Pendant un “upgrade”, on me lance ce que suit et dont,n’etant pas un expert, Je ne sais pas que faire.D’autant plus que mon anglais est assez mauvais.
[quote]mysql-5.5 (5.5.33+dfsg-0+wheezy1) wheezy-security; urgency=high
mysql-server-5.5 ships with the upstream mysql_install_db script which
creates a database “test” and sets up permissions that allow anonymous
access, without a password, from localhost to the “test” database and
any databases starting with “test_” that users might have created
after installing mysql-server.
During the migration of mysql-5.1 to mysql-5.5 in Debian the patches
to drop these permissions and the creation of the test databases were
not applied. This update resolves this issue for new installations of
mysql-server-5.5.
If you are updating from a previous version of mysql-5.5 it is
recommended to check your installation and to drop these privileges
and databases manually.
Further information can be found at the MySQL 5.5 Reference Manual[1].
[1] dev.mysql.com/doc/refman/5.5/en/ … leges.html
– Salvatore Bonaccorso carnil@debian.org Sat, 14 Dec 2013 22:15:25 +0100[/quote]
Merci de votre aide
