Après avoir redémarré au moins une dizaine de fois, toujours pas de son mais des messages différents d’erreurs à chaque fois. Par exemple là avec le message “spurious response” au démarrage, le script alsa donne ça en détail:
[code]upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.63
!!Script ran on: Sun May 25 17:45:58 UTC 2014
!!Linux Distribution
Debian GNU/Linux jessie/sid \n \l PRETTY_NAME=“Debian GNU/Linux jessie/sid” NAME=“Debian GNU/Linux” ID=debian HOME_URL=“http://www.debian.org/” SUPPORT_URL=“http://www.debian.org/support/” BUG_REPORT_URL=“http://bugs.debian.org/”
!!DMI Information
Manufacturer: Hewlett-Packard
Product Name:
Product Version: F.07
Firmware Version: 68YTT Ver. F.07
!!Kernel Information
Kernel release: 3.14-1-amd64
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k3.14-1-amd64
Library version: 1.0.27.2
Utilities version: 1.0.27.2
!!Loaded ALSA modules
snd_hda_intel
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
!!Soundcards recognised by ALSA
0 [SB ]: HDA-Intel - HDA ATI SB
HDA ATI SB at 0x100000000 irq 16
!!PCI Soundcards installed in the system
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 Azalia (Intel HDA)
!!Advanced information - PCI Vendor/Device/Subsystem ID’s
00:14.2 0403: 1002:4383
Subsystem: 103c:30c2
!!Modprobe options (Sound related)
snd_pcsp: index=-2
snd_usb_audio: index=-2
snd_atiixp_modem: index=-2
snd_intel8x0m: index=-2
snd_via82xx_modem: index=-2
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : 32,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 0
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : N
snoop : Y
!!HDA-Intel Codec information
–startcollapse–
Codec: Analog Devices AD1981
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x11d41981
Subsystem Id: 0x103c30c2
Revision Id: 0x100200
No Modem Function Group found
Default PCM:
rates [0x7f]: 8000 11025 16000 22050 32000 44100 48000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Default Amp-Out caps: ofs=0x3d, nsteps=0x3f, stepsize=0x05, mute=1
State of AFG node 0x01:
Power states: D0 D3
Power: setting=D0, actual=D0
GPIO: io=4, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=1, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=1, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[3]: enable=0, dir=0, wake=0, sticky=0, data=1, unsol=0
Node 0x02 [Audio Output] wcaps 0x30311: Stereo Digital
Converter: stream=0, channel=0
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
rates [0x60]: 44100 48000
bits [0x2]: 16
formats [0x5]: PCM AC3
Delay: 3 samples
Connection: 2
0x01* 0x04
Node 0x03 [Audio Output] wcaps 0x441: Stereo
Device: name=“AD1981 Analog”, type=“Audio”, device=0
Power states: D0 D3
Processing caps: benign=1, ncoeff=70
Node 0x04 [Audio Input] wcaps 0x100511: Stereo
SDI-Select: 0
PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Power states:
Power: setting=UNKNOWN, actual=D1, Error, Clock-stop-OK, Setting-reset
Connection: 1
0x15
In-driver Connection: 2
0x3d 0x3f
Node 0x05 [Audio Output] wcaps 0x80: Mono
Control: name=“Speaker Phantom Jack”, index=0, device=0
Unsolicited: tag=00, enabled=1
Node 0x06 [UNKNOWN Widget] wcaps 0x0: Mono
Control: name=“PCM Playback Volume”, index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Control: name=“Headphone Jack”, index=0, device=0
Node 0x07 [Audio Output] wcaps 0x80051f17: Stereo Digital Amp-In Amp-Out R/L CP
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=0
Amp-In vals:
Amp-Out caps: N/A
Amp-Out vals: [0x80051f17 0x00]
Converter: stream=7, channel=15
Digital: Enabled
PCM:
bits [0x6]: 16 20
formats [0x1]: PCM
Power states:
Delay: 5 samples
Connection: 0
0x03 0x0e
Node 0x08 [Audio Mixer] wcaps 0x270300: Mono Digital
Control: name=“Mic Jack”, index=0, device=0
Delay: 7 samples
Connection: 0
Node 0x09 [UNKNOWN Widget] wcaps 0x0: Mono
Control: name=“Line Jack”, index=0, device=0
Node 0x0a [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x0b [Audio Output] wcaps 0x10: Mono
Converter: stream=1, channel=0
PCM:
rates [0x27]: 8000 11025 16000 44100
bits [0x0]:
formats [0x0]:
Node 0x0c [Audio Output] wcaps 0xbb54: Mono Digital Amp-Out R/L CP
Amp-Out caps: N/A
Amp-Out vals: [0x00]
Digital:
PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Connection: 0
Processing caps: benign=0, ncoeff=0
Node 0x0d [UNKNOWN Widget] wcaps 0x0: Mono
Control: name=“Beep Playback Volume”, index=0, device=0
ControlAmp: chs=1, dir=Out, idx=0, ofs=0
Control: name=“Beep Playback Switch”, index=0, device=0
Node 0x0e [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x0f [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x10 [Audio Output] wcaps 0xfdf3: 16-Channels Amp-In Stripe R/L CP
Amp-In caps: N/A
Amp-In vals:
Converter: stream=8, channel=7
PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Unsolicited: tag=00, enabled=0
Power states:
Connection: 0
Node 0x11 [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x12 [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x13 [UNKNOWN Widget] wcaps 0x0: Mono
Control: name=“Line Playback Volume”, index=0, device=0
Control: name=“Line Playback Switch”, index=0, device=0
Node 0x14 [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x15 [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x16 [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x17 [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x18 [UNKNOWN Widget] wcaps 0x0: Mono
Control: name=“Internal Mic Phantom Jack”, index=0, device=0
Node 0x19 [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x1a [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x1b [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x1c [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x1d [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x1e [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x1f [UNKNOWN Widget] wcaps 0x0: Mono
Codec: LSI ID 1040
Address: 1
MFG Function Id: 0x2 (unsol 1)
Vendor Id: 0x11c11040
Subsystem Id: 0x103c1378
Modem Function Group: 0x1
–endcollapse–
!!ALSA Device nodes
crw-rw----+ 1 root audio 116, 6 May 25 19:41 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 5 May 25 19:41 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116, 4 May 25 19:41 /dev/snd/hwC0D1
crw-rw----+ 1 root audio 116, 3 May 25 19:44 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116, 2 May 25 19:44 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116, 1 May 25 2014 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 May 25 2014 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 60 May 25 19:41 .
drwxr-xr-x 3 root root 200 May 25 19:41 …
lrwxrwxrwx 1 root root 12 May 25 19:41 pci-0000:00:14.2 -> …/controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: SB [HDA ATI SB], device 0: AD1981 Analog [AD1981 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card 0 [SB]
amixer: Mixer load hw:0 error: Invalid argument
Card hw:0 ‘SB’/'HDA ATI SB at 0x100000000 irq 16’
Mixer name : 'Analog Devices AD1981’
Components : 'HDA:11d41981,103c30c2,00100200 HDA:11c11040,103c1378,00100200’
Controls : 16
amixer: Mixer hw:0 load error: Invalid argument
!!Alsactl output
–startcollapse–
–endcollapse–
!!All Loaded Modules
Module
md4
hmac
nls_utf8
cifs
dns_resolver
fscache
ctr
ccm
rfcomm
bnep
iptable_mangle
xt_LOG
xt_tcpudp
nf_conntrack_ipv4
nf_defrag_ipv4
xt_conntrack
nf_conntrack
pci_stub
iptable_filter
vboxpci
ip_tables
binfmt_misc
x_tables
vboxnetadp
vboxnetflt
vboxdrv
uinput
fuse
snd_hda_codec_hdmi
snd_hda_codec_analog
radeon
snd_hda_codec_generic
powernow_k8
kvm_amd
hp_wmi
joydev
sparse_keymap
arc4
kvm
b43
snd_hda_intel
bcma
btusb
bluetooth
6lowpan_iphc
pcspkr
snd_hda_codec
mac80211
snd_hwdep
ttm
drm_kms_helper
psmouse
serio_raw
snd_pcm
evdev
drm
cfg80211
tpm_infineon
rfkill
rng_core
edac_mce_amd
sp5100_tco
snd_seq
snd_seq_device
snd_timer
k8temp
snd
hp_accel
yenta_socket
lis3lv02d
pcmcia_rsrc
input_polldev
edac_core
i2c_algo_bit
i2c_piix4
i2c_core
soundcore
wmi
tpm_tis
battery
ac
tpm
parport_pc
parport
shpchp
button
video
processor
ext4
crc16
mbcache
jbd2
sr_mod
cdrom
sg
sd_mod
crc_t10dif
crct10dif_common
ata_generic
firewire_ohci
firewire_core
crc_itu_t
ehci_pci
pata_atiixp
ssb
mmc_core
pcmcia
pcmcia_core
thermal
fan
thermal_sys
ahci
libahci
ohci_pci
ohci_hcd
ehci_hcd
tg3
ptp
pps_core
libata
libphy
usbcore
usb_common
scsi_mod
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x05 0x92174110
0x06 0x0421201f
0x07 0x410710f0
0x08 0x04a12020
0x09 0x0181302e
0x0a 0x4145f0f0
0x16 0x995711f0
0x17 0x5993e0f0
0x18 0x91a79121
0x19 0x593310f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC0D1/init_pin_configs:
/sys/class/sound/hwC0D1/driver_pin_configs:
/sys/class/sound/hwC0D1/user_pin_configs:
/sys/class/sound/hwC0D1/init_verbs:
/sys/class/sound/hwC0D1/hints:
!!ALSA/HDA dmesg
[ 8.230230] usbcore: registered new interface driver btusb
[ 8.278434] hda-intel 0000:00:14.2: spurious response 0x11d41981:0x0, last cmd=0x1f0500
[ 8.397929] b43-phy0: Broadcom 4311 WLAN found (core revision 13)
[ 9.115195] clean.
[ 9.284106] hda-intel 0000:00:14.2: spurious response 0x0:0x1, last cmd=0x15ff0009
[ 9.586409] [drm] radeon kernel modesetting enabled.
[ 9.625568] [drm] PCIE GART of 512M enabled (table at 0x0000000034680000).
[ 9.626726] hda-intel 0000:00:14.2: spurious response 0x11c11040:0x1, last cmd=0x101f0500
[ 9.626806] hda-intel 0000:00:14.2: spurious response 0x0:0x1, last cmd=0x101f0500
[ 9.626851] hda-intel 0000:00:14.2: spurious response 0x100200:0x1, last cmd=0x101f0500
[ 9.626895] hda-intel 0000:00:14.2: spurious response 0x10001:0x1, last cmd=0x101f0500
[ 9.626939] hda-intel 0000:00:14.2: spurious response 0x102:0x1, last cmd=0x101f0500
[ 9.626992] hda-intel 0000:00:14.2: spurious response 0x2007d:0x1, last cmd=0x101f0500
[ 9.627045] hda-intel 0000:00:14.2: spurious response 0x0:0x1, last cmd=0x101f0500
[ 9.627096] hda-intel 0000:00:14.2: spurious response 0x0:0x1, last cmd=0x101f0500
[ 9.628165] radeon 0000:01:05.0: WB enabled
[ 9.628379] [drm] Loading RS690/RS740 Microcode
[ 9.632201] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:14.2/input/input17
[ 9.874134] radeon 0000:01:05.0: firmware: direct-loading firmware radeon/RS690_cp.bin
[ 9.875973] [drm] TV1: INTERNAL_KLDSCP_DAC1
[ 9.915298] input: HDA ATI SB Headphone as /devices/pci0000:00/0000:00:14.2/sound/card0/input20
[ 9.916752] input: HDA ATI SB Line as /devices/pci0000:00/0000:00:14.2/sound/card0/input19
[ 9.916985] input: HDA ATI SB Mic as /devices/pci0000:00/0000:00:14.2/sound/card0/input18
[ 10.138821] cfg80211: World regulatory domain updated:
[ 52.810035] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
[ 54.216958] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.308365] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.341514] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.355134] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.374274] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.402285] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.430185] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.458358] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.486709] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.499007] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.511038] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.523520] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.535797] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.547903] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.560191] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.572571] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.584653] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.596858] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.608794] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.620809] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.633097] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.645081] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.657385] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.669442] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.681547] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.693590] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.705670] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.718195] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.730803] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.742960] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.755169] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.767457] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.779630] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.792447] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.804665] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.819381] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.832354] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.845476] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.858603] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.873366] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 54.888067] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 55.285247] tg3 0000:10:00.0: irq 44 for MSI/MSI-X
[ 150.154754] systemd-logind[2990]: Linked /tmp/.X11-unix/X0 to /run/user/1000/X11-display.
[ 162.421207] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 162.539497] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 162.604789] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 162.632945] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 164.294868] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 164.294922] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 260.218622] azx_update_rirb: 240 callbacks suppressed
[ 260.218640] hda-intel 0000:00:14.2: spurious response 0x0:0x1, last cmd=0x100f0004
[ 260.218671] hda-intel 0000:00:14.2: spurious response 0x0:0x1, last cmd=0x100f0004
[ 260.218676] hda-intel 0000:00:14.2: spurious response 0x0:0x1, last cmd=0x100f0004
[ 260.218681] hda-intel 0000:00:14.2: spurious response 0x0:0x1, last cmd=0x100f0004
[ 260.218711] hda-intel 0000:00:14.2: spurious response 0x0:0x1, last cmd=0x100f0004
[ 260.218716] hda-intel 0000:00:14.2: spurious response 0x0:0x1, last cmd=0x100f0004
[ 260.218734] hda-intel 0000:00:14.2: spurious response 0x0:0x1, last cmd=0x100f0004
[ 260.218755] hda-intel 0000:00:14.2: spurious response 0x0:0x1, last cmd=0x100f0004
[ 260.218774] hda-intel 0000:00:14.2: spurious response 0x0:0x1, last cmd=0x100f0004
[ 260.218796] hda-intel 0000:00:14.2: spurious response 0x0:0x1, last cmd=0x100f0004
[ 260.221412] hda_codec: invalid dep_range_val 0:0
[ 260.380019] tg3 0000:10:00.0: vpd r/w failed. This is likely a firmware bug on this device. Contact the card vendor for a firmware update.
[ 261.977378] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 261.992754] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
[ 262.009753] hda_codec: num_steps = 0 for NID=0xd (ctl = Beep Playback Volume)
