bonjour,
lorsque je veux lire ce fichier : tv-direct.fr/flux_tf1live.asx
vlc essaye de télécharger une image en .gif ce qui le bloque.
j’ai ce message d’erreur :
Comment éviter cela?
bonjour,
Pour ma part çà fonctionne à peu près bien, preuve à l’appuie:
mplayer -playlist tv-direct.fr/flux_tf1live.asx
[code]MPlayer dev-SVN-rUNKNOWN-4.2.3 © 2000-2007 MPlayer Team
CPU: AMD Duron™ processor (Family: 6, Model: 7, Stepping: 1)
CPUflags: MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 0
Compiled with runtime CPU detection.
Resolving http://www.tv-direct.fr for AF_INET6…
Couldn’t resolve name for AF_INET6: http://www.tv-direct.fr
Resolving http://www.tv-direct.fr for AF_INET…
Connecting to server http://www.tv-direct.fr[213.186.33.19]: 80…
STREAM_ASF, URL: http://www.tv-direct.fr/flux_tf1live.asx
size_confirm mismatch!: 22611 28271
Error while parsing chunk header
Failed, exiting.
Cache size set to 8192 KBytes
Can’t open joystick device /dev/input/js0: No such file or directory
Can’t init input joystick
Playing mmshttp://www.tv-direct.fr/chargement.gif.
STREAM_ASF, URL: mmshttp://www.tv-direct.fr/chargement.gif
Cache fill: 0.06% (5265 bytes)
Playing mms://a918.l4162636917.c41626.e.lm.akamaistream.net/D/918/41626/v0001/reflector:36917.
STREAM_ASF, URL: mms://a918.l4162636917.c41626.e.lm.akamaistream.net/D/918/41626/v0001/reflector:36917
Resolving a918.l4162636917.c41626.e.lm.akamaistream.net for AF_INET6…
Couldn’t resolve name for AF_INET6: a918.l4162636917.c41626.e.lm.akamaistream.net
Resolving a918.l4162636917.c41626.e.lm.akamaistream.net for AF_INET…
Connecting to server a918.l4162636917.c41626.e.lm.akamaistream.net[193.108.95.93]: 1755…
Connected
read error:: Resource temporarily unavailable
pre-header read failed
Connecting to server a918.l4162636917.c41626.e.lm.akamaistream.net[193.108.95.93]: 80…
Server returned 404:Not Found
Failed to parse header.
Failed, exiting.
Cache fill: 0.00% (196 bytes)
AO: [alsa] 44100Hz 2ch s16le (2 bytes per sample)
Starting playback…
VDec: vo config request - 320 x 240 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is undefined - no prescaling applied.
VO: [xv] 320x240 => 320x240 Planar YV12 [fs] [zoom]
A:6643.3 V:6643.7 A-V: -0.416 ct: -0.548 0/ 0 5% 1% 1.2% 0 0 19%
Exiting… (Quit)[/code]
