J’ai installé une nouvelle debian sid sur mon portable, mais j’ai des problèmes d’affichage, principalement dans iceweasel (rarement dans d’autres applications).
Voici un exemple (ici on ne voit qu’une bande blanche, mais généralement c’est quasiment toute la page qui est blanche avec quelques trous laissant apercevoir la page de derrière) :
Je pense que la configuration graphique est foireuse.
Voici mon xorg.conf : j’ai copié celui de ma debian testing (qui fonctionne parfaitement) et l’ai mis sur cette sid après avoir installé fglrx :
[code]# xorg.conf (X.Org X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section “ServerLayout”
Identifier “aticonfig Layout”
Screen 0 “aticonfig-Screen[0]-0” 0 0
EndSection
Section “Files”
EndSection
Section “Module”
EndSection
Section “InputDevice”
Identifier “Generic Keyboard”
Driver “kbd”
Option “XkbRules” “xorg”
Option “XkbModel” “pc105”
Option “XkbLayout” “fr”
Option “XkbVariant” “latin9”
EndSection
Identifier “Configured Mouse”
Driver “mouse”
EndSection
Section “Monitor”
Identifier “Configured Monitor”
Option “PreferredMode” “1600x900”
EndSection
Section “Monitor”
Identifier “aticonfig-Monitor[0]-0”
Option “VendorName” “ATI Proprietary Driver”
Option “ModelName” “Generic Autodetecting Monitor”
Option “DPMS” “true”
EndSection
Section “Device”
Identifier “Configured Video Device”
EndSection
Section “Device”
Identifier “aticonfig-Device[0]-0”
Driver “fglrx”
BusID “PCI:1:0:0”
EndSection
Section “Screen”
Identifier “Default Screen”
Monitor “Configured Monitor”
EndSection
Section “Screen”
Identifier “aticonfig-Screen[0]-0”
Device “aticonfig-Device[0]-0”
Monitor “aticonfig-Monitor[0]-0”
DefaultDepth 24
SubSection “Display”
Viewport 0 0
Depth 24
EndSubSection
EndSection
[edit] Je suis sous openbox (installation minimal)
Si vous avez des idées pour ce problème plutôt embêtant (pas facile la navigation dans ces conditions
Merci d’avance,
bece
fait une copie avant du tient .
désolé pour le plantage
