Problème de lancement de proftpd
Je viens vers vous car j’aqi un problème de lancement de mon serveur FTP.
Voilà, j’ai juste fait un apt-get de ce serveur et puis j’ai juste supprimé (désactivé) le support IPv6. La preuve proftpd -t /etc/proftpd/proftpd.conf me sert à tester ma configuration, mais [code]Checking syntax of configuration file
  • unknown parameter: ‘/etc/proftpd/proftpd.conf’[/code]
    donc je ne sais pas pourquoi ce problème est là.
    Pour information, la commande proftpd -V me donne
[code]Compile-time Settings:
Version: 1.3.0
Platform: LINUX
Built With:
configure linux gnu
Files:
Configuration File:
Pid File:
/var/run/proftpd.pid
Scoreboard File:
/var/run/proftpd/proftpd.scoreboard
Shared Module Directory:
/usr/lib/proftpd
Features:
+ Autoshadow support
+ Controls support
+ curses support
+ Developer support
+ DSO support
+ IPv6 support
+ Largefile support
+ ncurses support
+ POSIX ACL support
+ Shadow file support
+ Sendfile support
Tunable Options:
PR_TUNABLE_BUFFER_SIZE = 1024
PR_TUNABLE_GLOBBING_MAX = 8
PR_TUNABLE_HASH_TABLE_SIZE = 40
PR_TUNABLE_NEW_POOL_SIZE = 512
PR_TUNABLE_RCVBUFSZ = 87380
PR_TUNABLE_SCOREBOARD_BUFFER_SIZE = 80
PR_TUNABLE_SCOREBOARD_SCRUB_TIMER = 30
PR_TUNABLE_SELECT_TIMEOUT = 30
PR_TUNABLE_SNDBUFSZ = 16384
PR_TUNABLE_TIMEOUTIDENT = 10
PR_TUNABLE_TIMEOUTIDLE = 600
PR_TUNABLE_TIMEOUTLINGER = 180
PR_TUNABLE_TIMEOUTLOGIN = 300
PR_TUNABLE_TIMEOUTNOXFER = 300
PR_TUNABLE_TIMEOUTSTALLED = 3600
PR_TUNABLE_XFER_BUFFER_SIZE = 16384
PR_TUNABLE_XFER_SCOREBOARD_UPDATES = 10
et mon fichier de configurtion est
[code]#
/etc/proftpd/proftpd.conf – This is a basic ProFTPD configuration file.
To really apply changes reload proftpd after modifications.
Includes DSO modules
Include /etc/proftpd/modules.conf
Set off to disable IPv6 support which is annoying on IPv4 only boxes.
UseIPv6 off
ServerName "Debian"
ServerType standalone
DeferWelcome off
MultilineRFC2228 on
DefaultServer on
ShowSymlinks on
TimeoutNoTransfer 600
TimeoutStalled 600
TimeoutIdle 1200
DisplayLogin welcome.msg
DisplayFirstChdir .message
ListOptions “-l”
DenyFilter *.*/
Port 21 is the standard FTP port.
Port 21
In some cases you have to specify passive ports range to by-pass
firewall limitations. Ephemeral ports can be used for that, but
feel free to use a more narrow range.
PassivePorts 49152 65534
To prevent DoS attacks, set the maximum number of child processes
to 30. If you need to allow more than 30 concurrent connections
at once, simply increase this value. Note that this ONLY works
in standalone mode, in inetd mode you should use an inetd server
that allows you to limit maximum number of processes per service
(such as xinetd)
MaxInstances 30
Set the user and group that the server normally runs at.
User proftpd
Group nogroup
Umask 022 is a good standard umask to prevent new files and dirs
(second parm) from being group and world writable.
Umask 022 022
Normally, we want files to be overwriteable.
AllowOverwrite on
Uncomment this if you are using NIS or LDAP to retrieve passwords:
PersistentPasswd off
Be warned: use of this directive impacts CPU average load!
Uncomment this if you like to see progress and transfer rate with ftpwho
in downloads. That is not needed for uploads rates.
UseSendFile off
TransferLog /var/log/proftpd/xferlog
SystemLog /var/log/proftpd/proftpd.log
TLSEngine off QuotaEngine on Ratios on
Delay engine reduces impact of the so-called Timing Attack described in
http://security.lss.hr/index.php?page=details&ID=LSS-2004-10-02
It is on by default.
DelayEngine on ControlsEngine on ControlsMaxClients 2 ControlsLog /var/log/proftpd/controls.log ControlsInterval 5 ControlsSocket /var/run/proftpd/proftpd.sock AdminControlsEngine on
A basic anonymous configuration, no upload directories.
<Anonymous ~ftp>
User ftp
Group nogroup
# We want clients to be able to login with “anonymous” as well as “ftp”
UserAlias anonymous ftp
# Cosmetic changes, all files belongs to ftp user
DirFakeUser on ftp
DirFakeGroup on ftp
RequireValidShell off
# Limit the maximum number of anonymous logins
MaxClients 10
# We want ‘welcome.msg’ displayed at login, and ‘.message’ displayed
# in each newly chdired directory.
# Limit WRITE everywhere in the anonymous chroot
<Directory *>
DenyAll
# Uncomment this if you’re brave.
# # Umask 022 is a good standard umask to prevent new files and dirs
# # (second parm) from being group and world writable.
# Umask 022 022
# DenyAll
# AllowAll
SI quelqu’un a une idée de ce qui se passe. Parce que moi je sèche.
J’ai pas de quoi tester mais à mon avis,
l’option “-t” permet de tester directement le fichier de configuration par défault sans avoir
donc de chemin à préciser, c’est avec l’option ‘-c’ que tu peux indiquer en plus un autre fichier de configuration à tester que celui par défault.
[quote=“swiip81”]J’ai pas de quoi tester mais à mon avis,
donc de chemin à préciser, c’est avec l’option ‘-c’ que tu peux indiquer en plus un autre fichier de configuration à tester que celui par défault.[/quote] Oui c’est vrai je m’étonne d’ailleurs je ne sais pas pourquoi j’ai préciser un fichier alors que j’utilsais -t. Maintenant mon ftp fonction, il s’agit de recompiler le tout (pour utiliser des modules un peu exotiques).
mais bref merci
