bonjour
j a isuivi se tuto pour installer beryl mais j ai un petit probleme
quand je fais la commande glxinfo |grep direct il me renvoie debian:/home/zyriuse# glxinfo | grep direct
direct rendering: No
je ne comprend pas pourquoi
Nous non plus si tu ne nous donnes pas ton xorg.conf, le tuto suivi, quelle version de debian, etc.
Bref, tout ce qui est marqué là en post-it de ce forum
Je te renvoie vers un post de quelqu’un qui a apparemment le même problème que toi avec beryl.
pardon
voci le xorg .conf
[code]# /etc/X11/xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
(Type “man /etc/X11/xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath “/usr/X11R6/lib/X11/fonts/75dpi”
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "bitmap"
Load "ddc"
Load "extmod"
Load "freetype"
Load "int10"
Load "type1"
Load "vbe"
Load "dbe"
Load "synaptics"
Load "glx"
Load “dri”
#Load "GLcore"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Section "Device"
Identifier "ATI Technologies Inc RV350 AP [Radeon 9600]"
Driver "ati"
BusID "PCI:3:0:0"
Option “XAANoOffscreenPixmaps” "true"
Option “AddARGBGLXVisuals” "On"
Option “AllowGLXWithComposite” "true"
EndSection
Section "Monitor"
Identifier "Écran générique"
Option "DPMS"
HorizSync 28-51
VertRefresh 43-60
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Technologies Inc RV350 AP [Radeon 9600]"
Monitor "Écran générique"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
Section "Extensions"
Option “Composite” "Enable"
EndSection
ma version de debian est la
2.6.18-5-k7
lesite avec le tuto http://forum.zebulon.fr/blog/lol2dol/index.php?showentry=480
encore merci a vous tous pour votre aide
Le xorg.conf a l’air correct. Le tuto aussi…
Je viens de regarder dans Trucs&Astuces ce tuto pour beryl avec les drivers libres ATI.
L’auteur a ajouté 2 trucs en plus.
As-tu installé les paquets suivants :
aptitude install libgl1-mesa-glx libgl1-mesa-dri
Je pense que ce sont ces paquets qui manquent et qui causent le message cité dans ton autre post
Il y a aussi :
[quote]- Dans la section “ServerLayout” rajouter :
Option “AIGLX” “true”[/quote]
A voir si ça fonctionne avec ça. Redémarre ton serveur X au besoin.
Bonne beryliade
je viens d essayer se que tu a dis j ai redemarrer le serveur x apres avoir ajouter la ligne mais j ai toujour le meme probleme quand je fais le test
direct rendering: No :shock: :shock:
Tu as bien installé les 2 paquets ?
Quel est le modèle de ta carte graphique ?
le model de ma carte graphique est une ati radeon 9600
j ai reussit a linstaller une fois beryl mais par la suite j ai du reformater le disque
Je parlais de ceux-là :
oui il sont bien installer
Le truc chiant avec ATI, c’est qu’il faut installer le XGL parce que les pilotes proprio ne gèrent pas ce XGL composite. le paquet s’appelle xserver-xgl .
Installe le.
Par contre sans beryl (donc window manager normal avec metacity ou autre) ça lag… Autre problème que j’ai rencontré avec compiz et XGL server: Blender et OOo s’affichent d’office en full screen et ils font à moitié foirer X
Donc, j’ai laissé tomber les bureaux 3D sur ma radeon
Je t’enverrai mon xorg.conf ce soir quand je rentrerai à la maison.
Les Radeon 9600 sont à présent prises en charge par le driver libre (que le posteur utilise). Pour moi, c’est plutôt une histoire de paquet(s) manquant(s), comme le suggère AnatomicJC.
Sinon, les derniers fglrx sont également compatibles AIGLX.
[quote=“zyriuse”]pardon
voci le xorg .conf
package.
Section “Files”
FontPath “/usr/share/fonts/X11/misc”
FontPath “/usr/X11R6/lib/X11/fonts/misc”
FontPath “/usr/share/fonts/X11/cyrillic”
FontPath “/usr/X11R6/lib/X11/fonts/cyrillic”
FontPath “/usr/share/fonts/X11/100dpi/:unscaled”
FontPath “/usr/X11R6/lib/X11/fonts/100dpi/:unscaled”
FontPath “/usr/share/fonts/X11/75dpi/:unscaled”
FontPath “/usr/X11R6/lib/X11/fonts/75dpi/:unscaled”
FontPath “/usr/share/fonts/X11/Type1”
FontPath “/usr/X11R6/lib/X11/fonts/Type1”
FontPath “/usr/share/fonts/X11/100dpi”
FontPath “/usr/X11R6/lib/X11/fonts/100dpi”
FontPath “/usr/share/fonts/X11/75dpi”
FontPath “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType”
EndSection
Section “Module”
Load “bitmap”
Load “ddc”
Load “extmod”
Load “freetype”
Load “int10”
Load “type1”
Load “vbe”
Load “dbe”
Load “synaptics”
Load “glx”
Load “dri”
#Load “GLcore”
EndSection
Section “InputDevice”
Identifier “Generic Keyboard”
Driver “kbd”
Option “CoreKeyboard”
Option “XkbRules” “xorg”
Option “XkbModel” “pc105”
Option “XkbLayout” “fr”
Option “XkbVariant” “latin9”
EndSection
Identifier “Configured Mouse”
Driver “mouse”
Option “CorePointer”
Option “Device” “/dev/input/mice”
Option “Protocol” “ImPS/2”
Option “Emulate3Buttons” “true”
EndSection
Section “Device”
Identifier “ATI Technologies Inc RV350 AP [Radeon 9600]”
Driver “ati”
BusID “PCI:3:0:0”
Option “XAANoOffscreenPixmaps” “true”
Option “AddARGBGLXVisuals” “On”
Option “AllowGLXWithComposite” “true”
EndSection
Section “Monitor”
Identifier “Écran générique”
Option “DPMS”
HorizSync 28-51
VertRefresh 43-60
EndSection
Section “Screen”
Identifier “Default Screen”
Device “ATI Technologies Inc RV350 AP [Radeon 9600]”
Monitor “Écran générique”
DefaultDepth 24
SubSection “Display”
Depth 1
Modes “1024x768” “800x600” “640x480”
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section “ServerLayout”
Identifier “Default Layout”
Screen “Default Screen”
InputDevice “Generic Keyboard”
InputDevice “Configured Mouse”
EndSection
Section “DRI”
Mode 0666
EndSection
Section “Extensions”
Option “Composite” “Enable”
EndSection
2.6.18-5-k7
encore merci a vous tous pour votre aide[/quote]
Ajoutes ceci à la fin de ton xorg.conf
Section "Module"
Load "glx"
EndSection
il y ai deja dans xorg.conf
a la section module
Ha wé autant pour moi j’avais pas vu
