problème compilation trouve pas avcodec.h
bonjour
Je veux compiler un soft XBMC et au configure j’ai une erreur
./configure --enable-external-libraries --enable-external-ffmpeg --enable-external-libmad --enable-external-liba52 --enable-external-libdts --enable-external-libfaad --enable-external-libmpeg2 --enable-external-libass --enable-external-libvorbis --enable-external-libogg --enable-external-libmpcdec --enable-external-libflac --enable-external-libwavpa ....................................... checking for main in -lswscale... yes checking libavcodec/avcodec.h usability... no checking libavcodec/avcodec.h presence... no checking for libavcodec/avcodec.h... no checking ffmpeg/avcodec.h usability... no checking ffmpeg/avcodec.h presence... no checking for ffmpeg/avcodec.h... no configure: error: Could not find some required headers. Please see the README for your platform.
pourtant j’ai bien les dev
$ locate avcodec.h
/usr/include/ffmpeg/libavcodec/avcodec.h
$ pkg-config --cflags libavcodec
-I/usr/include/ffmpeg
Effectivement si je fais les liens symboliques
ln -s /usr/include/ffmpeg/libavcodec/avcodec.h /usr/include/ffmpeg/avcodec.h
ca fonctionne (il faut aussi le faire pour d’autre fichier)
Mais je veux utiliser une méthode sans faire des liens symboliques.
 ./configure --help
`configure' configures "xbmc" 9.04 to adapt to many kinds of systems.
Usage: ./configure [OPTION]... [VAR=VALUE]...
To assign environment variables (e.g., CC, CFLAGS...), specify them as
VAR=VALUE.  See below for descriptions of some of the useful variables.
Defaults for the options are specified in brackets.
Configuration:
  -h, --help              display this help and exit
      --help=short        display options specific to this package
      --help=recursive    display the short help of all the included packages
  -V, --version           display version information and exit
  -q, --quiet, --silent   do not print `checking...' messages
      --cache-file=FILE   cache test results in FILE [disabled]
  -C, --config-cache      alias for `--cache-file=config.cache'
  -n, --no-create         do not create output files
      --srcdir=DIR        find the sources in DIR [configure dir or `..']
Installation directories:
  --prefix=PREFIX         install architecture-independent files in PREFIX
                          [/usr/local]
  --exec-prefix=EPREFIX   install architecture-dependent files in EPREFIX
                          [PREFIX]
By default, `make install' will install all the files in
`/usr/local/bin', `/usr/local/lib' etc.  You can specify
an installation prefix other than `/usr/local' using `--prefix',
for instance `--prefix=$HOME'.
For better control, use the options below.
Fine tuning of the installation directories:
  --bindir=DIR            user executables [EPREFIX/bin]
  --sbindir=DIR           system admin executables [EPREFIX/sbin]
  --libexecdir=DIR        program executables [EPREFIX/libexec]
  --sysconfdir=DIR        read-only single-machine data [PREFIX/etc]
  --sharedstatedir=DIR    modifiable architecture-independent data [PREFIX/com]
  --localstatedir=DIR     modifiable single-machine data [PREFIX/var]
  --libdir=DIR            object code libraries [EPREFIX/lib]
  --includedir=DIR        C header files [PREFIX/include]
  --oldincludedir=DIR     C header files for non-gcc [/usr/include]
  --datarootdir=DIR       read-only arch.-independent data root [PREFIX/share]
  --datadir=DIR           read-only architecture-independent data [DATAROOTDIR]
  --infodir=DIR           info documentation [DATAROOTDIR/info]
  --localedir=DIR         locale-dependent data [DATAROOTDIR/locale]
  --mandir=DIR            man documentation [DATAROOTDIR/man]
  --docdir=DIR            documentation root [DATAROOTDIR/doc/-xbmc-]
  --htmldir=DIR           html documentation [DOCDIR]
  --dvidir=DIR            dvi documentation [DOCDIR]
  --pdfdir=DIR            pdf documentation [DOCDIR]
  --psdir=DIR             ps documentation [DOCDIR]
System types:
  --build=BUILD     configure for building on BUILD [guessed]
  --host=HOST       cross-compile to build programs to run on HOST [BUILD]
Optional Features:
  --disable-option-checking  ignore unrecognized --enable/--with options
  --disable-FEATURE       do not include FEATURE (same as --enable-FEATURE=no)
  --enable-FEATURE[=ARG]  include FEATURE [ARG=yes]
  --enable-debug          enable debugging information (default is yes)
  --enable-optimizations  enable optimization (default is yes)
  --enable-gl             enable OpenGL rendering (default is yes)
  --enable-vdpau          enable VDPAU decoding (default is yes)
  --enable-profiling      enable gprof profiling (default is no)
  --enable-joystick       enable SDL joystick support (default is yes)
  --enable-xrandr         enable XRandR support (default is yes)
  --enable-ccache         enable building with ccache feature (default is yes
                          if ccache is installed)
  --enable-pulse          enable PulseAudio support (default is yes)
  --enable-faac           enable FAAC support (default is yes)
  --enable-dvdcss         enable DVDCSS support (default is yes)
  --enable-mid            enable MID support (default is no)
  --disable-avahi         disable Avahi support (default is enabled if
                          libavahi-common and libavahi-client is found)
                          enable use of all supported external libraries
                          (default is no) 'Linux only'
                          enable use of external ffmpeg libraries (default is
                          no) 'Linux only'
                          enable use of external libmad library (default is
                          no) 'Linux only'
                          enable use of external liba52 library (default is
                          no) 'Linux only'
                          enable use of external libdts library (default is
                          no) 'Linux only'
                          enable use of external libfaad library (default is
                          no) 'Linux only'
                          enable use of external libmpeg2 library (default is
                          no) 'Linux only'
                          enable use of external libass library (default is
                          no) 'Linux only'
                          enable use of external libvorbis library (default is
                          no) 'Linux only'
                          enable use of external libogg library (default is
                          no) 'Linux only'
                          enable use of external libmpcdec library (default is
                          no) 'Linux only'
                          enable use of external libflac library (default is
                          no) 'Linux only'
  --enable-external-libwavpack
                          enable use of external libwavpack library (default
                          is no) 'Linux only'
  --enable-external-python
                          enable use of external python library (default is
                          no) 'Linux only'
Some influential environment variables:
  CXX         C++ compiler command
  CXXFLAGS    C++ compiler flags
  LDFLAGS     linker flags, e.g. -L<lib dir> if you have libraries in a
              nonstandard directory <lib dir>
  LIBS        libraries to pass to the linker, e.g. -l<library>
  CPPFLAGS    C/C++/Objective C preprocessor flags, e.g. -I<include dir> if
              you have headers in a nonstandard directory <include dir>
  CC          C compiler command
  CFLAGS      C compiler flags
  CXXCPP      C++ preprocessor
  CPP         C preprocessor
J’essaye de jouer avec export (CXX CXXFLAGS …) mais je n’y arrive pas
Qui peut me donner un coup de main? merci
Ce ne serait pas linux-headers-xx qu’il te manque ?
[quote=“Myth0logy”]Ce ne serait pas linux-headers-xx qu’il te manque ?[/quote]non je les ai.
Je change le titre d’ailleur
C’est un bug donc. Si pkg-config renvoie ca et qu’il cherche dans le resultat de pkg-config alors il devrait trouver…
Et dans le config.log, ptet des infos?
Sinon:
CPPFLAGS="-I/usr/include/ffmpeg" ./configure
mélange paquet ffmpeg de lenny/debian et paquet ffmpeg de lenny/debian-multimedia
merci à vous c’est effectivement ca mélange de différente versions debian et debian-multimedia
J’ai réglé le problème avec l’aide de ignatioza
C’est marrant j’étais certain de l’avoir fait. CPPFLAGS="-I/usr/include/ffmpeg/"
merci encore
A propos c’est ca que je veux essayer xbmc.fr/
[quote=“limax”]A propos c’est ca que je veux essayer xbmc.fr/[/quote]Très beau ! :smiley:
@limax…
Merci de l’idée d’installer XBMC, c’est vraiment un très beau média center !
Un peu chaud à installer… Mais quand ça tourne, c’est coooooooool ! :smiley:
