia controller: Philips Semiconductors SAA7131/SAA7133/SAA7135 Video Broadcast Decoder (rev d1) root@debian:/home/debianaku#
je voudrais donc reussir le scan…
bonjour, :006
resolu… :041
j’ai installé ce paquet:
# apt-get install totem-plugins-dvb-daemon
et le scan c’est lancé,j’ai donc eu un “channels-conf”
par la suite j’ai eu des problemes pour l’appliquer puis finalement c’est passé
voila donc resolu…
ps: je n’ai pas toute les chaines de la tnt ,comme “I-tele” ou “bfm tv” par exemple,si ma fois quelqu’un peut m’arrager ca…
@+ :006
