Voila le Makefile que j’ai trouve :
[code]# Makefile.in generated by automake 1.10 from Makefile.am.
scripts/Makefile. Generated from Makefile.in by configure.
Copyright © 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002,
2003, 2004, 2005, 2006 Free Software Foundation, Inc.
This Makefile.in is free software; the Free Software Foundation
gives unlimited permission to copy and/or distribute it,
with or without modifications, as long as this notice is preserved.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY, to the extent permitted by law; without
even the implied warranty of MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
pkgdatadir = $(datadir)/libsigc++
pkglibdir = $(libdir)/libsigc++
pkgincludedir = $(includedir)/libsigc++
am__cd = CDPATH="$${ZSH_VERSION+.}$(PATH_SEPARATOR)" && cd
install_sh_DATA = $(install_sh) -c -m 644
install_sh_PROGRAM = $(install_sh) -c
install_sh_SCRIPT = $(install_sh) -c
INSTALL_HEADER = $(INSTALL_DATA)
transform = $(program_transform_name)
NORMAL_INSTALL = :
PRE_INSTALL = :
POST_INSTALL = :
NORMAL_UNINSTALL = :
PRE_UNINSTALL = :
POST_UNINSTALL = :
build_triplet = x86_64-unknown-linux-gnu
host_triplet = x86_64-unknown-linux-gnu
subdir = scripts
DIST_COMMON = $(srcdir)/Makefile.am $(srcdir)/Makefile.in
ACLOCAL_M4 = $(top_srcdir)/aclocal.m4
am__aclocal_m4_deps = $(top_srcdir)/scripts/cxx.m4
$(top_srcdir)/scripts/cxx_std.m4 $(top_srcdir)/configure.ac
am__configure_deps = $(am__aclocal_m4_deps) $(CONFIGURE_DEPENDENCIES)
$(ACLOCAL_M4)
mkinstalldirs = $(install_sh) -d
CONFIG_HEADER = $(top_builddir)/sigc++config.h
CONFIG_CLEAN_FILES =
SOURCES =
DIST_SOURCES =
DISTFILES = $(DIST_COMMON) $(DIST_SOURCES) $(TEXINFOS) $(EXTRA_DIST)
ACLOCAL = ${SHELL} /usr/local/music/src/ardour/2.0-ongoing/libs/sigc++2/missing --run aclocal-1.10
AMTAR = ${SHELL} /usr/local/music/src/ardour/2.0-ongoing/libs/sigc++2/missing --run tar
AR = ar
AS = as
AUTOCONF = ${SHELL} /usr/local/music/src/ardour/2.0-ongoing/libs/sigc++2/missing --run autoconf
AUTOHEADER = :
AUTOMAKE = ${SHELL} /usr/local/music/src/ardour/2.0-ongoing/libs/sigc++2/missing --run automake-1.10
AWK = gawk
CC = gcc
CCDEPMODE = depmode=gcc3
CFLAGS = -g -O2
CPP = gcc -E
CPPFLAGS =
CXX = g++
CXXCPP = g++ -E
CXXDEPMODE = depmode=gcc3
CXXFLAGS = -g -O2
CYGPATH_W = echo
DEFS = -DHAVE_CONFIG_H
DEPDIR = .deps
DLLTOOL = dlltool
ECHO = echo
ECHO_C =
ECHO_N = -n
ECHO_T =
EGREP = /bin/grep -E
EXEEXT =
F77 = gfortran
FFLAGS = -g -O2
FP_MAJOR_VERSION = 2
FP_MICRO_VERSION = 2
FP_MINOR_VERSION = 2
FP_RELEASE = 2.2
FP_VERSION = 2.2.2
GREP = /bin/grep
INSTALL = /usr/bin/install -c
INSTALL_DATA = ${INSTALL} -m 644
INSTALL_PROGRAM = ${INSTALL}
INSTALL_SCRIPT = ${INSTALL}
INSTALL_STRIP_PROGRAM = $(install_sh) -c -s
LDFLAGS =
LIBOBJS =
LIBS =
LIBTOOL = $(SHELL) $(top_builddir)/libtool
LN_S = ln -s
LTLIBOBJS =
M4 = m4
MAINT =
MAKEINFO = ${SHELL} /usr/local/music/src/ardour/2.0-ongoing/libs/sigc++2/missing --run makeinfo
MKDIR_P = /bin/mkdir -p
OBJDUMP = objdump
OBJEXT = o
PACKAGE = libsigc++
PACKAGE_BUGREPORT = libsigc-list@gnome.org
PACKAGE_NAME = libsigc++
PACKAGE_STRING = libsigc++ 2.2.2
PACKAGE_TARNAME = libsigc++
PACKAGE_VERSION = 2.2.2
PATH_SEPARATOR = :
PERL_PATH = /usr/bin/perl
RANLIB = ranlib
SED = /bin/sed
SET_MAKE =
SHELL = /bin/sh
STRIP = strip
VERSION = 2.2.2
abs_builddir = /usr/local/music/src/ardour/2.0-ongoing/libs/sigc++2/scripts
abs_srcdir = /usr/local/music/src/ardour/2.0-ongoing/libs/sigc++2/scripts
abs_top_builddir = /usr/local/music/src/ardour/2.0-ongoing/libs/sigc++2
abs_top_srcdir = /usr/local/music/src/ardour/2.0-ongoing/libs/sigc++2
ac_ct_CC = gcc
ac_ct_CXX = g++
ac_ct_F77 = gfortran
am__include = include
am__leading_dot = .
am__quote =
am__tar = tar --format=ustar -chf - "$$tardir"
am__untar = tar -xf -
bindir = ${exec_prefix}/bin
build = x86_64-unknown-linux-gnu
build_alias =
build_cpu = x86_64
build_os = linux-gnu
build_vendor = unknown
builddir = .
datadir = ${datarootdir}
datarootdir = ${prefix}/share
docdir = ${datarootdir}/doc/${PACKAGE_TARNAME}
dvidir = ${docdir}
exec_prefix = ${prefix}
host = x86_64-unknown-linux-gnu
host_alias =
host_cpu = x86_64
host_os = linux-gnu
host_vendor = unknown
htmldir = ${docdir}
includedir = ${prefix}/include
infodir = ${datarootdir}/info
install_sh = $(SHELL) /usr/local/music/src/ardour/2.0-ongoing/libs/sigc++2/install-sh
libdir = ${exec_prefix}/lib
libexecdir = ${exec_prefix}/libexec
localedir = ${datarootdir}/locale
localstatedir = ${prefix}/var
mandir = ${datarootdir}/man
mkdir_p = /bin/mkdir -p
oldincludedir = /usr/include
pdfdir = ${docdir}
prefix = /usr/local
program_transform_name = s,x,x,
psdir = ${docdir}
sbindir = ${exec_prefix}/sbin
sharedstatedir = ${prefix}/com
srcdir = .
sysconfdir = ${prefix}/etc
target_alias =
top_builddir = …
top_srcdir = …
EXTRA_DIST = cxx.m4 cxx_std.m4
all: all-am
.SUFFIXES:
$(srcdir)/Makefile.in: $(srcdir)/Makefile.am $(am__configure_deps)
@for dep in $?; do
case ‘$(am__configure_deps)’ in
$$dep)
cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am–refresh
&& exit 0;
exit 1;;
esac;
done;
echo ’ cd $(top_srcdir) && $(AUTOMAKE) --gnu scripts/Makefile’;
cd $(top_srcdir) &&
.PRECIOUS: Makefile
Makefile: $(srcdir)/Makefile.in $(top_builddir)/config.status
@case ‘$?’ in
config.status)
cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am–refresh;;
echo ’ cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe)’;
cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe);;
esac;
$(top_builddir)/config.status: $(top_srcdir)/configure $(CONFIG_STATUS_DEPENDENCIES)
$(top_srcdir)/configure: $(am__configure_deps)
$(ACLOCAL_M4): $(am__aclocal_m4_deps)
mostlyclean-libtool:
-rm -f *.lo
clean-libtool:
-rm -rf .libs _libs
tags: TAGS
TAGS:
ctags: CTAGS
CTAGS:
distdir: $(DISTFILES)
@srcdirstrip=echo "$(srcdir)" | sed 's/[].[^$$\\*]/\\\\&/g';
topsrcdirstrip=echo "$(top_srcdir)" | sed 's/[].[^$$\\*]/\\\\&/g';
list=’$(DISTFILES)’;
dist_files=for file in $$list; do echo $$file; done | \ sed -e "s|^$$srcdirstrip/||;t" \ -e "s|^$$topsrcdirstrip/|$(top_builddir)/|;t";
case $$dist_files in
/) $(MKDIR_P) echo "$$dist_files" | \ sed '/\//!d;s|^|$(distdir)/|;s,/[^/]*$$,,' | \ sort -u ;;
esac;
for file in $$dist_files; do
if test -f $$file || test -d $$file; then d=.; else d=$(srcdir); fi;
if test -d $$d/$$file; then
dir=echo "/$$file" | sed -e 's,/[^/]*$$,,';
if test -d $(srcdir)/$$file && test $$d != $(srcdir); then
cp -pR $(srcdir)/$$file $(distdir)$$dir || exit 1;
fi;
cp -pR $$d/$$file $(distdir)$$dir || exit 1;
else
test -f $(distdir)/$$file
|| cp -p $$d/$$file $(distdir)/$$file
|| exit 1;
fi;
done
check-am: all-am
check: check-am
all-am: Makefile
installdirs:
install: install-am
install-exec: install-exec-am
install-data: install-data-am
uninstall: uninstall-am
install-am: all-am
@$(MAKE) $(AM_MAKEFLAGS) install-exec-am install-data-am
installcheck: installcheck-am
install-strip:
$(MAKE) $(AM_MAKEFLAGS) INSTALL_PROGRAM="$(INSTALL_STRIP_PROGRAM)"
install_sh_PROGRAM="$(INSTALL_STRIP_PROGRAM)" INSTALL_STRIP_FLAG=-s
test -z '$(STRIP)' || \ echo "INSTALL_PROGRAM_ENV=STRIPPROG='$(STRIP)'" install
mostlyclean-generic:
clean-generic:
distclean-generic:
-test -z “$(CONFIG_CLEAN_FILES)” || rm -f $(CONFIG_CLEAN_FILES)
maintainer-clean-generic:
@echo “This command is intended for maintainers to use”
@echo "it deletes files that may require special tools to rebuild."
clean: clean-am
clean-am: clean-generic clean-libtool mostlyclean-am
distclean: distclean-am
-rm -f Makefile
distclean-am: clean-am distclean-generic
dvi: dvi-am
dvi-am:
html: html-am
info: info-am
info-am:
install-data-am:
install-dvi: install-dvi-am
install-exec-am:
install-html: install-html-am
install-info: install-info-am
install-man:
install-pdf: install-pdf-am
install-ps: install-ps-am
installcheck-am:
maintainer-clean: maintainer-clean-am
-rm -f Makefile
maintainer-clean-am: distclean-am maintainer-clean-generic
mostlyclean: mostlyclean-am
mostlyclean-am: mostlyclean-generic mostlyclean-libtool
pdf: pdf-am
pdf-am:
ps: ps-am
ps-am:
uninstall-am:
.MAKE: install-am install-strip
.PHONY: all all-am check check-am clean clean-generic clean-libtool
distclean distclean-generic distclean-libtool distdir dvi
dvi-am html html-am info info-am install install-am
install-data install-data-am install-dvi install-dvi-am
install-exec install-exec-am install-html install-html-am
install-info install-info-am install-man install-pdf
install-pdf-am install-ps install-ps-am install-strip
installcheck installcheck-am installdirs maintainer-clean
maintainer-clean-generic mostlyclean mostlyclean-generic
mostlyclean-libtool pdf pdf-am ps ps-am uninstall uninstall-am
Tell versions [3.59,3.63) of GNU make to not export all variables.
Otherwise a system limit (for SysV at least) may be exceeded.
.NOEXPORT:
Il y a aussi divers Makefile.in et Makefile.am a divers endroits, mais je suppose que ce ne sont pas ceux la qu’il faut poster.
Sinon j’ai trouve 3 configure differents :
Un dans ardour-2.5/libs/sigc++2
Un dans ardour-2.5/libs/libsndfile
Un dans ardour-2.5/libs/glibmm2
Je n’ai regarde que le premier, il est tres long. Faut-il que j’en poste un, plusieurs ou pas du tout?
(edit) j’ai pourtant mis les balises “code”, je pensais que ca allait mettre le fichier dans une fenetre…
