Bonjour a tous
j’ai un soucis avec une configuration de debian que je n’arrive pas résoudre , cela concerne postfix et sa configuration
je sous debian 64 bit
voila mon soucis
root@servmail:~# telnet localhost 25
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
220 mail.mondomaine.fr ESMTP Postfix (Debian/GNU)
ehlo mondomaine.fr
250-mail.mondomaine.fr
250-PIPELINING
250-SIZE 10240000
250-ETRN
250-ENHANCEDSTATUSCODES
250-8BITMIME
250 DSN
mail from test@test.fr
501 5.5.4 Syntax: MAIL FROM:<address>
mail from: test@test.fr
250 2.1.0 Ok
rcpt to: baptiste@mondomaine.fr
451 4.3.0 <baptiste @mondomaine.fr>: Temporary lookup failure
l’erreur est ici :
voila les log /var/log/mail.log
Dec 30 11:50:12 servmail postfix/smtpd[19037]: warning: dict_nis_init: NIS domain name not set - NIS lookups disabled
Dec 30 11:50:12 servmail postfix/smtpd[19037]: connect from unknown[unknown]
Dec 30 11:50:12 servmail postfix/smtpd[19037]: lost connection after CONNECT from unknown[unknown]
Dec 30 11:50:12 servmail postfix/smtpd[19037]: disconnect from unknown[unknown]
Dec 30 11:53:32 servmail postfix/anvil[19038]: statistics: max connection rate 1/60s for (smtp:unknown) at Dec 30 11:50:12
Dec 30 11:53:32 servmail postfix/anvil[19038]: statistics: max connection count 1 for (smtp:unknown) at Dec 30 11:50:12
Dec 30 11:53:32 servmail postfix/anvil[19038]: statistics: max cache size 1 at Dec 30 11:50:12
Dec 30 11:53:58 servmail postfix/smtpd[19033]: timeout after RCPT from localhost[127.0.0.1]
Dec 30 11:53:58 servmail postfix/smtpd[19033]: disconnect from localhost[127.0.0.1]
Dec 30 11:56:14 servmail postfix/smtpd[19047]: warning: dict_nis_init: NIS domain name not set - NIS lookups disabled
Dec 30 11:56:14 servmail postfix/smtpd[19047]: connect from localhost[127.0.0.1]
Dec 30 11:56:44 servmail postfix/trivial-rewrite[19049]: warning: connect to mysql server 127.0.0.1: Can't connect to MySQL server on '127.0.0.1' (111)
Dec 30 11:56:44 servmail postfix/trivial-rewrite[19049]: warning: mysql:/etc/postfix/mysql-virtual_aliases.cf: table lookup problem
Dec 30 11:56:44 servmail postfix/trivial-rewrite[19049]: warning: virtual_alias_domains lookup failure
Dec 30 11:56:59 servmail postfix/trivial-rewrite[19049]: warning: mysql:/etc/postfix/mysql-virtual_aliases.cf: table lookup problem
Dec 30 11:56:59 servmail postfix/trivial-rewrite[19049]: warning: virtual_alias_domains lookup failure
Dec 30 11:56:59 servmail postfix/smtpd[19047]: NOQUEUE: reject: RCPT from localhost[127.0.0.1]: 451 4.3.0 <baptiste @mondomaine.fr>: Temporary lookup failure; from=<test?@test.fr> to=<baptiste?@mondomaine.fr> proto=ESMTP helo=<mondomaine.fr>
Dec 30 11:57:04 servmail postfix/smtpd[19047]: warning: non-SMTP command from localhost[127.0.0.1]: root@servmail:~# telnet localhost 25
Dec 30 11:57:04 servmail postfix/smtpd[19047]: disconnect from localhost[127.0.0.1]
Dec 30 11:58:38 servmail postfix/pickup[18864]: 511D71C19E: uid=0 from=<root>
Dec 30 11:58:38 servmail postfix/cleanup[19065]: warning: connect to mysql server 127.0.0.1: Can't connect to MySQL server on '127.0.0.1' (111)
Dec 30 11:58:38 servmail postfix/cleanup[19065]: warning: mysql:/etc/postfix/mysql-virtual_aliases.cf lookup error for "from@mail.mondomaine.fr"
Dec 30 11:58:38 servmail postfix/cleanup[19065]: warning: 511D71C19E: virtual_alias_maps map lookup problem for from@mail.mondomaine.fr -- deferring delivery
Dec 30 11:58:39 servmail postfix/pickup[18864]: 55C731C19E: uid=0 from=<root>
Dec 30 11:58:39 servmail postfix/cleanup[19065]: warning: mysql:/etc/postfix/mysql-virtual_aliases.cf lookup error for "from@mail.mondomaine.fr"
Dec 30 11:58:39 servmail postfix/cleanup[19065]: warning: 55C731C19E: virtual_alias_maps map lookup problem for from@mail.mondomaine.fr -- deferring delivery
Dec 30 11:59:39 servmail postfix/pickup[18864]: 34DCC1C19E: uid=0 from=<root>
Dec 30 11:59:39 servmail postfix/cleanup[19065]: warning: connect to mysql server 127.0.0.1: Can't connect to MySQL server on '127.0.0.1' (111)
Dec 30 11:59:39 servmail postfix/cleanup[19065]: warning: mysql:/etc/postfix/mysql-virtual_aliases.cf lookup error for "from@mail.mondomaine.fr"
Dec 30 11:59:39 servmail postfix/cleanup[19065]: warning: 34DCC1C19E: virtual_alias_maps map lookup problem for from@mail.mondomaine.fr -- deferring delivery
Dec 30 12:00:39 servmail postfix/pickup[18864]: 465E51C19E: uid=0 from=<root>
Dec 30 12:00:39 servmail postfix/cleanup[19065]: warning: mysql:/etc/postfix/mysql-virtual_aliases.cf lookup error for "from@mail.mondomaine.fr"
Dec 30 12:00:39 servmail postfix/cleanup[19065]: warning: 465E51C19E: virtual_alias_maps map lookup problem for from@mail.mondomaine.fr -- deferring delivery
Dec 30 12:01:39 servmail postfix/pickup[18864]: 585C21C19E: uid=0 from=<root>
Dec 30 12:01:39 servmail postfix/cleanup[19065]: warning: connect to mysql server 127.0.0.1: Can't connect to MySQL server on '127.0.0.1' (111)
Dec 30 12:01:39 servmail postfix/cleanup[19065]: warning: mysql:/etc/postfix/mysql-virtual_aliases.cf lookup error for "from@mail.mondomaine.fr"
Dec 30 12:01:39 servmail postfix/cleanup[19065]: warning: 585C21C19E: virtual_alias_maps map lookup problem for from@mail.mondomaine.fr -- deferring delivery
Dec 30 12:02:39 servmail postfix/pickup[18864]: 6AEAD1C19E: uid=0 from=<root>
Dec 30 12:02:39 servmail postfix/cleanup[19065]: warning: mysql:/etc/postfix/mysql-virtual_aliases.cf lookup error for "from@mail.mondomaine.fr"
Dec 30 12:02:39 servmail postfix/cleanup[19065]: warning: 6AEAD1C19E: virtual_alias_maps map lookup problem for from@mail.mondomaine.fr -- deferring delivery
Dec 30 12:03:39 servmail postfix/pickup[18864]: 7C3721C19E: uid=0 from=<root>
Dec 30 12:03:39 servmail postfix/cleanup[19065]: warning: connect to mysql server 127.0.0.1: Can't connect to MySQL server on '127.0.0.1' (111)
Dec 30 12:03:39 servmail postfix/cleanup[19065]: warning: mysql:/etc/postfix/mysql-virtual_aliases.cf lookup error for "from@mail.mondomaine.fr"
Dec 30 12:03:39 servmail postfix/cleanup[19065]: warning: 7C3721C19E: virtual_alias_maps map lookup problem for from@mail.mondomaine.fr -- deferring delivery
et le main.cf
[code]# Service qui envoie des notifications “nouveau message”
biff = no
Desactive la commande SMTP VRFY. Arrête certaine technique pour avoir des adresses email
disable_vrfy_command = yes
Impose au client SMTP de démarrer la session SMTP par une commande Helo (ou ehlo)
smtpd_helo_required = yes
Avec le courier local ça ajoute .NDD aux adresses incomplètes (seulement le nom d’hote)
append_dot_mydomain = no
Le nom de la machine du système de messagerie
Par défaut c’est host.domain.tld mais on peut mettre un reverse dns
myhostname = mail.mondomaine.fr
Le domaine utilisé par defaut pour poster les message local
myorigin = mail.mondomaine.fr
Liste des domaines pour lequel le serveur doit accepter le courrier
mydestination = mail.mondomaine.fr, localhost.localdomain, localhost
Pour effectuer des livraisons de courrier avec un relay (ici non)
relayhost =
Liste des réseaux locaux autorisés
mynetworks = 127.0.0.0/8, 51.x.204.x
Taille des boîtes au lettre (0 = illimité)
mailbox_size_limit = 0
Séparateur entre le nom d’utilisateur et les extensions d’adresses
recipient_delimiter = +
Interfaces réseaux à écouter (ici toutes)
inet_interfaces = all
Gestion des boites mails virtuelle
Contient les fichiers qui permettent de relier postfix mysql
virtual_alias_maps = mysql:/etc/postfix/mysql-virtual_aliases.cf,mysql:/etc/postfix/mysql-virtual_aliases_comptes.cf
virtual_mailbox_domains = mysql:/etc/postfix/mysql-virtual_domaines.cf
virtual_mailbox_maps = mysql:/etc/postfix/mysql-virtual_comptes.cf
Le dossier ou seront contenu les mails (=home de l’user vmail)
virtual_mailbox_base = /var/spool/vmail/
L’id du groupe et de l’utilisateur vmail créé précédement
virtual_uid_maps = static:5000
virtual_gid_maps = static:5000
Créer un dossier par comte email
virtual_create_maildirsize = yes
A activer si vous souhaitez ajouter des quotas
virtual_mailbox_extended = yes
Impose les limites au niveau des mails, dans notre cas aucune
virtual_mailbox_limit_maps = mysql:/etc/postfix/mysql-virtual_quotas.cf
Ajouter une limite sur la taille des messages pour les boites virtuelles
virtual_mailbox_limit_override = yes
virtual_maildir_limit_message = “La boite mail de votre destinataire est pleine, merci de reessayez plus tard.”
virtual_overquota_bounce = yes
adresses d’expedition
smtpd_sender_restrictions =
permit_mynetworks,
warn_if_reject reject_unverified_sender
adresses de destination
smtpd_recipient_restrictions =
permit_mynetworks,
reject_unauth_destination,
reject_non_fqdn_recipient
client
smtpd_client_restrictions =
permit_mynetworks
(mysql -u postix -p -h 127.O.O.1)
