c’est revenu aprés avoir réinstaller:
amilo:/home/hulk# dmesg
Initializing cgroup subsys cpuset
Linux version 2.6.24-1-amd64 (Debian 2.6.24-6) (waldi@debian.org) (gcc version 4.1.3 20080308 (prerelease) (Debian 4.1.2-21)) #1 SMP Fri Apr 18 23:08:22 UTC 2008
Command line: root=/dev/hda2 ro quiet
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000003ffd0000 (usable)
BIOS-e820: 000000003ffd0000 - 000000003ffde000 (ACPI data)
BIOS-e820: 000000003ffde000 - 0000000040000000 (ACPI NVS)
BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
BIOS-e820: 00000000fecc0000 - 00000000fecc1000 (reserved)
BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
Entering add_active_range(0, 0, 159) 0 entries of 3200 used
Entering add_active_range(0, 256, 262096) 1 entries of 3200 used
end_pfn_map = 1048576
DMI 2.3 present.
ACPI: RSDP 000F9470, 0024 (r2 ACPIAM)
ACPI: XSDT 3FFD0100, 0044 (r1 A M I OEMXSDT 1000613 MSFT 97)
ACPI: FACP 3FFD0290, 00F4 (r3 A M I OEMFACP 1000613 MSFT 97)
ACPI: DSDT 3FFD0430, 4650 (r1 P50CA F20_____ 1 INTL 2002026)
ACPI: FACS 3FFDE000, 0040
ACPI: APIC 3FFD0390, 0060 (r1 A M I OEMAPIC 1000613 MSFT 97)
ACPI: MCFG 3FFD03F0, 003C (r1 A M I OEMMCFG 1000613 MSFT 97)
ACPI: OEMB 3FFDE040, 005B (r1 A M I AMI_OEM 1000613 MSFT 97)
ACPI: DMI detected: Fujitsu Siemens
Scanning NUMA topology in Northbridge 24
CPU has 1 num_cores
No NUMA configuration found
Faking a node at 0000000000000000-000000003ffd0000
Bootmem setup node 0 0000000000000000-000000003ffd0000
Zone PFN ranges:
DMA 0 -> 4096
DMA32 4096 -> 1048576
Normal 1048576 -> 1048576
Movable zone start PFN for each node
early_node_map[2] active PFN ranges
0: 0 -> 159
0: 256 -> 262096
On node 0 totalpages: 261999
DMA zone: 56 pages used for memmap
DMA zone: 1065 pages reserved
DMA zone: 2878 pages, LIFO batch:0
DMA32 zone: 3527 pages used for memmap
DMA32 zone: 254473 pages, LIFO batch:31
Normal zone: 0 pages used for memmap
Movable zone: 0 pages used for memmap
ACPI: PM-Timer IO Port: 0x808
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Processor #0 (Bootup-CPU)
ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 1, address 0xfec00000, GSI 0-23
ACPI: IOAPIC (id[0x02] address[0xfecc0000] gsi_base[24])
IOAPIC[1]: apic_id 2, address 0xfecc0000, GSI 24-47
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Setting APIC routing to flat
Using ACPI (MADT) for SMP configuration information
swsusp: Registered nosave memory region: 000000000009f000 - 00000000000a0000
swsusp: Registered nosave memory region: 00000000000a0000 - 00000000000e0000
swsusp: Registered nosave memory region: 00000000000e0000 - 0000000000100000
Allocating PCI resources starting at 50000000 (gap: 40000000:a0000000)
SMP: Allowing 1 CPUs, 0 hotplug CPUs
PERCPU: Allocating 34400 bytes of per cpu data
Built 1 zonelists in Node order, mobility grouping on. Total pages: 257351
Policy zone: DMA32
Kernel command line: root=/dev/hda2 ro quiet
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 32768 bytes)
Extended CMOS year: 2000
TSC calibrated against PM_TIMER
time.c: Detected 800.025 MHz processor.
Console: colour VGA+ 80x25
console [tty0] enabled
Checking aperture...
CPU 0: aperture @ d0000000 size 256 MB
Memory: 1022516k/1048384k available (2143k kernel code, 25480k reserved, 1003k data, 316k init)
Calibrating delay using timer specific routine.. 1602.42 BogoMIPS (lpj=3204857)
Security Framework initialized
SELinux: Disabled at boot.
Capability LSM initialized
Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
Mount-cache hash table entries: 256
Initializing cgroup subsys ns
Initializing cgroup subsys cpuacct
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 512K (64 bytes/line)
CPU 0/0 -> Node 0
SMP alternatives: switching to UP code
Freeing SMP alternatives: 25k freed
ACPI: Core revision 20070126
Using local APIC timer interrupts.
APIC timer calibration result 12500411
Detected 12.500 MHz APIC timer.
Brought up 1 CPUs
net_namespace: 120 bytes
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: Using MMCONFIG at e0000000 - efffffff
ACPI: EC: Look up EC in DSDT
ACPI: EC: non-query interrupt received, switching to interrupt mode
ACPI: Interpreter enabled
ACPI: (supports S0 S1 S3 S4 S5)
ACPI: Using IOAPIC for interrupt routing
ACPI: EC: GPE = 0x0, I/O: command/status = 0x66, data = 0x62
ACPI: EC: driver started in interrupt mode
ACPI: PCI Root Bridge [PCI0] (0000:00)
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P2._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P3._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 *10 11 12 14 15)
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
ACPI: bus type pnp registered
pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active)
pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
pnp 00:03: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
pnp 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
pnp 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
pnp 00:08: Plug and Play ACPI device, IDs SYN0802 SYN0800 PNP0f13 (active)
pnp 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
pnp 00:0a: Plug and Play ACPI device, IDs PNP0c01 (active)
pnp: PnP ACPI: found 11 devices
ACPI: ACPI bus type pnp unregistered
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
PCI: Cannot allocate resource region 7 of bridge 0000:00:03.0
PCI: Cannot allocate resource region 8 of bridge 0000:00:03.0
PCI: Cannot allocate resource region 8 of bridge 0000:00:03.2
NET: Registered protocol family 8
NET: Registered protocol family 20
Time: tsc clocksource has been installed.
pnp: the driver 'system' has been registered
system 00:06: ioport range 0x3e0-0x3e7 has been reserved
system 00:06: ioport range 0x4d0-0x4d1 has been reserved
system 00:06: ioport range 0x800-0x87f has been reserved
system 00:06: ioport range 0x400-0x41f has been reserved
system 00:06: driver attached
system 00:07: iomem range 0xfec00000-0xfec00fff could not be reserved
system 00:07: iomem range 0xfee00000-0xfee00fff could not be reserved
system 00:07: driver attached
system 00:09: iomem range 0xe0000000-0xefffffff could not be reserved
system 00:09: driver attached
system 00:0a: iomem range 0x0-0x9ffff could not be reserved
system 00:0a: iomem range 0xc0000-0xcffff has been reserved
system 00:0a: iomem range 0xe0000-0xfffff could not be reserved
system 00:0a: iomem range 0x100000-0x3fffffff could not be reserved
system 00:0a: iomem range 0xfff80000-0xffffffff could not be reserved
system 00:0a: driver attached
PCI: Bridge: 0000:00:01.0
IO window: disabled.
MEM window: disabled.
PREFETCH window: disabled.
PCI: Bridge: 0000:00:02.0
IO window: 9000-bfff
MEM window: fea00000-feafffff
PREFETCH window: aff00000-bfefffff
PCI: Bridge: 0000:00:03.0
PCI: Bridge: 0000:00:03.2
PCI: Setting latency timer of device 0000:00:01.0 to 64
ACPI: PCI Interrupt 0000:00:02.0[A] -> GSI 27 (level, low) -> IRQ 27
PCI: Setting latency timer of device 0000:00:02.0 to 64
ACPI: PCI Interrupt 0000:00:03.0[A] -> GSI 31 (level, low) -> IRQ 31
PCI: Setting latency timer of device 0000:00:03.0 to 64
ACPI: PCI Interrupt 0000:00:03.2[C] -> GSI 31 (level, low) -> IRQ 31
PCI: Setting latency timer of device 0000:00:03.2 to 64
IP route cache hash table entries: 32768 (order: 6, 262144 bytes)
TCP established hash table entries: 131072 (order: 9, 2097152 bytes)
TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
checking if image is initramfs...<7>Switched to high resolution mode on CPU 0
it is
Freeing initrd memory: 6737k freed
audit: initializing netlink socket (disabled)
audit(1211087434.592:1): initialized
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
PCI: VIA PCI bridge detected. Disabling DAC.
Boot video device is 0000:02:00.0
assign_interrupt_mode Found MSI capability
Allocate Port Service[0000:00:02.0:pcie00]
Allocate Port Service[0000:00:02.0:pcie01]
Allocate Port Service[0000:00:02.0:pcie03]
Allocate Port Service[0000:00:03.0:pcie00]
Allocate Port Service[0000:00:03.0:pcie01]
Allocate Port Service[0000:00:03.0:pcie03]
Allocate Port Service[0000:00:03.2:pcie00]
Allocate Port Service[0000:00:03.2:pcie01]
Allocate Port Service[0000:00:03.2:pcie03]
AER service couldn't init device 0000:00:02.0:pcie01 - no _OSC support
AER service couldn't init device 0000:00:03.0:pcie01 - no _OSC support
AER service couldn't init device 0000:00:03.2:pcie01 - no _OSC support
Real Time Clock Driver v1.12ac
Linux agpgart interface v0.102
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
pnp: the driver 'serial' has been registered
RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
input: Macintosh mouse button emulation as /class/input/input0
pnp: the driver 'i8042 kbd' has been registered
i8042 kbd 00:03: driver attached
pnp: the driver 'i8042 aux' has been registered
i8042 aux 00:08: driver attached
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
i8042.c: Detected active multiplexing controller, rev 1.0.
serio: i8042 KBD port at 0x60,0x64 irq 1
serio: i8042 AUX0 port at 0x60,0x64 irq 12
serio: i8042 AUX1 port at 0x60,0x64 irq 12
serio: i8042 AUX2 port at 0x60,0x64 irq 12
serio: i8042 AUX3 port at 0x60,0x64 irq 12
mice: PS/2 mouse device common for all mice
cpuidle: using governor ladder
cpuidle: using governor menu
TCP bic registered
NET: Registered protocol family 17
registered taskstats version 1
Freeing unused kernel memory: 316k freed
input: AT Translated Set 2 keyboard as /class/input/input1
ACPI: CPU0 (power states: C1[C1] C3[C3])
ACPI: Processor [CPU1] (supports 16 throttling states)
ACPI: Thermal Zone [THRM] (50 C)
ACPI: PCI Interrupt 0000:00:08.0[A] -> GSI 16 (level, low) -> IRQ 16
firewire_ohci: Added fw-ohci device 0000:00:08.0, OHCI version 1.10
r8169 Gigabit Ethernet driver 2.2LK-NAPI loaded
ACPI: PCI Interrupt 0000:00:09.0[A] -> GSI 17 (level, low) -> IRQ 17
PCI: Disallowing DAC for device 0000:00:09.0
eth0: RTL8169sb/8110sb at 0xffffc200001da400, 00:03:0d:35:26:15, XID 10000000 IRQ 17
ACPI: PCI Interrupt 0000:00:0a.0[A] -> GSI 18 (level, low) -> IRQ 18
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
pnp: the driver 'ide' has been registered
USB Universal Host Controller Interface driver v3.0
ssb: Sonics Silicon Backplane found on PCI device 0000:00:0a.0
ACPI: PCI Interrupt 0000:00:10.0[A] -> GSI 21 (level, low) -> IRQ 21
uhci_hcd 0000:00:10.0: UHCI Host Controller
uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:10.0: irq 21, io base 0x0000dc00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:10.1[A] -> GSI 21 (level, low) -> IRQ 21
uhci_hcd 0000:00:10.1: UHCI Host Controller
uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:10.1: irq 21, io base 0x0000d480
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:10.2[B] -> GSI 21 (level, low) -> IRQ 21
uhci_hcd 0000:00:10.2: UHCI Host Controller
uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:10.2: irq 21, io base 0x0000d400
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:10.3[B] -> GSI 21 (level, low) -> IRQ 21
uhci_hcd 0000:00:10.3: UHCI Host Controller
uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 4
uhci_hcd 0000:00:10.3: irq 21, io base 0x0000d080
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
firewire_core: created new fw device fw0 (0 config rom retries, S400)
VP_IDE: IDE controller (0x1106:0x0571 rev 0x06) at PCI slot 0000:00:0f.1
ACPI: PCI Interrupt 0000:00:0f.1[A] -> GSI 20 (level, low) -> IRQ 20
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt8237 (rev 00) IDE UDMA133 controller on pci0000:00:0f.1
ide0: BM-DMA at 0xfc00-0xfc07, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0xfc08-0xfc0f, BIOS settings: hdc:DMA, hdd:pio
Probing IDE interface ide0...
SCSI subsystem initialized
libata version 3.00 loaded.
hdb: IRQ probe failed (0xffffffffffdeecfc)
usb 4-1: new low speed USB device using uhci_hcd and address 2
usb 4-1: configuration #1 chosen from 1 choice
usbcore: registered new interface driver hiddev
input: Microsoft Microsoft Wireless Optical Mouse� 1.00 as /class/input/input2
input,hidraw0: USB HID v1.11 Mouse [Microsoft Microsoft Wireless Optical Mouse� 1.00] on usb-0000:00:10.3-1
usbcore: registered new interface driver usbhid
drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
hda: FUJITSU MHU2100AT, ATA DISK drive
hda: host max PIO5 wanted PIO255(auto-tune) selected PIO4
hda: UDMA/100 mode selected
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: _NEC DVD+/-RW ND-6650A, ATAPI CD/DVD-ROM drive
hdc: host max PIO5 wanted PIO255(auto-tune) selected PIO4
hdc: UDMA/33 mode selected
ide1 at 0x170-0x177,0x376 on irq 15
ACPI: PCI Interrupt 0000:00:10.4[C] -> GSI 21 (level, low) -> IRQ 21
ehci_hcd 0000:00:10.4: EHCI Host Controller
ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 5
ehci_hcd 0000:00:10.4: irq 21, io mem 0xfebff000
ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb5: configuration #1 chosen from 1 choice
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 8 ports detected
sata_via 0000:00:0f.0: version 2.3
ACPI: PCI Interrupt 0000:00:0f.0[B] -> GSI 20 (level, low) -> IRQ 20
sata_via 0000:00:0f.0: routed to hard irq line 3
scsi0 : sata_via
scsi1 : sata_via
ata1: SATA max UDMA/133 cmd 0xec00 ctl 0xe480 bmdma 0xe000 irq 20
ata2: SATA max UDMA/133 cmd 0xe400 ctl 0xe080 bmdma 0xe008 irq 20
usb 4-1: USB disconnect, address 2
ata1: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
ata2: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
usb 4-1: new low speed USB device using uhci_hcd and address 3
hda: max request size: 128KiB
hda: 195371568 sectors (100030 MB) w/8192KiB Cache, CHS=65535/16/63
hda: cache flushes supported
hda: hda1 hda2 hda3 < hda5 hda6 >
hdc: ATAPI 24X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache
Uniform CD-ROM driver Revision: 3.20
input: Microsoft Microsoft Wireless Optical Mouse� 1.00 as /class/input/input3
Attempting manual resume
swsusp: Marking nosave pages: 000000000009f000 - 0000000000100000
swsusp: Basic memory bitmaps created
swsusp: Basic memory bitmaps freed
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
input: Power Button (FF) as /class/input/input4
ACPI: Power Button (FF) [PWRF]
input: Lid Switch as /class/input/input5
ACPI: Lid Switch [LID]
input: Sleep Button (CM) as /class/input/input6
ACPI: Sleep Button (CM) [SLPB]
input: Power Button (CM) as /class/input/input7
ACPI: Power Button (CM) [PWRB]
ACPI: AC Adapter [AC0] (on-line)
ACPI: Battery Slot [BAT1] (battery present)
input: Video Bus as /class/input/input8
ACPI: Video Device [PEG] (multi-head: yes rom: no post: no)
b43-phy0: Broadcom 4318 WLAN found
phy0: Selected rate control algorithm 'simple'
input: PC Speaker as /class/input/input9
ACPI: PCI Interrupt 0000:00:11.6[C] -> GSI 22 (level, low) -> IRQ 22
PCI: Setting latency timer of device 0000:00:11.6 to 64
Synaptics Touchpad, model: 1, fw: 5.9, id: 0x6eb1, caps: 0xa04711/0x40a
input: SynPS/2 Synaptics TouchPad as /class/input/input10
ACPI: PCI Interrupt 0000:00:11.5[C] -> GSI 22 (level, low) -> IRQ 22
PCI: Setting latency timer of device 0000:00:11.5 to 64
Adding 3020180k swap on /dev/hda5. Priority:-1 extents:1 across:3020180k
EXT3 FS on hda2, internal journal
loop: module loaded
EXT3 FS on hda6, internal journal
r8169: eth0: link down
powernow-k8: Found 1 AMD Turion(tm) 64 Mobile Technology MT-32 processors (1 cpu cores) (version 2.20.00)
powernow-k8: 0 : fid 0xa (1800 MHz), vid 0xa
powernow-k8: 1 : fid 0x8 (1600 MHz), vid 0xc
powernow-k8: 2 : fid 0x0 (800 MHz), vid 0x16
Marking TSC unstable due to cpufreq changes
Time: acpi_pm clocksource has been installed.
Clocksource tsc unstable (delta = 619609345 ns)
pnp: the driver 'parport_pc' has been registered
lp: driver loaded but no devices found
ppdev: user-space parallel port driver
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
ADDRCONF(NETDEV_UP): eth0: link is not ready
Bluetooth: Core ver 2.11
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP ver 2.9
Bluetooth: L2CAP socket layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM ver 1.8
input: b43-phy0 as /class/input/input11
Registered led device: b43-phy0:tx
Registered led device: b43-phy0:rx
Registered led device: b43-phy0:radio
ADDRCONF(NETDEV_UP): wlan0: link is not ready
fglrx: module license 'Proprietary. (C) 2002 - ATI Technologies, Starnberg, GERMANY' taints kernel.
[fglrx] Maximum main memory to use for locked dma buffers: 923 MBytes.
[fglrx] ASYNCIO init succeed!
[fglrx] PAT is enabled successfully!
[fglrx] module loaded - fglrx 8.47.3 [Feb 25 2008] on minor 0
ACPI: PCI Interrupt 0000:02:00.0[A] -> GSI 24 (level, low) -> IRQ 24
hdc: drive_cmd: status=0x51 { DriveReady SeekComplete Error }
hdc: drive_cmd: error=0x04 { AbortedCommand }
ide: failed opcode was: 0xef
[fglrx] Reserve Block - 0 offset = 0X7ffb000 length = 0X5000
[fglrx] Reserve Block - 1 offset = 0X0 length = 0X40000
[fglrx] Reserve Block - 2 offset = 0X7fbb000 length = 0X40000
[fglrx] interrupt source 20008000 successfully enabled
[fglrx] enable ID = 0x00000004
[fglrx] Receive enable interrupt message with irqEnableMask: 20008000
[fglrx] interrupt source 10000000 successfully enabled
[fglrx] enable ID = 0x00000005
[fglrx] Receive enable interrupt message with irqEnableMask: 10000000
r8169: eth0: link up
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
eth0: no IPv6 routers present
