j’ai vraioment pas de chance avec ce toshiba
ce matin je le redemarre et je tombe sur une fenêtre vous avez eu un probleme de noyau
Kernel failure message 1:
------------[ cut here ]------------
WARNING: at /build/buildd-linux-2.6_2.6.32-45-i386-yQfQSv/linux-2.6-2.6.32/debian/build/source_i386_none/fs/buffer.c:1160 mark_buffer_dirty+0x23/0x80()
Hardware name: SATELLITE C855-177
Modules linked in: ext2 parport_pc ppdev acpi_cpufreq lp parport cpufreq_stats cpufreq_conservative cpufreq_powersave cpufreq_userspace sco bridge stp bnep rfcomm l2cap crc16 bluetooth i915 drm_kms_helper drm i2c_algo_bit binfmt_misc uinput fuse loop uvcvideo videodev v4l1_compat v4l2_compat_ioctl32 evdev video rfkill i2c_core psmouse serio_raw pcspkr output ac wmi battery processor button ext3 jbd mbcache sg sr_mod cdrom sd_mod crc_t10dif usbhid hid usb_storage xhci ahci libata thermal r8169 mii thermal_sys ehci_hcd scsi_mod usbcore nls_base [last unloaded: scsi_wait_scan]
Pid: 305, comm: khubd Not tainted 2.6.32-5-amd64 #1
Call Trace:
[] ? mark_buffer_dirty+0x23/0x80
[] ? warn_slowpath_common+0x77/0xa3
[] ? ext2_sync_fs+0x6b/0x7e [ext2]
[] ? sync_quota_sb+0x45/0xf6
[] ? __sync_filesystem+0x43/0x70
[] ? fsync_bdev+0x1e/0x3b
[] ? invalidate_partition+0x1d/0x39
[] ? del_gendisk+0x2b/0xd8
[] ? device_del+0x194/0x1a0
[] ? sd_remove+0x44/0x7e [sd_mod]
[] ? __device_release_driver+0x96/0xeb
[] ? device_release_driver+0x1e/0x2a
[] ? bus_remove_device+0x8d/0xac
[] ? device_del+0x138/0x1a0
[] ? __scsi_remove_device+0x50/0xb7 [scsi_mod]
[] ? scsi_forget_host+0x39/0x5b [scsi_mod]
[] ? scsi_remove_host+0x6d/0xec [scsi_mod]
[] ? quiesce_and_remove_host+0x5f/0x9c [usb_storage]
[] ? usb_stor_disconnect+0x15/0x1e [usb_storage]
[] ? usb_unbind_interface+0x5b/0xe3 [usbcore]
[] ? usb_disable_device+0x47/0xec [usbcore]
[] ? usb_disconnect+0x8c/0x12d [usbcore]
[] ? hub_thread+0x6c8/0x11bc [usbcore]
[] ? autoremove_wake_function+0x0/0x2e
[] ? hub_thread+0x0/0x11bc [usbcore]
[] ? kthread+0x79/0x81
[] ? child_rip+0xa/0x20
[] ? kthread+0x0/0x81
[] ? child_rip+0x0/0x20
—[ end trace 8936944d1ee16993 ]—
bon je reboote et plus rien, l’ordi semble tourner normalement…
