Voila sur une debian lenny à jour, le classique apache,php,mysql,bind,samba,ftp,… une GLPI couplé à un OCS Inventory.
J’ai tout configuré età peu près tout marche sauf le déploiement de paquets.
Lorsqu’un client OCS tente de récupérer les paquets dans le dossier download du serveur ocs (/var/www/download), voici le log d’apache :
Directory index forbidden by Options directive: /var/lib/ocsinventory-reports/download/
Voici le /etc/apache2.conf.d/ocsinventory-reports.conf :
OCS Inventory NG Administration Server
Copyleft 2008 OCS Inventory NG Team
Web: ocsinventory-ng.org
This code is open source and may be copied and modified as long as the source
code is always made freely available.
Please refer to the General Public Licence gnu.org/ or Licence.txt
ANY CHANGE ON THIS FILE REQUIRES APACHE RESTART TO TAKE EFFECT
Administration console public pages
Alias used to put Administration Server static page (typically PHP) outside
Apache document root directory
Alias /ocsreports /usr/share/ocsinventory-reports/ocsreports
<Directory /usr/share/ocsinventory-reports/ocsreports>
# By default, users can use console from everywhere
Order deny,allow
Allow from all
Options Indexes FollowSymLinks
DirectoryIndex index.php
AllowOverride Options
# Uncomment following to force use of HTTPS in Administration Server
#SSLRequireSSL
# PHP tuning (not working on all distribution, use php.ini instead)
AddType application/x-httpd-php .php
php_flag file_uploads on
# Some PHP tuning for deployement feature up to 8 MB
# post_max_size must be greater than upload_max_filesize
# because of HTTP headers
php_value post_max_size 40m
php_value upload_max_filesize 38m
# You may have to uncomment following on errors
#php_value max_execution_time -1
#php_value max_input_time -1
# Uncomment following to allow HTTP body request up to 4 MB
# instead default 512 KB
#LimitRequestBody 4194304
Deployment packages download area
Alias to put Deployement package files outside Apache document root directory
Alias /download /var/lib/ocsinventory-reports/download
Je ne comprends donc pas mon problème…
