je viens de faire un nouveau dmseg après réinstallation, ça me donne ça :
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
Adding 979924k swap on /dev/hda6. Priority:-1 extents:1
EXT3 FS on hda8, internal journal
hdb: ATAPI 24X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
ieee1394: Initialized config rom entry `ip1394'
SCSI subsystem initialized
sbp2: $Rev: 1219 $ Ben Collins <bcollins@debian.org>
Real Time Clock Driver v1.12
Generic RTC Driver v1.07
Synaptics Touchpad, model: 1, fw: 6.1, id: 0xa3a0b3, caps: 0xa04713/0x10008
input: SynPS/2 Synaptics TouchPad on isa0060/serio4
mice: PS/2 mouse device common for all mice
ts: Compaq touchscreen protocol output
EXT3 FS on hda7, internal journal
Linux Kernel Card Services
options: [pci] [cardbus] [pm]
PCI: Enabling device 0000:03:01.0 (0105 -> 0107)
ACPI: PCI Interrupt 0000:03:01.0[A] -> GSI 17 (level, low) -> IRQ 201
Yenta: CardBus bridge found at 0000:03:01.0 [1043:1127]
Yenta: ISA IRQ mask 0x04a8, PCI irq 201
Socket status: 30000006
ohci1394: $Rev: 1250 $ Ben Collins <bcollins@debian.org>
ACPI: PCI Interrupt 0000:03:01.1[B] -> GSI 18 (level, low) -> IRQ 193
ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[193] MMIO=[feafe800-feafefff] Ma x Packet=[2048]
8139too Fast Ethernet driver 0.9.27
ACPI: PCI Interrupt 0000:03:00.0[A] -> GSI 20 (level, low) -> IRQ 209
eth0: RealTek RTL8139 at 0xd800, 00:15:f2:3e:e7:d0, IRQ 209
eth0: Identified 8139 chip type 'RTL-8100B/8139D'
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v2.2
ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 23 (level, low) -> IRQ 217
PCI: Setting latency timer of device 0000:00:1d.0 to 64
uhci_hcd 0000:00:1d.0: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #1
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:1d.0: irq 217, io base 0x0000e480
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1d.1[B] -> GSI 19 (level, low) -> IRQ 225
PCI: Setting latency timer of device 0000:00:1d.1 to 64
uhci_hcd 0000:00:1d.1: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #2
usb 1-1: new low speed USB device using uhci_hcd and address 2
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:1d.1: irq 225, io base 0x0000e800
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ieee1394: Host added: ID:BUS[0-00:1023] GUID[00e0180003433481]
ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 193
PCI: Setting latency timer of device 0000:00:1d.2 to 64
uhci_hcd 0000:00:1d.2: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #3
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:1d.2: irq 193, io base 0x0000e880
eth1394: $Rev: 1247 $ Ben Collins <bcollins@debian.org>
eth1394: eth1: IEEE-1394 IPv4 over 1394 Ethernet (fw-host0)
usb 2-2: new full speed USB device using uhci_hcd and address 2
usbcore: registered new driver hiddev
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1d.3[D] -> GSI 16 (level, low) -> IRQ 169
PCI: Setting latency timer of device 0000:00:1d.3 to 64
uhci_hcd 0000:00:1d.3: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #4
input: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-0000:00:1d.0-1
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.01:USB HID core driver
drivers/usb/class/usblp.c: usblp0: USB Bidirectional printer dev 2 if 0 alt 0 pr oto 2 vid 0x03F0 pid 0x1904
usbcore: registered new driver usblp
drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 4
uhci_hcd 0000:00:1d.3: irq 169, io base 0x0000ec00
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
usb 4-1: new full speed USB device using uhci_hcd and address 2
ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 23 (level, low) -> IRQ 217
PCI: Setting latency timer of device 0000:00:1d.7 to 64
ehci_hcd 0000:00:1d.7: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB 2 EHCI Controller
ehci_hcd 0000:00:1d.7: debug port 1
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 5
ehci_hcd 0000:00:1d.7: irq 217, io mem 0xfebfbc00
PCI: cache line size of 32 is not supported by device 0000:00:1d.7
ehci_hcd 0000:00:1d.7: USB 2.0 initialized, EHCI 1.00, driver 10 Dec 2004
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 8 ports detected
usb 4-1: USB disconnect, address 2
usb 1-1: USB disconnect, address 2
usb 2-2: USB disconnect, address 2
drivers/usb/class/usblp.c: usblp0: removed
Linux agpgart interface v0.101 (c) Dave Jones
agpgart: Detected an Intel 915GM Chipset.
agpgart: AGP aperture is 256M @ 0x0
usb 5-7: new high speed USB device using ehci_hcd and address 4
usb 1-1: new low speed USB device using uhci_hcd and address 3
usb 2-2: new full speed USB device using uhci_hcd and address 3
drivers/usb/class/usblp.c: usblp0: USB Bidirectional printer dev 3 if 0 alt 0 pr oto 2 vid 0x03F0 pid 0x1904
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
ACPI: PCI Interrupt 0000:00:1b.0[A] -> GSI 16 (level, low) -> IRQ 169
PCI: Setting latency timer of device 0000:00:1b.0 to 64
hda_codec: no AFG node found
hw_random hardware driver 1.0.0 loaded
8139cp: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004)
input: PC Speaker
irda_init()
NET: Registered protocol family 23
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA ]
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
NET: Registered protocol family 17
cs: IO port probe 0x100-0x4ff: excluding 0x170-0x177 0x2e0-0x2e7 0x370-0x37f 0x4 00-0x41f 0x480-0x4bf 0x4d0-0x4d7
cs: IO port probe 0x800-0x8ff: excluding 0x810-0x87f
cs: IO port probe 0xc00-0xcff: excluding 0xcf8-0xcff
cs: IO port probe 0xa00-0xaff: clean.
hdb: packet command error: status=0x51 { DriveReady SeekComplete Error }
hdb: packet command error: error=0x50 { LastFailedSense=0x05 }
ide: failed opcode was: unknown
cdrom: open failed.
ACPI: Battery Slot [BAT0] (battery present)
ACPI: AC Adapter [AC0] (on-line)
ACPI: CPU0 (power states: C1[C1] C2[C2])
ACPI: Processor [CPU1] (supports 8 throttling states)
ACPI: Power Button (FF) [PWRF]
ACPI: Sleep Button (CM) [SLPB]
ACPI: Lid Switch [LID]
ACPI: Fan [FN00] (off)
ACPI: Thermal Zone [THRM] (44 C)
apm: BIOS not found.
NET: Registered protocol family 10
Disabled Privacy Extensions on device c030c060(lo)
IPv6 over IPv4 tunneling driver
eth0: no IPv6 routers present
au passage : au moment de recomplier le kernel : y as-t-il besoin de prendre un kernel spécifique pour mon processeur (pentium M), et est-ce utile ?
