Si tu recompiles ton noyau, regardes dans la section suivante de ton .config:
[code]burp:/usr/src/linux# grep HIGH .config
CONFIG_NOHIGHMEM=y
CONFIG_HIGHMEM4G is not set
CONFIG_HIGHMEM64G is not set
Je suis pas sûr mais il me semble que en dessus de 1GB de RAM, tu peux mettre l’option CONFIG_HIGHMEM4G=y
Regardes la doc ou au moment du make menuconfig pour confirmer ce que je dis…
Sinon, as-tu essayé:
[quote]burp:/usr/src/linux# apt-cache show memtest86
Package: memtest86
Priority: optional
Section: misc
Installed-Size: 152
Maintainer: Yann Dirson dirson@debian.org
Architecture: i386
Version: 3.2-1.1
Suggests: hwtools, sysutils, kernel-patch-badram, memtest86+, grub (>= 0.95+cvs20040624), mtools
Filename: pool/main/m/memtest86/memtest86_3.2-1.1_i386.deb
MD5sum: b05e1f2608d79aef64840183584ed119
Description: A thorough real-mode memory tester
Memtest86 scans your RAM for errors.
This version is apparently not as actively maintained upstream as
memtest86+ is. Especially if you own a recent computer on which it
does not work, you should consider looking at the memtest86+ package.
This tester runs independently of any OS - it is run at computer
boot-up, so that it can test all of you memory. You may want to
look at memtest' (in packagesysutils’), which allows to test
your memory within Linux, but this one won’t be able to test your
whole RAM.
This used to be part of the hwtools package, which still contains
another real-mode memory tester (memmxtest) optimized for mmx
machines (but apparently not maintained any more).
It can output a list of bad RAM regions usable by the BadRAM kernel
patch, so that you can still use you old RAM with one or 2 bad bits.
A convenience script is also provided to make a grub-based floppy or
image.
Pour tester ta RAM ?
