Problème de dépendances avec apt [Résolu]
ca y est ! Après deux années passées avec des systèmes a base debian et sans jamais aucun problème avec apt et le chargement des packages, j’ai mon premier souci.
Ce matin après un apt-get update, et un apt-get upgrade, j’ai voulu installé xvidcap et voila le résultat [code]apt-get install xvidcap
Reading package lists…
Building dependency tree…
Reading state information…
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
xvidcap: Depends: libavcodec51 (>= 3:20080414) but 0.svn20080206-8 is to be installed
Depends: libavdevice52 (>= 3:20080414) but 0.svn20080206-8 is to be installed
Depends: libavformat52 (>= 3:20080414) but 0.svn20080206-8 is to be installed
Depends: libavutil49 (>= 3:20080414) but 0.svn20080206-8 is to be installed
Depends: libswscale0 (>= 3:20080414) but 0.svn20080206-8 is to be installed
Donc en lisant cela, je me dis : problème de dépendances donc j’essaie d’installer libavcodec51 et la de nouveau [code]Reading package lists…
The following extra packages will be installed:
libavutil49
The following NEW packages will be installed:
libavcodec51 libavutil49
0 upgraded, 2 newly installed, 0 to remove and 397 not upgraded.
Need to get 0B/1693kB of archives.
After this operation, 4055kB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
libavutil49 libavcodec51
Authentication warning overridden.
(Reading database … 63481 files and directories currently installed.)
Unpacking libavutil49 (from …/libavutil49_0.svn20080206-8_i386.deb) …
dpkg: error processing /var/cache/apt/archives/libavutil49_0.svn20080206-8_i386.deb (–unpack):
trying to overwrite `/usr/lib/libavutil.so.49.6.0’, which is also in package libavutilcvs49
Unpacking libavcodec51 (from …/libavcodec51_0.svn20080206-8_i386.deb) …
dpkg: error processing /var/cache/apt/archives/libavcodec51_0.svn20080206-8_i386.deb (–unpack):
trying to overwrite `/usr/lib/libavcodec.so.51’, which is also in package libavcodeccvs51
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)[/code]
Ma question est donc : que puis je faire pour resoudre ce problème ?
Ps : Ah oui, ma distribution sur laquelle j’ai ce problème est un AntiX-M7.2, dérivée de Mepis, dérivée de Debian
viewtopic.php?f=3&t=14997
Bonjour et merci ,
Voici ce que j’ai fais :
 - j'ai supprimé les librairies existantes
 - puis j'ai reinstallé avec cette commande [code]apt-get install libavformat52=3:20080610-0.0[/code]
 - idem pour les autres librairies qui manquaient
 - et enfin j'ai installé xvidcap sans difficulté.
Le problème est pour l’instant résolu.
Merci encore
