J’ai un soucis pour configurer proftpd.
Lorsque j’upload les fichiers, je n’ai pas accès aux droits qu’il y a dessus (les dossier sont en 777)
Donc, impossible pour mon ftp d’écraser les fichiers existant lorsqu’il y a une mise à jour.
[code]# Includes DSO modules
Include /etc/proftpd/modules.conf
Set off to disable IPv6 support which is annoying on IPv4 only boxes.
UseIPv6 on
If set on you can experience a longer connection delay in many cases.
IdentLookups off
ServerName "Arcora Ltd FTP"
ServerType standalone
DeferWelcome off
MultilineRFC2228 on
DefaultServer on
ShowSymlinks on
TimeoutNoTransfer 800
TimeoutStalled 800
TimeoutIdle 1200
DisplayLogin welcome.msg
DisplayChdir .message true
ListOptions “-l”
DenyFilter *.*/
Use this to jail all users in their homes
DefaultRoot ~
Users require a valid shell listed in /etc/shells to login.
Use this directive to release that constrain.
RequireValidShell off
Port 21 is the standard FTP port
Port 4645
In some cases you have to specify passive ports range to by-pass
firewall limitations. Ephemeral ports can be used for that, but
feel free to use a more narrow range.
PassivePorts 49152 65534
If your host was NATted, this option is useful in order to
allow passive tranfers to work. You have to use your public
address and opening the passive ports used on your firewall as well.
MasqueradeAddress 1.2.3.4
This is useful for masquerading address with dynamic IPs:
refresh any configured MasqueradeAddress directives every 8 hours
# DynMasqRefresh 28800To prevent DoS attacks, set the maximum number of child processes
to 30. If you need to allow more than 30 concurrent connections
at once, simply increase this value. Note that this ONLY works
in standalone mode, in inetd mode you should use an inetd server
that allows you to limit maximum number of processes per service
(such as xinetd)
MaxInstances 20
Set the user and group that the server normally runs at.
User nobody
Group saver
Umask 022 is a good standard umask to prevent new files and dirs
(second parm) from being group and world writable.
Umask 000 000
Normally, we want files to be overwriteable.
AllowOverwrite on
Uncomment this if you are using NIS or LDAP via NSS to retrieve passwords:
PersistentPasswd off
This is required to use both PAM-based authentication and local passwords
AuthOrder mod_auth_pam.c* mod_auth_unix.c
Be warned: use of this directive impacts CPU average load!
Uncomment this if you like to see progress and transfer rate with ftpwho
in downloads. That is not needed for uploads rates.
UseSendFile off
TransferLog /var/log/proftpd/xferlog
SystemLog /var/log/proftpd/proftpd.log
Delay engine reduces impact of the so-called Timing Attack described in
http://security.lss.hr/index.php?page=details&ID=LSS-2004-10-02
It is on by default.
DelayEngine on ControlsEngine off ControlsMaxClients 10 ControlsLog /var/log/proftpd/controls.log ControlsInterval 25 ControlsSocket /var/run/proftpd/proftpd.sock AdminControlsEngine off # # Alternative authentication frameworks # #Include /etc/proftpd/ldap.conf #Include /etc/proftpd/sql.confThis is used for FTPS connections
#Include /etc/proftpd/tls.conf
Useful to keep VirtualHost/VirtualRoot directives separated
#Include /etc/proftpd/virtuals.con
A basic anonymous configuration, no upload directories.
<Anonymous ~ftp>
User ftp
Group nogroup
# We want clients to be able to login with “anonymous” as well as “ftp”
UserAlias anonymous ftp
# Cosmetic changes, all files belongs to ftp user
DirFakeUser on ftp
DirFakeGroup on ftp
# Limit the maximum number of anonymous logins
MaxClients 10
# We want ‘welcome.msg’ displayed at login, and ‘.message’ displayed
# in each newly chdired directory.
# Limit WRITE everywhere in the anonymous chroot
<Directory *>
DenyAll
# Uncomment this if you’re brave.
# # Umask 022 is a good standard umask to prevent new files and dirs
# # (second parm) from being group and world writable.
# Umask 022 022
# DenyAll
# AllowAll
TLSEngine on TLSLog /var/log/proftpd-tls.log TLSProtocol SSLv23 TLSOptions NoCertRequestAre clients required to use FTP over TLS when talking to this server?
TLSRequired on
TLSRSACertificateFile /etc/proftpd/ftpd-rsa.pem
TLSRSACertificateKeyFile /etc/proftpd/ftpd-rsa-key.pem
Authenticate clients that want to use FTP over TLS?
TLSVerifyClient off
<Directory /home//saving/>
ncludes DSO modules
UseIPv6 on
IdentLookups off
DeferWelcome off
MultilineRFC2228 on
DefaultServer on
ShowSymlinks on
TimeoutStalled 800
TimeoutIdle 1200
ListOptions “-l”
DenyFilter *.*/
DefaultRoot ~
Port 4645
“/etc/proftpd/proftpd.conf” 198L, 5535C # (second parm) from being group and world writable.
Umask 666
AllowOverwrite on
Je bloque sur la partie droit utilisateur, je ne sais pas pourquoi il n’accorde pas les droits sur mes fichiers.
Pouvez-vous m’aider ?
