en faisant wpa_supplicant -D ndiswrapper -i wlan0 -c /etc/wpa_supplicant.conf -d
j’obtient
Initializing interface 'wlan0' conf '/etc/wpa_supplicant.conf' driver 'ndiswrapper' ctrl_interface 'N/A' bridge 'N/A'
Unsupported driver 'ndiswrapper'.
Failed to add interface wlan0
Cancelling scan request
Cancelling authentication timeout
donc la le driver ndiswrapper ne marche pas.par contre en reproduisant avec wext ce qui donne
j’obtient
Setting scan request: 5 sec 0 usec
Starting AP scan (broadcast SSID)
Scan requested (ret=0) - scan timeout 5 seconds
Scan timeout - try to get results
Received 1753 bytes of scan results (7 BSSes)
CTRL-EVENT-SCAN-RESULTS
Selecting BSS from priority group 0
Try to find WPA-enabled AP
0: 00:17:33:ed:65:a1 ssid='NEUF_65A0' wpa_ie_len=28 rsn_ie_len=0 caps=0x11
skip - SSID mismatch
1: 00:18:e7:58:9c:25 ssid='Livebox-4146' wpa_ie_len=22 rsn_ie_len=0 caps=0x11
2: 00:1c:26:36:29:4f ssid='Livebox-DD88' wpa_ie_len=22 rsn_ie_len=0 caps=0x11
3: 00:1e:2a:55:80:72 ssid='NETGEAR' wpa_ie_len=22 rsn_ie_len=0 caps=0x11
4: 00:19:7e:c2:c7:84 ssid='Livebox-6CC8' wpa_ie_len=22 rsn_ie_len=0 caps=0x11
5: 00:1b:2f:50:de:d0 ssid='NETGEAR' wpa_ie_len=0 rsn_ie_len=0 caps=0x11
skip - no WPA/RSN IE
6: 00:17:33:ed:65:a8 ssid='Neuf WiFi' wpa_ie_len=0 rsn_ie_len=0 caps=0x1
Try to find non-WPA AP
No suitable AP found.
et tout cela en boucle sans pouvoir accrocher aucun signal
voila mon fichier wpa_supplicant.conf
network={
ssid=[NETGEAR]"
#psk="[ma passphrase]"
psk=mon code chiffrée
ai-je oublier quelque chose.est ce que mon affaire est mal conpilée?
