bonjour,
quand un souci passe un autre arrive…
j’ai voulu me connecter en ssh aujourd’hui sur mon serveur et voici ce qu’il me retourne
00:20:09.973 Bitvise SSH Client, a fully featured SSH2 client.
Copyright (C) 2000-2013 by Bitvise Limited.
Portions Copyright (C) 1995-2003 by Wei Dai.
00:20:09.973 Visit www.bitvise.com for latest information about our SSH2 products.
00:20:09.973 Run 'BvSsh -help' to learn the supported command-line parameters.
00:20:10.155 Loading default profile.
00:20:26.923 Starting a new SSH2 session.
00:20:26.924 Connecting to SSH2 server 192.168.0.33:666.
00:20:27.013 Connected.
00:20:27.021 Starting first key exchange.
00:20:27.021 Server version string: SSH-2.0-OpenSSH_5.5p1 Debian-6+squeeze3
[color=#FF0000]00:20:27.029 Server disconnected without sending a disconnect message.[/color]
00:20:43.018 Starting a new SSH2 session.
00:20:43.019 Connecting to SSH2 server 192.168.0.33:666.
00:20:43.096 Connected.
00:20:43.108 Starting first key exchange.
00:20:43.108 Server version string: SSH-2.0-OpenSSH_5.5p1 Debian-6+squeeze3
[color=#FF0000]00:20:43.161 Server disconnected without sending a disconnect message.[/color]
Par ailleurs, j’ai reçu un mail de Gandi qui me dit ceci :
[quote]Dear Customer,
You receive this mail because an OT&E account on our API is activated on
the handle XXXXXXX (mon id).
A couple of changes in the API will occur on the 9th of September on the
OT&E platform and on the 17th of September on the production platform.
See below changes included in version 3.3.0 :
- hosting methods
Note that we have moved our IaaS to a more flexible system based on
credits. Previous methods to buy products in the hosting namespace have
been removed:
- product.* has been removed
- hosting.product.* has been removed
Also note that the vm., disk., ip., iface., image.* methods, that
are no longer documented, are deprecated and will be removed in a future
release. You should start moving to the hosting.* namespace if you are
still using them.
For example : any actual call to vm.* should be made on hosting.vm.*
now.
For more details, please read entries in
http://doc.rpc.gandi.net/hosting/reference.html
- mailbox methods
On the mailbox namespace two methods have been renamed:
- mailbox_add is now mailbox.create
- mailbox_del is now mailbox.delete
http://doc.rpc.gandi.net/domain/reference.html
- domain methods
3.1 removal of owner.set_dry_run
The method domain.owner.set_dry_run is no longer available.
3.2 signature change on autorenew_activate
The method autorenew_activate in the domain namespace has a new
signature. You should now add the duration in parameter.
New signature : def autorenew_activate(self, apikey, domain, params)
with params = {‘duration’: Integer()}
- contact methods
contact.list and contact.info : the security_question_answer and
security_question_num fields were a security issue fixed in this release
and should not have been available in these methods. They are no longer
part of the return type.
Don’t hesitate to get back to us on the email api-ote@support.gandi.net
if you have any further questions.
Sincerely.
The Gandi team[/quote]
et je n’y comprends rien
pourriez vous m’éclairer svp ?
merci par avance pour votre aide
[Edit] : réponse de FileZilla :
Erreur : Network error: Software caused connection abort
Erreur : Impossible d'établir une connexion au serveur
