Probleme d'ajout de police
voila l’erreur renvoyée :
lotsob@benbook:~$ xset fp+ fonts/ xset: bad font path element (#7), possible causes are: Directory does not exist or has wrong permissions Directory missing fonts.dir Incorrect font server address or syntax
le contenu du répertoire en question :
lotsob@benbook:~$ lsla fonts/ total 176 drwxr-xr-x 2 lotsob lotsob 4096 Oct 14 22:07 . drwxr-xr-x 34 lotsob lotsob 4096 Oct 14 22:14 .. -rw-r--r-- 1 lotsob lotsob 20237 Oct 14 22:07 cureextra.bdf -rw-r--r-- 1 lotsob lotsob 11200 Oct 14 22:07 cureextra.pcf -rw-r--r-- 1 lotsob lotsob 27517 Oct 14 22:07 lokaltog-10b.bdf -rw-r--r-- 1 lotsob lotsob 27618 Oct 14 22:07 lokaltog-10.bdf -rw-r--r-- 1 lotsob lotsob 30007 Oct 14 22:07 lokaltog-12b.bdf -rw-r--r-- 1 lotsob lotsob 30016 Oct 14 22:07 lokaltog-12.bdf -rw-r--r-- 1 lotsob lotsob 15422 Oct 14 22:07 lokaltog-symbols.bdf
ce que me renvoie xset
lotsob@benbook:~$ xset -q Keyboard Control: auto repeat: on key click percent: 0 LED mask: 00000000 XKB indicators: 00: Caps Lock: off 01: Num Lock: off 02: Scroll Lock: off 03: Compose: off 04: Kana: off 05: Sleep: off 06: Suspend: off 07: Mute: off 08: Misc: off 09: Mail: off 10: Charging: off 11: Shift Lock: off 12: Group 2: off 13: Mouse Keys: off auto repeat delay: 660 repeat rate: 25 auto repeating keys: 00ffffffdffffbbf fadfffefffedffff 9fffffffffffffff fff7ffffffffffff bell percent: 50 bell pitch: 400 bell duration: 100 Pointer Control: acceleration: 2/1 threshold: 4 Screen Saver: prefer blanking: yes allow exposures: yes timeout: 600 cycle: 600 Colors: default colormap: 0x20 BlackPixel: 0 WhitePixel: 16777215 Font Path: /usr/share/fonts/X11/misc,/usr/share/fonts/X11/100dpi/:unscaled,/usr/share/fonts/X11/75dpi/:unscaled,/usr/share/fonts/X11/Type1,/usr/share/fonts/X11/100dpi,/usr/share/fonts/X11/75dpi,built-ins DPMS (Energy Star): Standby: 600 Suspend: 600 Off: 600 DPMS is Enabled Monitor is On
j’avoue ne pas bien savoir d’où pourrais venir le problème, j’ai aussi essaye xset fp+ /home/lotsob/fonts sans succes
xset te le dit : ta police n’est pas dans le path.
Les dernières lignes de xset t’indiquent les chemin supportés.
/fonts ne l’est pas.
Donc 2 possibilités :
  • Ajouter /fonts au path de xset
  • Mettre tes polices dans /usr/share/fonts par exemple
j’ai fait un mkfontdir dans mon directory fonts, ça a créé fonts.dir et du coup le xset fp+ marche
