Hello,
Depuis quelque jours, ma Debian a quelques soucis au démarrage, elle peine apparemment avec le driver Nouveau.
Voilà ce que j’ai:
[ 6.512704] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[ 6.512995] ACPI: Video Device [PEGP] (multi-head: yes rom: yes post: no)
[ 6.513073] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:43/LNXVIDEO:00/input/input14
[ 6.551467] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 6.551572] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input15
[ 6.551631] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 6.551784] nouveau [ DEVICE][0000:01:00.0] BOOT0 : 0x117120a2
[ 6.551786] nouveau [ DEVICE][0000:01:00.0] Chipset: GM107 (NV117)
[ 6.551787] nouveau [ DEVICE][0000:01:00.0] Family : NV110
[ 6.551806] nouveau [ VBIOS][0000:01:00.0] checking PRAMIN for image...
[ 6.551819] nouveau [ VBIOS][0000:01:00.0] ... signature not found
[ 6.551820] nouveau [ VBIOS][0000:01:00.0] checking PROM for image...
[ 6.551926] nouveau [ VBIOS][0000:01:00.0] ... signature not found
[ 6.551928] nouveau [ VBIOS][0000:01:00.0] checking ACPI for image...
[ 6.552621] snd_hda_intel 0000:00:03.0: irq 50 for MSI/MSI-X
[ 6.562176] input: HDA Intel HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/sound/card0/input16
[ 6.562247] input: HDA Intel HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/sound/card0/input17
[ 6.562316] input: HDA Intel HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/sound/card0/input18
[ 6.802863] [drm] Enabling RC6 states: RC6 on, RC6p off, RC6pp off
[ 6.963157] scsi 5:0:0:0: Direct-Access Samsung M3 Portable 1301 PQ: 0 ANSI: 6
[ 6.963335] sd 5:0:0:0: Attached scsi generic sg1 type 0
[ 6.963508] sd 5:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 6.963726] sd 5:0:0:0: [sdb] Write Protect is off
[ 6.963728] sd 5:0:0:0: [sdb] Mode Sense: 33 00 00 08
[ 6.963930] sd 5:0:0:0: [sdb] No Caching mode page found
[ 6.963951] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 8.740409] r8169 0000:09:00.0 eth0: link up
[ 8.740415] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 9.022042] sdb: sdb1
[ 9.022938] sd 5:0:0:0: [sdb] Attached SCSI disk
[ 14.110961] nouveau [ VBIOS][0000:01:00.0] ... appears to be valid
[ 14.110965] nouveau [ VBIOS][0000:01:00.0] using image from ACPI
[ 14.111101] nouveau [ VBIOS][0000:01:00.0] BIT signature found
[ 14.111104] nouveau [ VBIOS][0000:01:00.0] version 82.07.34.00.08
[ 14.111461] nouveau [ DEVINIT][0000:01:00.0] adaptor not initialised
[ 14.111473] nouveau [ VBIOS][0000:01:00.0] running init tables
[ 14.217464] nouveau 0000:01:00.0: irq 51 for MSI/MSI-X
[ 14.217472] nouveau [ PMC][0000:01:00.0] MSI interrupts enabled
[ 14.217507] nouveau [ PFB][0000:01:00.0] RAM type: GDDR5
[ 14.217507] nouveau [ PFB][0000:01:00.0] RAM size: 4096 MiB
[ 14.217508] nouveau [ PFB][0000:01:00.0] ZCOMP: 0 tags
[ 14.217704] nouveau E[ PIBUS][0000:01:00.0] HUB0: 0x6013d4 0x0000573f (0x19408200)
[ 14.218963] nouveau [ CLK][0000:01:00.0] 07: core 405 MHz memory 810 MHz
[ 14.219031] nouveau [ CLK][0000:01:00.0] 0a: core 270-1097 MHz memory 1600 MHz
[ 14.219117] nouveau [ CLK][0000:01:00.0] 0f: core 270-1097 MHz memory 5010 MHz
[ 14.219183] nouveau [ CLK][0000:01:00.0] --: core 405 MHz memory 810 MHz
[ 14.230280] nouveau [ PGRAPH][0000:01:00.0] using external firmware
[ 14.230293] nouveau 0000:01:00.0: firmware: failed to load nouveau/nv117_fuc409c (-2)
[ 14.230312] nouveau 0000:01:00.0: Direct firmware load failed with error -2
[ 14.230313] nouveau 0000:01:00.0: Falling back to user helper
[ 74.417264] nouveau 0000:01:00.0: firmware: failed to load nouveau/fuc409c (-2)
[ 74.417352] nouveau 0000:01:00.0: Direct firmware load failed with error -2
[ 74.417356] nouveau 0000:01:00.0: Falling back to user helper
[ 134.515246] nouveau E[ DEVICE][0000:01:00.0] failed to create 0x18000717, -22
[ 134.515339] nouveau E[ DRM] failed to create 0x80000080, -22
[ 134.517120] ACPI Error: [AR02] Namespace lookup failure, AE_NOT_FOUND (20140424/psargs-359)
[ 134.517134] ACPI Error: Method parse/execution failed [\_SB_.PCI0.PEG0._PRT] (Node ffff88045e8775e0), AE_NOT_FOUND (20140424/psparse-536)
[ 134.517478] nouveau: probe of 0000:01:00.0 failed with error -22
Sachant que mon ordi démarre correctement après, juste qu’il lui faut 3 minutes de plus là…
Si quelqu’un a une idée?
