problème de résolution
Bonsoir,
Je posséde un pc portable Hp 6710B avec une carte graphique : Intel® Graphics Media Accelerator X3100.
Je n’arrive pas a choisir la résolution 1280 x 800 dans la liste.
Mon fichier xorg.conf est comme ceci :
/etc/X11/xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
(Type “man /etc/X11/xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath “/usr/X11R6/lib/X11/fonts/75dpi”
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "be"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option “SendCoreEvents” "true"
Option “Device” "/dev/psaux"
Option “Protocol” "auto-dev"
Option “HorizScrollDelta” "0"
EndSection
Section "Device"
Identifier "Carte vidéo générique"
Driver "vesa"
BusID "PCI:0:2:0"
EndSection
Section "Monitor"
Identifier "Écran générique"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Carte vidéo générique"
Monitor "Écran générique"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “1920x1440” “1920x1200” “1856x1392” “1792x1344” “1680x1050” “1600x1200” “1440x900” “1400x1050” “1280x1024” “1280x960” “1280x854” “1280x800” “1280x768” “1200x800” “1152x864” “1152x768” “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "Synaptics Touchpad"
EndSection
Section "DRI"
Mode 0666
EndSection
J’ai déjà essayer d’installer 915 masi j’ai un message d’erreur quand j’execute 915reolution -l :
pc-portable-dodo-linux:/etc/X11# 915resolution -l
Intel 800/900 Series VBIOS Hack : version 0.5.2
Intel chipset detected. However, 915resolution was unable to determine the chipset type.
Chipset Id: 2a008086
Please report this problem to stomljen@yahoo.com
Merci d’avance
Pour choisir une résolution on peut faire en console :su mot-de-passe-root dpkg-reconfigure xserver-xorget choisir la résolution voulue à l’écran adéquat.
Mais comme le pilote choisi est vesa, je me demande si ce pilote (basique) n’a pas des limitations en résolution. Installer le paquet xserver-xorg-video-i810 serait peut-être une bonne idée.[quote]X.Org X server – Intel i8xx, i9xx display driver
This package provides the driver for the Intel i8xx and i9xx family
of chipsets, including i810, i815, i830, i845, i855, i865, i915, and
i945 series chips.[/quote]Pour installer le pilote vidéo i810, la procédure est indiquée ci-dessus.
j’ai fais ce que vous m’avez dit de faire et au redémarrage il me dit “no screen found” :s
merci d’avance
Au redémarrage recommencer en console avec les droits root le dpkg-reconfigure xserver-xorg et modifier le paramétrage de l’écran. Il y a probablement un truc qui doit coincer à ce niveau.
Bienvenue au club : tu as le même chipset que moi. Je n’ai pas résolu ce pb de résolution. J’ai envoyé un rapport de bug sur le paquet 915resolution. Essaye tjs ce paquet, ça marchera peut-être miraculeusement pour toi (après avoir installé xserver-xorg-video-intel)
Mais ton module n’est pas bon, normalement tu dois choisir “intel” et pas “vesa”. C’est peut-être seulement ça qui le bloque dans ton cas. On m’avait parlé d’un bug spécifique à ma carte mère, tu n’as pas la même, je pense.
D’ailleurs, je pense qu’il est fort possible que le bug soit sur le paquet xserver-xorg-video-intel…
viewtopic.php?f=3&t=10470
Bientôt, on fait une manif :wink:
Quelle version de Debian ?
bonjour,
ma version de debian est debian 4 etch
J’ai installer le paquet …xorg-intel et je n’est plus d’interface graphique ni de console ( j’ai un écran vert) d’ou j’ai réinstaller debian et je vais essayer de mettre intel a la place de vesa
j’essayer de mettre intel a la place de vesa et je n’ai plus d’interface graphique.
Que puis-je faire ?
Poste-nous les lignes de ton Xorg.0.log qui commencent par (EE)
[quote=“dodo1309”]j’essayer de mettre intel a la place de vesa et je n’ai plus d’interface graphique.
Que puis-je faire ?[/quote]
par su mot-de-passe-root dpkg-reconfigure xserver-xorg
ou “à la main”
su mot-de-passe-root nano /etc/X11/xorg.conf
