salut,
Non , il n’y a plus moyen de booter…
je ne savais pas ce qu’est un live-cd, j’ai fais une recherche et j’ai donc téléchargé knopix , et de plus le clavier par défaut est qwerty), j’ai voulu mettre au boot l’option lang=fr mais
il me réponds un truc du genre unknown kernel.
Bref , j’ai réussi a copier le fichier menu.lst mais je ne sais pas si cela suffit.
Voilà ce que ça donne :
menu.lst - See: grub(8), info grub, update-grub(8)
grub-install(8), grub-floppy(8),
grub-md5-crypt, /usr/share/doc/grub
and /usr/share/doc/grub-doc/.
default num
Set the default entry to the entry number NUM. Numbering starts from 0, and
the entry number 0 is the default if the command is not used.
You can specify ‘saved’ instead of a number. In this case, the default entry
is the entry saved with the command ‘savedefault’.
default 0
timeout sec
Set a timeout, in SEC seconds, before automatically booting the default entry
(normally the first entry defined).
timeout 5
Pretty colours
color cyan/blue white/blue
password [’–md5’] passwd
If used in the first section of a menu file, disable all interactive editing
control (menu entry editor and command-line) and entries protected by the
command ‘lock’
e.g. password topsecret
password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
password topsecret
examples
title Windows 95/98/NT/2000
root (hd0,0)
makeactive
chainloader +1
title Linux
root (hd0,1)
kernel /vmlinuz root=/dev/hda2 ro
Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
BEGIN AUTOMAGIC KERNELS LIST
lines between the AUTOMAGIC KERNELS LIST markers will be modified
by the debian update-grub script except for the default options below
DO NOT UNCOMMENT THEM, Just edit them to your needs
## Start Default Options
default kernel options
default kernel options for automagic boot options
If you want special options for specifiv kernels use kopt_x_y_z
where x.y.z is kernel version. Minor versions can be omitted.
e.g. kopt=root=/dev/hda1 ro
kopt=root=/dev/hda5 ro
default grub root device
e.g. groot=(hd0,0)
groot=(hd0,4)
should update-grub create alternative automagic boot options
e.g. alternative=true
alternative=false
alternative=true
should update-grub lock alternative automagic boot options
e.g. lockalternative=true
lockalternative=false
altoption boot targets option
multiple altoptions lines are allowed
e.g. altoptions=(extra menu suffix) extra boot options
altoptions=(recovery mode) single
controls how many kernels should be put into the menu.lst
only counts the first occurence of a kernel, not the
alternative kernel options
e.g. howmany=all
howmany=7
howmany=all
should update-grub create memtest86 boot option
e.g. memtest86=true
memtest86=false
memtest86=true
## End Default Options
title Debian GNU/Linux, kernel 2.4.27-3-386
root (hd0,4)
kernel /boot/vmlinuz-2.4.27-3-386 root=/dev/hda5 ro
initrd /boot/initrd.img-2.4.27-3-386
savedefault
boot
title Debian GNU/Linux, kernel 2.4.27-3-386 (recovery mode)
root (hd0,4)
kernel /boot/vmlinuz-2.4.27-3-386 root=/dev/hda5 ro single
savedefault
boot
END DEBIAN AUTOMAGIC KERNELS LIST
This is a divider, added to separate the menu items below from the Debian
ones.
title Other operating systems:
root
This entry automatically added by the Debian installer for a non-linux OS
on /dev/hda1
title Microsoft Windows XP Professionnel
root (hd0,0)
savedefault
makeactive
chainloader +1
This entry automatically added by the Debian installer for an existing
linux installation on /dev/hda2.
title linux (on /dev/hda2)
root (hd0,1)
kernel /boot/vmlinuz-2.4.20-8 ro hdc=ide-scsi root=LABEL=/
initrd /boot/initrd-2.4.20-8.img
savedefault
boot
